Show messages:  1-18  …  899-918  919-938  939-958  959-978  979-998  999-1018  1019-1038  …  3119
13 May 2021   [#959]
MagicaVoxel doodling...
13 May 2021   [#960] In reply to [#959]
Very cool!
20 May 2021   [#961]
A cool free one!
20 May 2021   [#962]
Classical relax with the free MagicaVoxel! :)
20 May 2021   [#963]
SDF Edit has been released, and renamed to MagicaCSG:
http://ephtracy.github.io/index.html?page=magicacsg
More info and demo videos here:
https://blenderartists.org/t/new-signed-distance-fields-editor-by-the-creator-of-magicavoxel/1293075
Regards,
Metin
20 May 2021   [#964] In reply to [#963]
Excellent!
21 May 2021   [#965]
A new concept of modeling object by object to manage! :)
21 May 2021   [#966]
Let's go first crazy with MagicaCSG and my little prog that you can use! https://editor.p5js.org/Pilou/full/y1GHaBqyT
Just make a transparent png image with some of your modules and drag and drop them !
A transparent PNG image with anything but also some free space!
and of course can be used with any moi3D objects! (my little prog not the MagicaCSG :)
And surprise following your inside image! 8-)
21 May 2021   [#967]
Yeah, MagicaCSG is a lot of fun!
21 May 2021   [#968]
Gizmo rotate the object material itself! So hallucinated forms! Maybe a little training is necessary for master that! :)
Artists are in the starting blocks! :)
By ManXiaoMisaki
22 May 2021   [#969]
Astonished Magicavoxel free Kitbash for SF & CyberPunk (video of use inside the site)
https://gumroad.com/l/voxelkitbash
By Paul Riehle
23 May 2021   [#970] In reply to [#969]
Amazing model!
Mik
25 May 2021   [#971]
Free Kitbash above by Hifoo/ Paul Riehle is a killer one! keys 9,0,= a delight! (for free MagicaVoxel https://ephtracy.github.io
here following a same element rotated, positive, negative etc...
25 May 2021   [#972]
How to simulate a "stereographic" 3D model from the MagicaVoxel rendering engine?
Retrieve the "straight" OBJ object from Magica, better to clean up the coplanar faces with your favorite 3D program, project it onto the volume of your choice (here a half-sphere). The object will then have a thickness, and will be completely "3D Printable". It is funny to see that a "curvated" building becomes curiously a spaceship!
Once again the free"Kitbash" free is full of infinite richness of possibilities! Bravo to Paul Riehle / hifoo!
25 May 2021   [#973] In reply to [#972]
Beautiful!
25 May 2021   [#974] In reply to [#973]
Very inspirative!
Mik
26 May 2021   [#975]
Cool use of Blender and other true gems!
1 Jun 2021   [#976]
Infinite textures from free JsPlacement (can of course be used for Moi Objects) https://windmillart.net/?p=jsplacement
Then free FileToVvox by Zarbuz https://github.com/Zarbuz/FileToVox & render free MagicaVoxel https://ephtracy.github.io
2 Jun 2021   [#977]
3 Jun 2021   [#978]
From free Jsplacement & free filetox by Zarbuz for the free MagicaVoxel...
you can export obj format so possible import inside moi! ;)
