Show messages:  1-18  …  699-718  719-738  739-758  759-778  779-798  799-818  819-838  …  3119
15 Oct 2019   [#759]
From Moi to the free Twinmotion in using the new interface by Wayne! ;)
here _sSplit _SBridge _Subdiv9
Inset
16 Oct 2019   [#760]
Careful when you import Moi Object inside Twinmotion Scale is generally necessary
as you have several colors as material you must careful to selected all colors for scale the entiere object!
Else you can imagine that something don't works!
17 Oct 2019   [#761]
17 Oct 2019   [#762] In reply to [#761]
XD
23 Oct 2019   [#763]
Free Standalone!
https://rodzilla.itch.io/material-maker
23 Oct 2019   [#764]
By Ephtracy the Autor of MagicaVoxel (so same ergonomy for the render! :)
Aerialod (free)
An interactive path tracing renderer for height maps.
support rendering height maps of size up to 16384^2.
support importing and exporting 8-bit and 16-bit png images
I am waiting the Strereographic projection (buttons are existing! ;)
4 Nov 2019   [#765]
HorseBreakdown from mehmet fatih usta on Vimeo.
6 Nov 2019   [#766]
ZBrush 2020 (12 November)
7 Nov 2019   [#767]
All videos by Aujik are crazzy!
8 Nov 2019   [#768] In reply to [#767]
A-M-A-Z-I-N-G !!!
Thanks!
8 Nov 2019   [#769]
Not sure that is an easy program :) (it has an ELEPHANT under steroïds :)
8 Nov 2019   [#770] In reply to [#769]
"Not sure that is an easy program"
A very complex one, indeed!
8 Nov 2019   [#771]
Cool!
8 Nov 2019   [#772]
Chaos by Pixero
a free Plugin for SketchUp :)
I suppose that we can make the same in Moi with the pinky ELEPHANT by Max Smirnov! ;)
Recall me a very fun free prog for make crazzy images with only 3 Keys!!! in 3 seconds!
http://www.chaoscope.org
8 Nov 2019   [#773]
JSplacement
https://windmillart.net/?p=jsplacement Free
For make maps of displacement 8192*8192 or any automatic "square" textures...
Works like a charm with Aerialod above! (16 384 * 16 384)
I am not sure that PLY format only existing for the moment is very useful because file size result is 2 - 3 gigas!
for the little one following!
I suppose that in the future there will be a more simplified OBJ result!
9 Nov 2019   [#774]
No headache ...in 3 seconds...zap! :)
10 Nov 2019   [#775] In reply to [#774]
Cool! Thanks!
18 Nov 2019   [#776]
MagicaVoxel Resolution becomes crazzy with the Zarbuz Plugin!
By Zarbuz
my try with the image above before try with big image :)
18 Nov 2019   [#777] In reply to [#776]
Thanks Pilou!
This plugin is very interesting :)
22 Nov 2019   [#778]
What a monster! :)
