Show messages:  1-10  …  571-590  591-610  611-630  631-650  651-670  671-690  691-710  …  3111-3119
10 Feb 2019   [#631]
With a little piece of the above image and a triple loops of Processing :)
I believe that you can change anything you want aespecially t between 1 - 50, the coef of k 1 - 5 etc...
Tell me if that work for you in direct on the fly ! Press the black triangle inside the yellow disc!
Then change the code...
A cool thing that this Web Editor!
https://editor.p5js.org/Pilou/sketches/PE_HwNoXH
10 Feb 2019   [#632] In reply to [#631]
Interesting...
@You : "...Tell me if that work for you..."
Yes! It works :)
10 Feb 2019   [#633] In reply to [#632]
Cool! :)
Else a meta animation because the start image is the image above! :)
12 Feb 2019   [#634]
Test compression...
13 Feb 2019   [#635]
A meta thing because it's the 72 images of an animation posted last week! :)
A possible fixed image
A close-up somewhere...walking is infinited! :)
brother...! :)
14 Feb 2019   [#636] In reply to [#635]
I like especially the penultimate images.
Looks like stones.
Beautiful!
14 Feb 2019   [#637]
In SketchUp Make 2017 (free)
14 Feb 2019   [#638]
Blue balls...
27 Feb 2019   [#639]
https://quadspinner.com/Gaea
Limited in 1K render for free but result can be used commercially!
28 Feb 2019   [#640]
Magic!
28 Feb 2019   [#641] In reply to [#640]
Wonderful!!
Thanks!
28 Feb 2019   [#642]
Nostalgia :)
A funny thing in what I participated with a friend ten years ago! ;)
https://www.mindomo.com/fr/mindmap/logiciels-3d-9b90f007d13a9a2a1b83e298627d1574
You can Zoom, Move etc...and click on the final arborescence for details :)
Not sure that Moi was yet present...Yes it was!!! :)
Mindomo in free has 3 maps possible! ;)
A cool concept! https://www.mindomo.com
Maybe I will remake one for free progs! :)
1 Mar 2019   [#643]
Excellent!
1 Mar 2019   [#644]
Na ja, ... results looks average. I can do that much better with GEEX (from Bruno Levy, France), Houdini or other tools and MoI. ;-)
1 Mar 2019   [#645] In reply to [#644]
Don't know Geex :) Not very images on the site!
https://gforge.inria.fr/projects/geex/
1 Mar 2019   [#646]
The source code for GEEX (Windows) is no longer available ...
All places which hosted the source code have it also no longer!
Here you can see a picture from one of the programs from GEEX:
(3rd posting from Torolf, showing the Batwing Surface.
https://www.sidefx.com/forum/topic/27610/lofi/
1 Mar 2019   [#647]
P.S my Voronoi Eggs are done, for example, with GEEX, Houdini and MoI too.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
1 Mar 2019   [#648]
It was an easy prog or not ?
And have you it always somewhere or it is an authorized prog ?
2 Mar 2019   [#649]
It was/is software for researchers, so you must know what to do and then use other
programs (like Houdini) to get the desired result. There are many steps involved,
so it would require a tutorial.
But since the program was taken of the Internet, it makes no sense to write
a tutorial, because i don't know if it is allowed to distribute the software ...
I think also it is no longer available, because professional Designers like
to use such software for free and then doing paid gigs with that and without
mentioning the author. This happens very often, unfortunately.
2 Mar 2019   [#650] In reply to [#649]
No problem! ;)
There are some others over the world! :)
