 121-140
 141-160
 161-180
 181-200
 201-220
 221-223
hi karsten,
thanks for continuing to look into this. i'm glad you find prop design easy to use. that was one of my main goals. unfortunately over time the inputs and settings grew. but there wasn't really anything I could do about that. i'll take a look at the file and get back with you. in the mean time. there is a video that covers a few things I forgot to mention the cad issues video. i'm not sure if you seen it or not. it may help to answer your question too. the links for the video is;
https://www.youtube.com/watch?v=jNkNNawmfJ0
hmm, kinda hard to see what's going on in the model. that is a hard blade to model. I will model it manually and post the file for you to look at. I won't project onto cylinders though because that takes forever. with the tip going to a point, that makes it worse as well as far as projecting onto cylinders. but hopefully, the file i'll send you will help to see the default layout. the airfoils should align with the rail points that come out of prop design. if that makes sense. the orientations are always the same so once you get something working it should always work. I posted a file a few messages back for another user. it is the one shown in the screencast. it too may help you see the orientations. it has all of them in there too. so it is more thorough than what i'll send this time.
so that was useful. I started recording a screencast for you and right away ran into a bug with xyz. I fixed the bug but haven't posted the update yet. I finished the screencast too but have to upload it. I also have to finish working on the rhino file. So lots to do. Give me an hour or so to get everything done and I'll post the file when I'm finished with everything. Hopefully, this will all answer your question.
Hello Anthony,
please don't generate the complete model. It's a lot of work - only 1 or 2 curves in the tip area where the span left the parallel to the xy plane. The shown examples don't show the orientation of the profile and the base coordinate system fro the orientation to the cylinder, because the span is nearly in a plane. By the way, the model was complete generated by the node editor. It's a hard peace of cake, but it helps me to improve the node editor extensions and understand the node editor itself. Now I have to view your video on YT:-)
Have a nice day
Karsten
there seems to be something odd about a few of the airfoil positions. i'm looking into it now. but I posted the file and associated screencast. it may help. let me know if you have more questions. it looks like it's going to take awhile to dig into this on my end.
I think there may be some bugs in xyz. I checked a few of the angles for the model in question and they don't match what they should be. It seems like the le and/or te rails may be incorrect. I'll keep working on it.
here is the swept computer case fan example. it's setup to the default cartesian reference frame. I ran into a rhino issue when doing it. so i'm going to go back to the example you mentioned and see if it was rhino messing up again. I came across a really weird orient problem. some of the airfoils came out right and a bunch came out wrong. so I had to redo them to get them setup right. so it maybe that oddball angle was a rhino problem. i'll keep working on it. but the attached file may answer your question better. everything appears in order with this model.
hi karsten,
so I made some errors creating the last two airfoils in the model I sent you for the a400m blade. I  have it oriented much better now. the angle of attacks match. there isn't that odd angle showing up. however, the sweep isn't matching up exactly. so I still have to look into it a little more. I found you can use the 2 rail sweep going to a point with multiple cross sections. to smooth it out I skipped a few of the cross sections around the kink. the solid looks a lot like the one I usually get using just the first cross section. I also curve fit the rails to work out the kink, as mentioned in the video. so it's much better now. there may not be an issue with prop design. but i'm still not sure. I am seeing a much smaller difference. at least it's not a huge difference like I was getting.
hi karsten,
ok. so there were some rhino issues with my first attempt at the a400m blade. I left the links up to the file and video. However, I attached a new model and video to this message. The model seems to be accurate now. The video goes over the model. The only thing I see is that the sweep measurements are based off the te in this case. basically the sweep measurement is bouncing from various places. some models it would be the le, some the span, and some the te. this happened with the 10th anniversary update. I basically have to choose if I want the model to bounce around or the sweep measurement to bounce around. I thought it was better to keep the model from bouncing and hadn't realized the affect on the sweep measurement until now. the sweep seems fine it is just how the measurement is done that is changing. so it's probably something I should mention in the documentation. I don't think any changes to the code are needed right now. it is pretty confusing though.
anthony
Hello Anthony,
Thank you very much!
I got it. I will try to correct the positioning of the profiles tomorrow.
Karsten
yw karsten. i'm concerned I created an issue with certain chord distribution options. the sweep should really be defined at the aerodynamic center for all chord distribution options. I was surprised to see that wasn't the case on the a400m. I suspect options 3-5 are messed up. I'm not entirely sure how to fix that right now. hopefully this won't mess you up too much. if I have to make a code change then I also have to make new input files etc... so the example geometry may change slightly. I have to figure out what's going wrong first. seems like I fixed some things only to break others. i'm really glad you brought this to my attention. for now stick to options 1 and 2 and you should be fine to use the total sweep angles output by the code.
