Full Version: Majik Tutorial: Audio Speaker
Show messages:  1-15  16-35  36-55  56-59
29 Sep 2011   [#16] In reply to [#15]
Try first with very small objects ;)
Not sure that the format 3Ds keep the color! skp no (and not also any names) you must export in 3Ds then explode in Sketchup
objects named must keeping but with maybe name become something like ob01, ob02 etc...
29 Sep 2011   [#17] In reply to [#15]
Hi Mike,
> I just imported a .obj file made from MoI and I got this:
That's the kind of thing that happens when a renderer tries to triangulate a complex n-gon but doesn't quite do a good enough job of it and has triangles kind of leaking to the outside of the n-gon instead of only generating triangles inside of the n-gon.
You might want to send that file to the Kerkythea as a bug report for an example of an n-gon triangulation failure.
In the meantime, to avoid that problem use the "Output: Quads & Triangles" option when exporting out from MoI rather than "Output: N-gons". That will use MoI's mechanism for triangulating the n-gon instead of relying on Kerkythea to do it.
Generating a good triangulation from complex n-gons is a fairly tricky business - some programs are not very refined in that particular area so if you encounter that you shouldn't export n-gons to them.
> Where is this report file located, or was it something it wanted
> to save but did not get a chance?
It depends whether you're running in XP or if you're running on Vista or Win7 with UAC enabled. Under XP they'll be written to the same location as moi.exe .
With UAC enabled in Vista or Win7, programs are prevented from writing to the "Program Files" folder, and in that case it will go to your %Temp% folder - go to Start > Run and put in %Temp% to go to that folder.
> What I mean by "smoothing" (SU term) is an attribute between
> two polys where they tell the renderer to either Phong blend them
> or to allow them to look "faceted".
When exporting to OBJ format MoI does export vertex normals that should be used by the renderer to handle phong shading.
SketchUp however is an exception and doesn't make use of that particular vertex normal data like other renderers - instead SketchUp always calculates its own vertex normals from the polygon data and instead relies on flags on each edge for whether it's supposed to be a smooth looking boundary or not. When you export from MoI to SKP format MoI's exporter will set those edge flags so edges on polygons from a smooth surface are both hidden and have their smooth flag set.
For going to Kerkythea I believe that it will make use of the vertex normals in the OBJ file to do the shading, so the data that MoI exports there will directly control the phong shading in that case. That tends to give the best results because the vertex normals come from the original NURBS surface, so using them to do the shading makes the polygons shade in the exact same way as the original surface.
In SketchUp the shading tends to be a little bit off since it doesn't use the original vertex normals and instead cooks up its own from the polygon data.
29 Sep 2011   [#18] In reply to [#15]
Hi Mike, looks like you added some more to your post that I didn't see.
> Tried a .3ds file. I didn't come in bad like that. It was tiny
> however and the colors were gone. The materials list on the
> side listed every object in the model instead.
MoI currently only exports style/material information to LWO and OBJ polygon formats.
3DS should generally be avoided - it's a really antique old format and has a lot of limits in it like a 16-bit numeric limit for the max number of vertices in a single mesh, and no provision for vertex normals or polygons with more than 3 sides.
Only use 3DS as a last resort method, you will usually get much better results with OBJ files.
> The setting to "Z-Up" fixed that, but I'm having degenerated
> polys everywhere as show in the pic. I tried lower angle-out
> settings too.
That's because you're exporting n-gons and the n-gon triangulation on Kerkythea is a bit buggy with handling complex n-gons, which is fairly common since it's a bit of a tricky thing to make really robust.
If you switch to export Quads & Triangles or Triangles only out of MoI it will avoid that problem and it should work a lot better for you.
29 Sep 2011   [#19] In reply to [#18]
Whew!
Bless you Michael!!!
Exporting with Quads and Triangle did the trick - And the materials with the naming was retained!
This is wonderful!
And hopefully, the positioning data is retained, so that Kerky puts everything where I left them in MoI, instead of centering newly merged into the scene - but I'll have to experiment with that.
29 Sep 2011   [#20] In reply to [#19]
Hi Mike, I'm glad that's working for you now!
MoI does not alter the object's location when it creates the OBJ file so if you're seeing something like imported objects being centered that is something that Kerkythea is deciding to do to the import - there is probably some setting in it that you can change to make it stop doing that.
29 Sep 2011   [#21]
I had problems trying to re-export the mesh object, MoI crashed. I sent the canned error zip to you, but the OS just may need to be re-booted.
I had the one I made earlier and combined it with the other parts of the speaker.
Kerkythea Boost, Metropolis Light Transform (BPT), only a few passes, but this image was reduced by 2 to clear up the noise.
Used one omni-light at a low angle. And a little F# tweaking on the camera.
Not bad for my little bit of knowledge with MoI-Kerky rendering.
29 Sep 2011   [#22] In reply to [#21]
Hi Mike, thanks for sending the crash report. I'll take a look and see if something can be tuned up so that it becomes just a failure rather than a crash but often times out of memory handling is quite difficult to deal with well. Just in general it's not something that I expect to get to as high a level of robustness as regular operation. One reason for that is that it's difficult to test and replicate the problem with the memory allocation failing in the exact same way as it did during your run.
