Full Version: Engrave tool
Show messages:  1-13  14-22
25 Apr 2012   [#14] In reply to [#13]
Hi Stevecim,
In your original post you were speaking of needing to boolean the continents away from the globe.. If all you want is lines, then you could probably do an "isect" command and generate outlines of the continents.
Look under construct-curve-isect and give that a whirl. Then you could also trim the globe surface with those curves and have continent surfaces too... Maybe run "ExplodeMove" on the seperated lot, to make a cool 3d image of the thing.
25 Apr 2012   [#15] In reply to [#14]
thanks Burrman, I'll give it a try :)
25 Apr 2012   [#16] In reply to [#15]
Earth.. ExplodeMove!!!!!
25 Apr 2012   [#17]
I love ZSurf. Used it quite a lot. Here are two examples:
http://grabcad.com/library/peugeot-badge-and-loge
http://grabcad.com/library/relief-with-frame
25 Apr 2012   [#18] In reply to [#17]
Nice work Sebastian, Like most MoI users here, your work is at a level I can only bream of reaching :)
here is what I done so far with Moi + ZSurf.
MWSnap061 2012-04-26, 16_02_46.jpg  MWSnap062 2012-04-26, 16_04_29.jpg  MWSnap063 2012-04-26, 16_05_12.jpg
25 Apr 2012   [#19]
Made an Antarctica from NASA map.
Outline is mostly ice...
Probably too many control points.
Planar and extrude work, but are very slow.
Not to scale...
25 Apr 2012   [#20] In reply to [#19]
a 3d pdf for the kids to learn from???
"Hey, where's antarctica???"
Very good johnny... :)
29 Apr 2012   [#21]
My two cents, from a cartographic point of view:
To create a correct globe in Moi, use a world-map that is "Unprojected" or is in the "Geographic projection". This is a world map with a 2:1 width/height ratio that will produce a correct globe.
29 Apr 2012   [#22] In reply to [#21]
thanks Dexter
