Show messages:  1-9  …  590-609  610-629  630-649  650-669  670-689  690-709  710-729  …  3110-3119
2 Mar 2019   [#650] In reply to [#649]
No problem! ;)
There are some others over the world! :)
2 Mar 2019   [#651]
Some test with the Gaea above
Very nodal :)
But result is here not a volume but a simple surface! Very heavy : the OBJ = 50 megas!
I must something for have a "Volume solid"
Not so evident to have the OBJ : it's with the Button Build who put the result Mesher.OBJ in the folder Builds!
OBJ file result : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/mesher.obj
Must be surelly decimate!
With the free MeshMixer (no decimated)
A friend of me made a render with C4D
By YPY
3 Mar 2019   [#652]
A new folish thing!
I started out a French site version of GAEA ! :)
https://gaeafr.weebly.com
The author is very prolific! http://daxpandhi.com
4 Mar 2019   [#653]
Another cool trick! ;)
With the free Mixamo you can make some funny animations like a motion capture!
https://www.mixamo.com
Here inside Blender...(fbx no time to play with that now)
Jean-Paul Gaultier as accessories  :D
Next time animation of any volumes....
5 Mar 2019   [#654] In reply to [#653]
With a Moi volume! :)
You have just to drag and drop your Moi volumes OBJ inside the Mixamo screen!
5 Mar 2019   [#655] In reply to [#654]
AHAHAHAHA :)
So funny!
5 Mar 2019   [#656] In reply to [#655]
And in colors!
Make a zip of the 3 Files : OBJ, MTL, PNG then Press Button Upload character!
No gap between volumes, neutral T position, better to be on origine, different colors...
(I must find something for Moi because seems colors of volumes are not take in compt! ???
Here with Magicavoxel Volumes! ;)
6 Mar 2019   [#657]
Seems for Moi volumes you must add artificially a PNG file who is not generated with the OBJ export! ???
Don't take care of the green background : it's the reccord who must be regulated! :)
6 Mar 2019   [#658] In reply to [#657]
What PNG file would you expect to be generated from MoI's OBJ export?
MoI does not export texture mapped materials to the OBJ file so there isn't anywhere that a bitmap file like a PNG file would fit.
6 Mar 2019   [#659] In reply to [#658]
<< What PNG file would you expect to be generated from MoI's OBJ export?
Colors Style of works used during the modelisation inside MOi...
like following (not exactly the same because i have not more the modified object (at ends' arm/ hands)
But i must continue to investigate!
MagicaVoxel create 3 files OBJ, Mtl and PNG file : this last one is one horizontal line of the 256 or less colors used !
It's this png file that i have artificially add inside the 2 files created by MOi and magically object will have colors!
Mixamo ask a zip file of these 3 files!
Here result with the artificially Moi 3 Files zipped :)
6 Mar 2019   [#660]
But I must make some tests more!
6 Mar 2019   [#661] In reply to [#659]
There isn't anything in the OBJ format spec that says that there should be such a bitmap file created along with the .obj file. It's probably something unique to MagicaVoxel.
6 Mar 2019   [#662] In reply to [#661]
Seems i have dreamed...seems the 2 files OBJ MTL are sufficient...from MOI!
Here with 2 colors that's works with only OBJ + MTL!
14 Mar 2019   [#663]
Ok this time that must works! thx to Makio! https://twitter.com/makio135
Just put an image PNG with a transparent background (empty spaces)
Full Screen https://editor.p5js.org/Pilou/full/y1GHaBqyT
https://editor.p5js.org/Pilou/sketches/y1GHaBqyT directly in the editor (you can modify it if you are not cardiac! :)
or put your image here by Drag & Drop on your screen : save it as you want with Right Click on the image
Have fun! You can put any number of images you want!
etc...
15 Mar 2019   [#664]
and of course with any moi objects' image! ;) Flipper's buttons of the golden age ? :)
Magica here ;)
15 Mar 2019   [#665]
17 Mar 2019   [#666]
Wonderful!
21 Mar 2019   [#667]
https://www.nvidia.com/en-us/deep-learning-ai/ Infos on AI from NVidia!
Test Play Ground in direct online...and other wonders!
https://www.nvidia.com/en-us/research/ai-playground/
I have tested the IA on clear foreground : can be some better but it's the beginning! :)
21 Mar 2019   [#668]
this technique is not so new (Image Inpainting)
I can do this also with Photoshop CC 2019 on 3D models
with textures applied, to get rid, for example, of seams. ;-)
22 Mar 2019   [#669]
A funny workflow :)
Use the Free Bricsys Shape https://www.bricsys.com/en-us/shape/ (a tricky ergonomy - not sure i all understand but...
you can take also Moi of course! ;)
Make a little drawing (10 seconds) with the Quick Draw function (first icon :)
Take a Snap Shot image - make a PNG image with transparent background (some white surfaces) with any 2D Prog
And Drag & Drop the result on my little prog some posts above! https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.663
Right Click Save image and voilà! :)
Of course that is infinite because you can draw anything you want! : Only your imagination can limit the process! :)
