Full Version: Sunglasses with Flow
Show messages:  1-6  7-26
1 Sep 2011   [#7] In reply to [#6]
Hey, get an order for 144+ tee's and I'll quote you a price. ;-)
1 Sep 2011   [#8] In reply to [#7]
They better be the "good kind" with a tight, solid neck.. Not the soon to be waxing rags!!!! :o
1 Sep 2011   [#9] In reply to [#1]
Hi Mauro, that is an awesome result, and that really shows off the potential for the new flow command quite well! Thanks for posting the images to show the progression.
So much more depth and nuance in your final result compared with the initial extrusion!
This ability to start with some more simple blocky initial shapes should make things a lot easier than it would have been to create that final result directly in place.
1 Sep 2011   [#10] In reply to [#1]
Very cool Mauro!
Shows us Moidellers the powerful potential of the new flow command, it's almost TSplines for MoI :)
Nice going Michael!
1 Sep 2011   [#11]
Wow it is great,
i would have loved to see this tutorial as a video
Message 4471.12 was deleted
3 Sep 2011   [#13] In reply to [#12]
Thx ;)
I have also put your tut on some forum where I am and of course on the French Part http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=249.1 ;)
(in English or French) Ps You have not a Web site for link to it?
http://forum.zbrush.fr/index.php?topic=8003.msg110363#msg110363
http://forums.polyloop.net/showthread.php?p=202696#post202696
http://modo.logy.fr/index.php/forum/15-Discussions-diverses/10268-Pour-fans-de-Moi3D-Beta01-V3-%29?limit=10&start=10
http://www.pushpullbar.com/forums/showthread.php?4216-Moment-of-Inspiration/page11
http://forums.sketchucation.com/viewtopic.php?f=51&t=35686&start=45
http://www.3d-station-forum.com/forum/index.php?topic=18430.msg340154#msg340154
http://frenchcinema4d.fr/showthread.php?56061-Mod%E9lise-avec-MoI-%28&p=968350#post968350
http://www.3dvf.com/forum/3dvf/Logiciels3D/Autres-2/3d-beta1-sorti-sujet_1141_1.htm#t6665
http://forum.cfsl.net/viewtopic.php?f=52&t=33423&p=1238858#p1238858
http://forums.cgsociety.org/showthread.php?p=7102249#post7102248
9 Sep 2011   [#14] In reply to [#1]
OUTSTANDING! Thanks for sharing!
9 Sep 2011   [#15] In reply to [#1]
Hi Mauro - the part of your Sunglasses steps here where you applied the lightbulb gave me an idea for a new "projective" mode for Flow which I've been working on for the past week here, and it seems like it is turning out pretty well.
It will be an additional mode for Flow where instead of stretching from surface to surface it instead beams the object onto a target by projecting along the base surface's normals.
Here's an example (here using some shapes that Felix posted previously):
So the position and angle of the base plane are significant with this mode, since the object is projected along the surface normals of the base plane.
Here's another example:
The other interesting thing about this mode is that it can work to project across joined surfaces instead of only on a single surface target like the current Flow, the surfaces do need to be smooth to each other though or else you'll get a messy result.
It should be good for applying stuff like decals where you want to apply it to a more localized area rather than having it stretch across the full surface.
projective_flow1.jpg  projective_flow2.jpg  projective_flow3.jpg  projective_flow4.jpg
9 Sep 2011   [#16] In reply to [#1]
Here's another example of projective flow:
You can see the more localized effect there rather than stretching along the full target surface like the other flow mode does.
It also helps to make for less distortion, as long as the target surface doesn't curl away at too sharp of an angle from the projection.
9 Sep 2011   [#17]
Does this yet using with the beta 1 V3 or for the next release?
10 Sep 2011   [#18] In reply to [#16]
Very nice addition Michael, a more predictive control over Flow.
Message 4471.19 was deleted
10 Sep 2011   [#20]
Neat! So to make a design that had a lot of repetitive elements (like your star example, but with many more stars), would you array the stars in space around the base object, then "project-flow" them all at once?
Ed
10 Sep 2011   [#21] In reply to [#20]
Very nice Michael... :-))
Peace,
Rich_Art. ;)
10 Sep 2011   [#22] In reply to [#17]
This is a new option that will be in the next v3 beta.
10 Sep 2011   [#23] In reply to [#20]
Hi Ed,
You would make copies of the star and base plane, but currently you would need to apply them with multiple runs of the Flow command - right now at least it projects by one base plane at a time.
I'm not quite sure yet how to make it work more in a batch type mode.
9 Nov 2021   [#24]
Seems Mauro has made a video! ;)
9 Nov 2021   [#25] In reply to [#24]
Yes :)
I moved from Vimeo to YT
I just restyled the video, It is 9 years old :)
M
9 Nov 2021   [#26] In reply to [#25]
Subscribed to your YT channel. Hope to see more Mauro!
