Show messages: All
1-6
7-13
Thanks guys. Always nice to be able to contribute! MoI is such an awesome tool!
Michael T.
Here is a very simple little script to find the Midpoint of a curve or an edge, closed or open.
I needed a simple function to get the midpoint of a curve segment, so writing this script helped to clarify the coding.
This code of this script has a very high percentage, modified and adapted, from LineWeb and BlendCap scripts.
The script could be made much more elaborate, to pick multiple curves and/or edges, and find Midpoints of them.
_CurveMidpoint.zip
Hello Brian (and everyone...and happy new year!)
Thanks a lot for this very useful script!
I've tested it also on a 3D curve and on a merged edge and it works fine (also with V4).
(With "merged edge" I mean an edge that I first trimmed and the merged with "merge" command)
Ciao!
Marco, thank you, and thank you for the testing.
A brief, extremely simple self reminder, about MoI in general:
Hidden edges or curves cannot be selected until they are unhidden, using Hide or Styles of Types, or some other script. :-)
It seems that objects saved by MoI and reloaded may have a few previously hidden edges unhidden.
It seems that objects saved by Max's ObjLibrary , and reloaded with customUI, have ALL previously hidden edges unhidden. (?)
I assigned Shortcut key "M" to _CurveMidpoint.
It might be nice to redo the script to conform to the behavior of "_MarkCurveStart" script.
And call it "_MarkCurveMidpoint.
- B
Here is the script _MarkCurveMidpoint, which works like _MarkCurveStart.
Now I have shortcut key Alt+M to get curve or edge start points,
and shortcut key M to get the midpoints.
The script is essentially the same as _CurveMidpoint, with a for loop...
_MarkCurveMidpoint.zip
Yeah I happened to run into this recently as well - it's a bug where the last edge of a brep doesn't get its stored hidden property loaded. It's fixed for the next beta.
Show messages: All
1-6
7-13