Usually it is best to try and avoid running out of memory in the first place. If you know that you have a particularly heavy model and that it is likely to run out of memory try exporting it in some chunks instead of all in one big piece.
29 Sep 2011   [#23] In reply to [#22]
Yeah.. I looked at that silly CPU/MEM "Gadget" Windows 7 has, it was at around 25%.
And there may be something else not set right. The vid driver temporarily crashed twice today. Once when only Adobe reader was running.
But me and my brother are still in the "let's see if this baby really works" phase of this new work PC.
But man! Does it feel good to get a MoI model rendered. :-)
29 Sep 2011   [#24] In reply to [#23]
Hi Mike, one thing to keep in mind is that MoI is a 32-bit program, so it will max out at something like around 3.6 GB of memory usage, not when all your full 64-bit system memory is exhaused.
So to monitor MoI for running out of memory, if you're on a high memory 64-bit OS you'll really need to monitor MoI.exe in the process list and not just your overall system memory consumption. If you're on a 32-bit OS or on 64-bit with more like 4GB of memory then you could watch overall system memory.
When you have a particularly high level of geometry like you're doing here you will probably need to pay some extra attention to some things like this which you don't need to worry about so much with a more regular kind of model.
You also may get some better results for high complexity models if you reduce the display mesh density to be coarser - that can help to reduce memory consumption by quite a bit.
Some details for that in this previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4196.2
The settings for that are under Options > View > Meshing parameters - try setting "Mesh angle" to 25 degrees and uncheck "Add detail to inflections". That may reduce memory load a fair amount.
29 Sep 2011   [#25] In reply to [#23]
Hi Mike,
You might make sure it's not getting overheated - is your system possibly overclocked?
Also it's probably a good idea to go directly to your video card manufacturer's web site and download the latest driver they have available from there to see if that helps.
29 Sep 2011   [#26] In reply to [#25]
Thanks for that advice... I was wondering about the limitations being a 32 bit app.
We were thinking some of the same things about the video.
I had a tech put me on a different login with admin priv. due to requirements to get my M$ Outlook connected among other things.
An error log my brother was looking at eluded to the fact that something was denied some type of privileges when MoI crashed.
I plan on uninstalling and re-installing the INVIDIA driver in the morning to rule that out.
If it was a hardware problem the vid card blackouts (2 of them) would have happened when I was taxing my system... hard to tell at this stage.
But yes... that model is a stresser for MoI under any circumstances.
29 Sep 2011   [#27]
MAJIKMIKE -
I really like the render - nice dramatic lighting. Again, a fantastic model and I'm trying it out right now in KeyShot (still can't get the grill exported out of MoI due to memory limit).
Do you mind if I post a KeyShot version later tonight?
Ed
29 Sep 2011   [#28] In reply to [#27]
Thanks Ed!
Yes, go ahead - that's why I posted it. Have at it!
Ed, try this out: https://www.mediafire.com/folder/3tlre2zc6y1qh/MoI (test 1.zip)
It is the .obj that worked for the wire mesh. Can't guarantee it, but give it a try.
29 Sep 2011   [#29] In reply to [#28]
Hi Majik,
Just a mention on the original surface you had import issues with, that is a "joined surface" and not a solid, so it may have had something to do with that. Although you did get it going with quads and tris, so it is just information/speculation.
29 Sep 2011   [#30] In reply to [#29]
Hi Burr that kind of looking thing where triangles seem to be leaking out of an n-gon outline usually means that something went wrong with a process of converting n-gons into triangles.
In order to convert an n-gon into triangles, one edge of the n-gon will be connected to a point somewhere else on the n-gon. If it's not handled carefully then the connection to that other point could cross over the outside area of the n-gon if it's a complex concave type shape.
That's something that can tend to happen pretty easily in n-gon triangulation functions, it's not all that easy to make a really robust triangulator.
If the rendering program that you are exporting to has those kinds of problems in handling complex n-gons, then you'll need to use the "Export: Quads & Triangles" option to do the triangulation in MoI instead of relying on the rendering program to do it.
29 Sep 2011   [#31]
Majik -
Here's your model rendered in KeyShot. Thanks for sharing!
29 Sep 2011   [#32]
hi Majik
i exported your mesh without problems, (i don't understand exactly..you got this mesh in obj or not??? )if needs take a look below
for Rich
sorry for misunderstandings:MY APOLOGIZES.This is a peaceful forum,this also is main reason when i decided to post some stuff
I respect you and i told you
in dutch without dubts:Mijn excuses
29 Sep 2011   [#33] In reply to [#32]
@m-dynamics
No problem and thanks for the kind words. :-)
Peace,
Rich_Art. ;-)
29 Sep 2011   [#34]
Thanks Mike!!
Very good tutorial, and nice result!!
Man that's a lot of screen captures!!!! :)
29 Sep 2011   [#35]
Hi all! It is impossible to make. Please explain as?
-Riko
Flow test.3dm
