Show messages:  1-7  …  868-887  888-907  908-927  928-947  948-967  968-987  988-1007  …  3108-3119
13 Jan 2021   [#928]
Astonished!
https://toonme.com
26 Jan 2021   [#929]
Becomes free!
https://www.gravitysketch.com/blog/articles/gravity-sketch-will-soon-be-free/
Export FBX, IGES ;)
27 Jan 2021   [#930]
This one becomes Open Source!
https://opensource.googleblog.com/2021/01/the-future-of-tilt-brush.html
15 Feb 2021   [#931]
Abstract Landscape by Taron with its Vervette SandBox above! ;)
2 Mar 2021   [#932]
Totally amazing!
7 Mar 2021   [#933]
quote:
This is an online edition of the classic technical reference Five Hundred and Seven Mechanical Movements by Henry T. Brown. This site contains the original illustrations and text from the 21st edition of the book, published in 1908. It also includes animated versions of the illustrations, and occasional notes by the webmaster. The animated versions are not yet complete. They are identified by color images in the thumbnail pages. To keep up with developments on this site, use the Twitter Follow or Facebook Subscribe links below.
http://507movements.com
7 Mar 2021   [#934]
quote:
Welcome to Animated Engines! Here you’ll find animated illustrations that explain the inner workings of a variety of steam, Stirling, and internal combustion engines.
http://animatedengines.com
8 Mar 2021   [#935] In reply to [#934]
Excellent and a cool prog for adapt them!
Free Algodoo! ;)
http://www.algodoo.com
30 Mar 2021   [#936]
https://plasmo.ai/ neat approach !
30 Mar 2021   [#937] In reply to [#936]
Super cool!
30 Mar 2021   [#938]
Always free for primo loaders of 2019 ;)
https://twinmotionhelp.epicgames.com/s/article/Twinmotion-2021-1-Release-Notes
30 Mar 2021   [#939]
Absolutly fascinating!
https://virtualcreatures.github.io
I put here the more artistic!
Lenia : can be played online - a little special! : https://chakazul.github.io/Lenia/JavaScript/Lenia.html
By bert Chan
7 Apr 2021   [#940]
10 Apr 2021   [#941]
Polygons on steroids! :)
21 Apr 2021   [#942]
Another funny one! More you draw more it's free!
25 Apr 2021   [#943]
Free MagicaVoxel https://ephtracy.github.io/
no more need to enter shader inside the Console : All by the UI!
Try with the shaders by Mode_vis! https://gumroad.com/mode_vis?sort=newest
That works like a charm!
My test of a FerroFluid! :)
26 Apr 2021   [#944]
Animation from your videos!
And it's free!
28 Apr 2021   [#945]
Made with Blender!!!
28 Apr 2021   [#946]
Make volumes for 3D Printing in the Free MagicaVoxel!
Pattern is done in Magica, you can import an OBJ objects from Moi by Drag & Drop or build anything with Magica.
Fractal classic function but...
Matrix is filled with any cubical volumes. Press Fractal for replace all cubes by the Pattern!
Unitary Matrix maxi : 256 256 256
Each cube is now the Pattern but with only color! Press Tex for have all colors' Pattern on each cube!
It's here that you can make anything you want like select "Green" color and erase it for have only a wire buildable for the 3D Print!
For Render in MagicaVoxel ( F1) maybe you can see nothing...
it's because in Mode World (Tab) volumes are under the Ground! Just up them!
4 May 2021   [#947]
MagicaVoxel again (free)
A Ferro-Fluid https://en.wikipedia.org/wiki/Ferrofluid
With crazzy Shaders by Mode_vis https://gumroad.com/mode_vis?sort=newest