@Barry,
It seems something is wrong with the email system. I'm not sure if this is what you looking for. Please replace the links for the csv files and adjust the extrusions.
Have a nice day
Karsten
 AirfoilXX2.nod
AirfoilXX2.nod
hi karsten,
I finally made some progress understanding that bug. I think ultimately nothing is going to change as far as for you. I just need to make some changes so the analysis is correct. Unfortunately, understanding the angles is pretty difficult. More so than I thought. I will have to make some pictures and things to try and explain it for the documentation. But basically the total sweep angle is measured in the top view (x-y). It would be about the local z axis of each cross section. In the videos I was saying the global z axis but that's not the case. So if you are using the total sweep angles from the file that is how to use them. I will have a new version of PROP_DESIGN out at some point but I don't think it will change much from what you are seeing and dealing with.
although on second thought. I can now compute the total sweep angle at the aerodynamic center. so I can output it as well. that may fix the whole mess of different reference points. In that case, you could measure everything from the ac. which is how it's supposed to be. i'll see about doing that. not sure what will happen. but i'll get back with you.
hi karsten,
I got the bug fixed. you can now use the angle of attack and total sweep angle files at the aerodynamic center, as was always intended. I checked them out using the a400m model you asked about. there is an updated version of prop design on my website. download that. all the input files were updated as well. so re-run the a400m example. I posted the file I talk about in the screencasts. the links to the updated answer to your question are here:
rhino 5 3dm file for the a400m example; edit - this file was replaced with a more detailed version. the link is in a later post.
screencast part 1;
https://youtu.be/lJ7FFXkQr9c
screencast part 2;
https://youtu.be/mQMdhpCeoZA
screencast part 3;
https://youtu.be/Ns2GiYCnL80
I deleted all the old files and screencasts that I posted in previous forum messages. let me know if you have any more questions.
Hello Anthony,
I had some problems with flipping coordinate systems for clockwise and counterclockwise rotation. I think that I solved it now, but I have to download and compile your updated software. What I saw while testing the script for A400M and Predator example, is that the Profile A is on top for A400M and on the bottom for Predator. For a symmetric profile no problem. Do you use also asymmetric profiles in your software or am I generally wrong?  Problem with my script or my interpretation of the data? I don't know.
Do you have the possibility to test the node scripts already?
Have a nice day
Karsten
hi karsten,
yes the airfoil is symmetric. I believe you are right that a and b will switch depending on the blade. that isn't something that affects me but if it is messing you up, let me know. I know in the code there are four outcomes that I had to program. clockwise, counter-clockwise, swept forward, and swept back. so you may run into that as well. I don't have moi yet. I was waiting for v4 to come out, to try and make the switch easier. I don't know anything about the node editor or all of max's custom scripts. I have been reading the forum for years though. so I kind of know what all has been going on. but I haven't used any of it. I'm sure i'll have lots of questions once I get started.
Hello Anthony,
if the profiles always symmetric - there is no Problem. I use only the rails, span and profiles in the script.
I think that's a forum is made for.
Have a nice day
Karsten
Hi Anthony,
can you take a look at the attached curves that I produced with the node editor to see if they are what you require.
At the moment I produced the 2 sets with different nod files with the node editor but will see if I can incorporate both into one nod file.
Anyway hope this helps.
Barry
.png)
hi barry,
thanks for continuing to work on this. i will take a look. i downloaded the file and right away noticed something odd. the second airfoil from the origin seems rotated 90deg out of phase to the rest of the airfoils. i'll continue to look at the file though. the rest seem like they could be right.
hi barry,
the swept fan blade appears to be more inline with the needed outcome. it will take me some time to do exact comparisons. but i could do a two rail sweep on the geometry you provided and the airfoils visually seem like what you would want. the a400m blade though has some problems. the second airfoil in is about 90degs from the others. but none of the airfoils seem to have their sweep value. when i try a 2 rail sweep the blade is wavy at the tip and the surface is very heavy. it's really slow in rhino. it seems like the airfoil curves might have too much definition if that makes sense. i didn't seem to have that issue with the swept fan blade you provided. but i will work on my manual models so i can do more of a comparison for you. but it seems like you are getting close. i can visually see you have them onto cylinders which is great. and you have two kinds of profiles which is really useful too.
here is a link to the updated a400m model. there is tons of info in there you can use to compare to. i manually created everything in the file. when doing the 2 rail sweep i ignore two of the profiles that deviate a lot from the curve fit rails. this is to smooth out the wavyness. this is kind of a bad example to use for comparisons. but since you picked it, i went ahead and detailed the model the best i could. i will work on the swept fan blade next. that one is a better test case.
 121-140
 141-160
 161-180
 181-200
 201-220
 221-223
