Full Version: Anyone wish to develop a custom script?
Show messages:  1-9  10-29  30-49  50-69  70-89  90-109  110-129  …  210-223
26 Dec 2011   [#50] In reply to [#49]
oh thanks, I did not see the scroll button. now I can check it out.
P.S. Maybe there is a way to have it float, rather than docked in the side. That way you wouldn't have to worry about width.
26 Dec 2011   [#51] In reply to [#50]
Looks good bemfarmer,
I imported the points and they lay right over the curve your program generates. Like you said you still have to work out the radius but I like how you have the curve and then the points to make the radius. The only thing would be on your curve fit it looks like the "through points" option whereas for this curve you want the "control points option". I think you'll see that once you start trying to get the radius in there. The first and last point of the curve will change once you get the radius in there too, since they will become a point tangent to the circle.
But looking good man. thanks
26 Dec 2011   [#52] In reply to [#50]
Hi Anthony
I made up a "skinny" menu for MoI version 2. (Not as nice having abbreviated names). (Mostly, I use MoI Beta 3 now, where the wide menu works fine.)
(At this time, believe one must own MoI2 to download Beta3)
Don't know how to "float" a menu. There are lots of posts on "custom UI"...
Working on Rail section now...
26 Dec 2011   [#53] In reply to [#52]
Tried it out, works good with my version.
27 Dec 2011   [#54]
Getting close, after many corrections to rails script.
27 Dec 2011   [#55] In reply to [#54]
Looking good. Just a reminder. The rail spines should be made with the through points option. Where as the airfoil should be made with the control points option.
27 Dec 2011   [#56] In reply to [#55]
Regarding through points option, Blue curve and Blue points,
versus control points option, Red curve, and Red points.
Created two AirFoil curves, with two scripts differing by the following two lines, (using Styles for colors):
Blue points and Blue (interpret)curves are created with var factory = moi.command.createFactory( 'interpcurve' );
Red points and Red (curve)curves are created with var factory = moi.command.createFactory( 'curve' );
Note that the Red control points are the same AirFoil points (which would be) generated by the Fortran code, and also,
that these Red points are the Nurb control points for the Red curve.
Note that the Blue (interpret)curves pass through the Red control points.
The Blue control points I interpret to be Nurbs control points, which are NOT the Airfoil points which would be generated by the Fortran code.
Note that creating only the Blue (interpret)curves, that the Airfoil points are not shown, however by generating the Blue (interpret)curves, and
ALSO by using the (second) point factory "for loop", (via a third version of the interpcurve script, indexing the second "for loup" from zero to 28,)
to create ALL of the airfoil Points, that the airfoil Points show up, without using the "var factory = moi.command.createFactory( 'curve' );" code.
27 Dec 2011   [#57]
I have realized that trying to get MoI to access an array element that does not exist, causes an error.
Suggestions to Anthony, (or myself):
1. Do not hardcode the number of elements (27) in the arrays, in the Airfoil Points Do (or for) loup. ?
(Instead use the javascript array length.....)
2. Test to see if the number of elements in the AFXTAB and AFYTAB are the same. ? (With warning alert)
3. Place the Extra (radius) points in separate arrays similar to AFXTAB and AFYTAB. ? (same # of "X" and "Y" types.)
I will change the control points, as per your reminder above.
(Should be possible to have multiple airfoil cross sections, with nested loup......)
27 Dec 2011   [#58] In reply to [#57]
Hi bemfarmer,
A lot of that is way over my head. But the reason for the control points aspect of the airfoil curve generation is because of the leading and trailing edge circles. The NACA data points do not agree with the radius they specify for the le and te. If you were to strictly follow everything they specify in the document, you would end up with a lumpy airfoil. The picture you attached with the red and blue curves do not have the leading and trailing edge circles in there. So that may be why you aren't sure why I'm deviating from the data points at this step.
The hard part is going to be coding all that from your aspect. I don't know how you script MoI to generate a model, or if it can be done. So I can only speak about how I am doing it manually. I don't know if that translates to the way it would be coded. But it should become pretty obvious to you when you start to try and generate the whole airfoil, that you will have to use the control points option for the airfoil data points.
To get the whole airfoil curve that you need for the sweep, I do the following:
1) make circles at the leading and trailing edge, using the naca defined radii
2) make a line from the last naca point defined near the le and te to points tangent to the circles
3) make points at the intersection of the lines and circles
4) delete the lines and circles
5) use the new points as the start and end of a spline that runs through the naca defined points, using the control points option
6) mirror that spline
7) make arcs at the le and te
8) select all four curves and join them
Now you have a smooth airfoil that closely follows the naca document. You can sweep it using the le and te rails. The 1/4 chord rail is for reference. You can create the hub cutout with it, measure the radius, and apply loads later on with a different program if desired.
I hope that helps some.
Anthony
27 Dec 2011   [#59] In reply to [#58]
Thanks Anthony.
Looked again at your 16 pictures of your process.
So the key is to find out the y and z coordinates of Tangent point T
I never before heard of Thale's theorem, but it provides another way to locate Tangent point T.
