Show messages:  1-7  …  588-607  608-627  628-647  648-667  668-687  688-707  708-727  …  3108-3119
1 Mar 2019   [#648]
It was an easy prog or not ?
And have you it always somewhere or it is an authorized prog ?
2 Mar 2019   [#649]
It was/is software for researchers, so you must know what to do and then use other
programs (like Houdini) to get the desired result. There are many steps involved,
so it would require a tutorial.
But since the program was taken of the Internet, it makes no sense to write
a tutorial, because i don't know if it is allowed to distribute the software ...
I think also it is no longer available, because professional Designers like
to use such software for free and then doing paid gigs with that and without
mentioning the author. This happens very often, unfortunately.
2 Mar 2019   [#650] In reply to [#649]
No problem! ;)
There are some others over the world! :)
2 Mar 2019   [#651]
Some test with the Gaea above
Very nodal :)
But result is here not a volume but a simple surface! Very heavy : the OBJ = 50 megas!
I must something for have a "Volume solid"
Not so evident to have the OBJ : it's with the Button Build who put the result Mesher.OBJ in the folder Builds!
OBJ file result : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/mesher.obj
Must be surelly decimate!
With the free MeshMixer (no decimated)
A friend of me made a render with C4D
By YPY
3 Mar 2019   [#652]
A new folish thing!
I started out a French site version of GAEA ! :)
https://gaeafr.weebly.com
The author is very prolific! http://daxpandhi.com
4 Mar 2019   [#653]
Another cool trick! ;)
With the free Mixamo you can make some funny animations like a motion capture!
https://www.mixamo.com
Here inside Blender...(fbx no time to play with that now)
Jean-Paul Gaultier as accessories  :D
Next time animation of any volumes....
5 Mar 2019   [#654] In reply to [#653]
With a Moi volume! :)
You have just to drag and drop your Moi volumes OBJ inside the Mixamo screen!
5 Mar 2019   [#655] In reply to [#654]
AHAHAHAHA :)
So funny!
5 Mar 2019   [#656] In reply to [#655]
And in colors!
Make a zip of the 3 Files : OBJ, MTL, PNG then Press Button Upload character!
No gap between volumes, neutral T position, better to be on origine, different colors...
(I must find something for Moi because seems colors of volumes are not take in compt! ???
Here with Magicavoxel Volumes! ;)
6 Mar 2019   [#657]
Seems for Moi volumes you must add artificially a PNG file who is not generated with the OBJ export! ???
Don't take care of the green background : it's the reccord who must be regulated! :)
6 Mar 2019   [#658] In reply to [#657]
What PNG file would you expect to be generated from MoI's OBJ export?
MoI does not export texture mapped materials to the OBJ file so there isn't anywhere that a bitmap file like a PNG file would fit.
6 Mar 2019   [#659] In reply to [#658]
<< What PNG file would you expect to be generated from MoI's OBJ export?
Colors Style of works used during the modelisation inside MOi...
like following (not exactly the same because i have not more the modified object (at ends' arm/ hands)
But i must continue to investigate!
MagicaVoxel create 3 files OBJ, Mtl and PNG file : this last one is one horizontal line of the 256 or less colors used !
It's this png file that i have artificially add inside the 2 files created by MOi and magically object will have colors!
Mixamo ask a zip file of these 3 files!
Here result with the artificially Moi 3 Files zipped :)
6 Mar 2019   [#660]
But I must make some tests more!
6 Mar 2019   [#661] In reply to [#659]
There isn't anything in the OBJ format spec that says that there should be such a bitmap file created along with the .obj file. It's probably something unique to MagicaVoxel.
6 Mar 2019   [#662] In reply to [#661]
Seems i have dreamed...seems the 2 files OBJ MTL are sufficient...from MOI!
Here with 2 colors that's works with only OBJ + MTL!
14 Mar 2019   [#663]
Ok this time that must works! thx to Makio! https://twitter.com/makio135
Just put an image PNG with a transparent background (empty spaces)
Full Screen https://editor.p5js.org/Pilou/full/y1GHaBqyT
https://editor.p5js.org/Pilou/sketches/y1GHaBqyT directly in the editor (you can modify it if you are not cardiac! :)
or put your image here by Drag & Drop on your screen : save it as you want with Right Click on the image
Have fun! You can put any number of images you want!
etc...
15 Mar 2019   [#664]
and of course with any moi objects' image! ;) Flipper's buttons of the golden age ? :)
Magica here ;)
15 Mar 2019   [#665]
17 Mar 2019   [#666]
Wonderful!
21 Mar 2019   [#667]
https://www.nvidia.com/en-us/deep-learning-ai/ Infos on AI from NVidia!
Test Play Ground in direct online...and other wonders!
https://www.nvidia.com/en-us/research/ai-playground/
I have tested the IA on clear foreground : can be some better but it's the beginning! :)
