Show messages:  1-18  …  599-618  619-638  639-658  659-678  679-698  699-718  719-738  …  3119
6 Mar 2019   [#659] In reply to [#658]
<< What PNG file would you expect to be generated from MoI's OBJ export?
Colors Style of works used during the modelisation inside MOi...
like following (not exactly the same because i have not more the modified object (at ends' arm/ hands)
But i must continue to investigate!
MagicaVoxel create 3 files OBJ, Mtl and PNG file : this last one is one horizontal line of the 256 or less colors used !
It's this png file that i have artificially add inside the 2 files created by MOi and magically object will have colors!
Mixamo ask a zip file of these 3 files!
Here result with the artificially Moi 3 Files zipped :)
6 Mar 2019   [#660]
But I must make some tests more!
6 Mar 2019   [#661] In reply to [#659]
There isn't anything in the OBJ format spec that says that there should be such a bitmap file created along with the .obj file. It's probably something unique to MagicaVoxel.
6 Mar 2019   [#662] In reply to [#661]
Seems i have dreamed...seems the 2 files OBJ MTL are sufficient...from MOI!
Here with 2 colors that's works with only OBJ + MTL!
14 Mar 2019   [#663]
Ok this time that must works! thx to Makio! https://twitter.com/makio135
Just put an image PNG with a transparent background (empty spaces)
Full Screen https://editor.p5js.org/Pilou/full/y1GHaBqyT
https://editor.p5js.org/Pilou/sketches/y1GHaBqyT directly in the editor (you can modify it if you are not cardiac! :)
or put your image here by Drag & Drop on your screen : save it as you want with Right Click on the image
Have fun! You can put any number of images you want!
etc...
15 Mar 2019   [#664]
and of course with any moi objects' image! ;) Flipper's buttons of the golden age ? :)
Magica here ;)
15 Mar 2019   [#665]
17 Mar 2019   [#666]
Wonderful!
21 Mar 2019   [#667]
https://www.nvidia.com/en-us/deep-learning-ai/ Infos on AI from NVidia!
Test Play Ground in direct online...and other wonders!
https://www.nvidia.com/en-us/research/ai-playground/
I have tested the IA on clear foreground : can be some better but it's the beginning! :)
21 Mar 2019   [#668]
this technique is not so new (Image Inpainting)
I can do this also with Photoshop CC 2019 on 3D models
with textures applied, to get rid, for example, of seams. ;-)
22 Mar 2019   [#669]
A funny workflow :)
Use the Free Bricsys Shape https://www.bricsys.com/en-us/shape/ (a tricky ergonomy - not sure i all understand but...
you can take also Moi of course! ;)
Make a little drawing (10 seconds) with the Quick Draw function (first icon :)
Take a Snap Shot image - make a PNG image with transparent background (some white surfaces) with any 2D Prog
And Drag & Drop the result on my little prog some posts above! https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.663
Right Click Save image and voilà! :)
Of course that is infinite because you can draw anything you want! : Only your imagination can limit the process! :)
27 Mar 2019   [#670]
A very famous city! ;) (MagicVoxel)
28 Mar 2019   [#671]
Wow, great....
3 Apr 2019   [#672]
Always amazing!
5 Apr 2019   [#673]
G'MIC https://gmic.eu
Add 482 Image Filters to: GIMP, Krita, Paint.net...
Aespecially G'MIC/Artistic/Stylise who avoid to go to these on line deep learning progs! ;)
https://www.ostagram.me
https://dreamscopeapp.com /
https://deepdreamgenerator.com/
5 Apr 2019   [#674]
Cool Pilou!
Here are two self portraits which uses reaction diffusion.
You can do this with Ready, KPT Reaction Filter or reactor.exe
and then one must make a color mesh of it to render it.
me1
me2
5 Apr 2019   [#675]
Very convincing!
5 Apr 2019   [#676]
Yes, i think so too.
6 Apr 2019   [#677]
Working on a MoI vector / NURBS version …
Wish me luck that I can later make a nice mesh out of it.
Otherwise I have a nice vector technique for T-Shirt or Poster prints … :-)
me-moi-reaction-diffusion
6 Apr 2019   [#678]
Finally finished the drawing and creation of the surfaces.
Was quite a bit of work, but I enjoyed it due to the fact
that MoI is such a cool and fun app.
me-final-drawing