A high school student could probably canculate the formula for point T, given points P[1], P[2], and O. :-)
Not sure exactly which tools in MoI script to use...
http://en.wikipedia.org/wiki/Thales%27_theorem
http://en.wikipedia.org/wiki/Tangent_lines_to_circles
27 Dec 2011   [#60]
Aren't you making an assumption that the leading and trailing edges are circular for any distance? I read the NACA specs to say that they are not constant radius at any point of the profile. All that is given is the instantaneous curvature radius at the leading edge point and the trailing edge point. I read one article that suggested using a tilted ellipse at the leading edge replacing the first points of the equation.
28 Dec 2011   [#61] In reply to [#60]
Hi bemfarmer,
I never heard of that theorem either. You seem to be on the right track though. SteveMacc, I have the radius going through the end points of the airfoil, so that the chord works out. I have never tried fitting an ellipse to the data. The trailing edge works out as is. You can use the NACA points and the ter they define with no issue. The ler and the data are what do not agree. In order to keep the chord, using the radius they define, I curve fit the data points. If you know of another way, please demonstrate. I'd be interested in looking at it.
28 Dec 2011   [#62]
Time for a script update.
This script functions pretty good.
There are still likely errors and mistakes.
Extra points have been moved to the end of the AFXTAB and AFYTAB arrays.
There is an AirFoil curve version, and an interpcurve version.
There is a narrow menu for MoI2, and a wider menu for MoI3Beta.
The leading edges and trailing edges have not been converted to radii, but this can be
easily done in MoI.
Using either the curve version, or the interpcurve version, I think there will be a (tiny) flat or bump spot, where the
radius joins with the airfoil "spline." (Seems to me the control points should be on the surface of the blade, via interpcurve...),
but for artistic work, they are both very close...
28 Dec 2011   [#63] In reply to [#62]
i tried out the updated scripts. its looking good. the reason your curve is a little lumpy is because the very first and last points that you are using are for the creation of the leading and trailing edge circles. so there are a total of four points there for reference. the rest of the points are the ones you want to use for curve fitting the airfoil shape.
i have a question about installing your script. how do you get the narrow script to work. i copied all the files into the commands folder, but when it starts it is the wider version being used. likewise, how do you go about stalling the curve version as opposed to the other version of the javascript.
28 Dec 2011   [#64] In reply to [#63]
Tried out the script. I was able to fillet the leading edge nicely. although that causes me to loose the original intent of the airfoils curves.
I wonder if it would be better to get the end radius values with a fillet "after" the solid has been generated? Just poking my 2 cents in...
28 Dec 2011   [#65] In reply to [#63]
Hi Anthony,
Need to rename either the narrow .htm menu name to match the the javascript .js name, (with different extensions of course.),
or vice versa. (With matching shortcut key of course.)
Variations of scripts and menu's, with modified, but matching names, can have different shortcut keys.
I have a few ideas of how to automate the top and bottom arcs, maybe using part of trim....
The bisector line script looks interesting. There is a wealth of information in Michaels scripts, which I'm trying to underestand...
28 Dec 2011   [#66] In reply to [#65]
For example use rename...
PropDesignGeoCurve.js (Curve version)
PropDesignGeoCurve.htm (narrow version)
(with shortcut key command PropDesignGeoCurve)
28 Dec 2011   [#67]
Creating radius arcs at leading edge & trailing edge using control points
Leading edge radius arc:
1. Calculate all AirFoil control points, as points only.
2. Using pt_ex1 as center, and pt_af1 as radius, form upper half of
semicircular arc_le.
3. Calculate pt_thales1, or locate it using midpoint of line segment from
pt_ex1 to pt_af2.
4. Using pt_thales1 as center, and pt_ex1 as radius, create upper
semicircular arc_thales1.
5. Find intersection of arc_le, and arc_thales1, which is point (pt_tan1).
6. Create new arc_le, using pt_ex1 as center, and pt_af1 as radius start, and
pt_tan1 as radius end.
7. Push arc_le into AirFoilfactories array.
8. Similarly, create arc_te at trailing edge, pt_thales2, and pt_tan2.
9. Starting at pt_tan1, create control points curve factory, using pt_af2...
pt_af24, and pt_tan2. and push into AirFoilfactories array.
10. Push arc_te int AirFoilfactories array.
11. Commit AirFoilfactories array.
12. Create Rails.
Done.
28 Dec 2011   [#68]
Also tried out a leading edge radius, using the upper NURBS control point ,of the interpcurve "spline",
in order to create the tangent point. (Don't know if this would be workable in practice.)
I think the leading edge should be a euler spiral curve. (spiro). ??
28 Dec 2011   [#69] In reply to [#68]
I tried renaming them after I posted that message and it worked out. But glad to know that is what I was supposed to do. The first two pics you posted in your last message look good. I couldn't quite tell about the third pic. It really seems like you know what you are doing now though. Thanks again for all your hard work. I look forward to the next version. I will be away from the computer for most of the day.
Anthony
P.S. I played with some of the blade generation options this time and it seems like it is working. Didn't do a definitive check. But I tried counterclockwise rotation with forward sweep, and elliptical chord distribution, and a different chord, and it all recalculated fine. This is going to be a real time saver. Would it be possible to show the points on the rail lines. Also having the rail lines, rail points, in their own layer. And the airfoil curve(s) and airfoil points in their own layer.
