Show messages:  1-12  …  813-832  833-852  853-872  873-892  893-912  913-932  933-952  …  3113-3119
2 Jul 2020   [#873]
So cute and astonished!
2 Jul 2020   [#874] In reply to [#873]
nice !
3 Jul 2020   [#875]
Play on line reduced version https://oskarstalberg.com/game/house/index.html
Here with a planet https://oskarstalberg.com/game/planet/planet.html
And for all understand
Terrific! Seems number of levels are infinite! :)
Not the map hoppefuly :)
3 Jul 2020   [#876]
Totally addictive and regressive! :)
4 Jul 2020   [#877]
Tensegrity you have to see it to believe it! Amazing!
5 Jul 2020   [#878]
A new very cool Plugin for SketchUp!
https://alexschreyer.net/projects/scale-by-image-equation-tools-extension-for-sketchup/
7 Jul 2020   [#879]
About tensigrity above :)
The creator of that! R.Buckminster Fuller
The wires on the sides play the role of shrouds on a boat!
They prevent the top piece from falling from one side or the other!
You can understand it better if you imagine this!
The wire becomes "solid"! The side shrouds become useless!
It is the bottom piece that "holds" the top piece!
8 Jul 2020   [#880]
I made a suggestion to Meshlab to add an option to reverse the wheel mouse direction. They accepted it and it is in version 2020.07. https://www.meshlab.net/
8 Jul 2020   [#881]
21 Jul 2020   [#882]
Amazing thing!
21 Jul 2020   [#883]
Free!
30 Jul 2020   [#884]
Amazing and free!
https://cascadeur.com
6 Aug 2020   [#885]
https://www.daz3d.com/flowscape-tutorial
tuto flowscape by the developer Chris Hunter ( 1 h 35 min )
sympathique créateur du sympathique Flowscape ... entre 2 séances de Vue xtream ou Lumion ... ça détend ;)
6 Aug 2020   [#886] In reply to [#885]
Cool cela complètera mon manuel! :) VF
https://moiscript.weebly.com/flowscape.html
Flowscape is true gem! I am a big fan of it!
see https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.791 and following! :)
13 Aug 2020   [#887]
Sorry not 3D but can be useful for musicians! :) (Free)
14 Aug 2020   [#888]
Materialize -- An AMAZING Free Texture Map Generating Tool
download here
https://www.boundingboxsoftware.com/materialize/index.php
how to here
https://www.youtube.com/watch?v=vtnJToPxBNo
excellent FREE PBR material creator !
15 Aug 2020   [#889] In reply to [#888]
Great finding: very many thanks !
15 Aug 2020   [#890]
http://jenn3d.org/
jenn3d is an old freeware ( jenn3d_win_2013_06_20.zip ) .. it generates a lot of geometric structures some very nice ! some very complex !
works on any windows - the diameter of the elements can be reduced or enlarged
easy to use - the 3d file is named " jenn_export.stl " ... no choice ... so don't forget to rename the several models
01 jenn 02 jenn etc ... STL ... convert in .obj ( for example in Meshlab )
the parts are not joined so it's easy to delete unwanted tubes or spheres to keep interesting structures
examples imported in Max ... and with a remeshing in quads, the import in Moi is very quick
22 Aug 2020   [#891]
Free models, and searching:
https://thangs.com/
Format?
The article:
https://www.3dnatives.com/en/thangs-search-engine-for-3d-models-200820205/
22 Aug 2020   [#892] In reply to [#891]
Seems 3dm or OBJ are not on board! :)
Supported file extensions include .3dxml .CATPart .dwg .dxf .iges .igs .ipt .jt .model .par .prt .sab .sat .sldprt .step .stl .stp .vda .x_b .x_t .xcgm .xml .
