600-619
620-639
640-659
660-679
680-699
700-719
720-739
But I must make some tests more!
> MagicaVoxel create 3 files OBJ, Mtl and PNG file : this last one is one horizontal line of the 256 or less colors used !
There isn't anything in the OBJ format spec that says that there should be such a bitmap file created along with the .obj file. It's probably something unique to MagicaVoxel.
Seems i have dreamed...seems the 2 files OBJ MTL are sufficient...from MOI!
Here with 2 colors that's works with only OBJ + MTL!
Ok this time that must works! thx to Makio!
https://twitter.com/makio135
Just put an image PNG with a transparent background (empty spaces)
Full Screen
https://editor.p5js.org/Pilou/full/y1GHaBqyT
https://editor.p5js.org/Pilou/sketches/y1GHaBqyT directly in the editor (you can modify it if you are not cardiac! :)
or put your image here by Drag & Drop on your screen : save it as you want with Right Click on the image
Have fun! You can put any number of images you want!
etc...
and of course with any moi objects' image! ;) Flipper's buttons of the golden age ? :)
Magica here ;)
Wonderful!
VIDEO
https://www.nvidia.com/en-us/deep-learning-ai/ Infos on AI from NVidia!
Test Play Ground in direct online...and other wonders!
https://www.nvidia.com/en-us/research/ai-playground/
VIDEO
I have tested the IA on clear foreground : can be some better but it's the beginning! :)
this technique is not so new (Image Inpainting)
I can do this also with Photoshop CC 2019 on 3D models
with textures applied, to get rid, for example, of seams. ;-)
A funny workflow :)
Use the Free Bricsys Shape
https://www.bricsys.com/en-us/shape/ (a tricky ergonomy - not sure i all understand but...
you can take also Moi of course! ;)
Make a little drawing (10 seconds) with the Quick Draw function (first icon :)
Take a Snap Shot image - make a PNG image with transparent background (some white surfaces) with any 2D Prog
And Drag & Drop the result on my little prog some posts above!
https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.663
Right Click Save image and voilà! :)
Of course that is infinite because you can draw anything you want! : Only your imagination can limit the process! :)
A very famous city! ;) (MagicVoxel)
Wow, great....
Always amazing!
VIDEO
G'MIC
https://gmic.eu
Add 482 Image Filters to: GIMP, Krita, Paint.net...
Aespecially G'MIC/Artistic/Stylise who avoid to go to these on line deep learning progs! ;)
https://www.ostagram.me
https://dreamscopeapp.com /
https://deepdreamgenerator.com /
VIDEO
Cool Pilou!
Here are two self portraits which uses reaction diffusion.
You can do this with Ready, KPT Reaction Filter or reactor.exe
and then one must make a color mesh of it to render it.
Very convincing!
Yes, i think so too.
Working on a MoI vector / NURBS version …
Wish me luck that I can later make a nice mesh out of it.
Otherwise I have a nice vector technique for T-Shirt or Poster prints … :-)
Finally finished the drawing and creation of the surfaces.
Was quite a bit of work, but I enjoyed it due to the fact
that MoI is such a cool and fun app.
So you can make like JR! ;)
https://www.jr-art.net
600-619
620-639
640-659
660-679
680-699
700-719
720-739
