Show messages:  1-8  …  629-648  649-668  669-688  689-708  709-728  729-748  749-768  …  3109-3119
19 Apr 2019   [#689] In reply to [#685]
The SPH videos are quite impressive indeed. They remind me of a free Blender add-on called Molecular Add-on:
Regards,
Metin
visualization • illustration • animation • 3D design — metinseven.nl
19 Apr 2019   [#690] In reply to [#689]
Yes particles are magical things!
19 Apr 2019   [#691]
and of course ;)
28 Apr 2019   [#692]
A free clouds generator!
https://github.com/turtletooth/kumoworksportable
1 May 2019   [#693]
Free BricsCad Shape https://www.bricsys.com/en-intl/shape/
Funny one but you must make a little training! :)
Direct modeling is cool and Fillet, Chamfer, Boolean some strong!
Moi to Shape is easy by SKP format inbetweener
Render of course SimLab Composer lite (free)
PS If you export as DAE to SKetchUP, seems there is a bug even both programs are in unity meter!
You must scale * 1000 in Shape before the exportation!
else you will have some faces no filled!
3 May 2019   [#694]
For Demoparties fan! :)
5 May 2019   [#695] In reply to [#694]
Ah, the good old demo scene. My friends and I created a number of demos for the Commodore Amiga back in the late 1980s and early 1990s.
9 May 2019   [#696]
@ Marco : We can now directly transform a "big" format OBJ directly in .vox for MagicaVoxel! ;)
with the Zarbuz plugin : https://github.com/Zarbuz/FileToVox/releases
from Squarries http://www.fractal-recursions.com/files/mech0025.html
With the old free Chaoscope http://www.chaoscope.org
9 May 2019   [#697] In reply to [#696]
Wow!!!
Very cool stuff!
I just pinned this post :)
10 May 2019   [#698]
Funny to think that is a little part of the strange attractor above! :)
10 May 2019   [#699]
With free BricsCad Shape! (function Quick draw) :)
Draw 2-3 volumes Make a Snapshot - dupplicate / rotate / resize the few volumes on a PNG transparent background Image and drag & drop the result on my own little tricky free prog https://editor.p5js.org/Pilou/full/y1GHaBqyT
Put it inside MagicaVoxel + File2Vox by Zarbuz et voilà! :)
10 May 2019   [#700] In reply to [#699]
The last one is AMAZING!
10 May 2019   [#701]
Test with an image of Moi3D objects :)
12 May 2019   [#702]
Rocket 3F as Polygonal modeling is always pleasant to use!
inside MagicaVoxel for exploring some infinite worlds! ...
20 May 2019   [#703]
As you can run Moi onAndroïd tablett :) see https://moi3d.com/forum/index.php?webtag=MOI&msg=9374.1
2 cool programs in direct Tablett (so speedy max)
And this last one (different than the direct viewer - https://play.google.com/store/apps/details?id=com.autodesk.fusion tested working like a charm)
Not yet tested the following...on Tablett or in local computer
23 May 2019   [#704]
If you gothere you will see how was resolved my problem of Moi on Android Tablett! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9374.13
This is made (5 seconds) with these free https://www.escapemotions.com/experiments.php by Peter Blaskovic
24 May 2019   [#705]
Then imported with File2 vox by Zarbuz inside MagicaVoxel
Infinite exploration!
And of course you can export OBJ for the Free TwinMotion!  :)
24 May 2019   [#706] In reply to [#705]
Wonderful!
28 May 2019   [#707]
With the free Verve!
29 May 2019   [#708]
with free http://www.picturetopeople.org
