554-573
574-593
594-613
614-633
634-653
654-673
674-693
3114-3119
Just 72 images will be sufficient! Above it's just 24 images! ;)
here a test with an image 6 000 * 6 000 pixels (now you can have 12 000 * 12 000)
(i believe that must be a little deformation because the original was 960*800)
Very good!
Print it on a t-shirt ;)
Pilou, these are very dreamy. They remind me of some abstract exploration games like fract, NaissanceE or antichamber and make me want to walk around.
With a SkektchUp Make Model with a cool Plugin DeckBuilder by SDMitch :) (All is free! )
And Zarbuz tools!
I was blocked on the size by the Gif creator that i used (original was at hte double so 960 * 800 ! )
72 images this follow is 5.5 megas - 20 minutes to render at the double size (that some long for me! :)
Another test :)
(36 images) Maybe a little speedy :)
format mp4 is possible (1 /8 of a Gif size! ) but i don't know how to put it in this forum ?
with an image by Aryaneire
Test with the new mp4 video syntax of Moi! (Gif = 9.3 megas , mp4 = 538 KB)
put following line between < and>
video controls="true" src="your mp4 image adress hosted"></video
right Click on the image for have some more controls!
Really COOL!!
How funny how a simple cube can be rendered! :)
What is it? ...a mysterious object :)
maybe interesting for you too ...
https://github.com/tommyettinger/IsoVoxel
Thx but i have yet that on my site from the beginning! ;) (in French of course :)
http://moiscript.weebly.com/isovoxel.html
With a Chipp Walter crash-test mannequin model! ;)
Another test...
Right Clck on the image for more controls!
Great JOB!!!
Another test
Right Click on the image for more controls!
You walk in a luxurious jungle!
Always jungle! :)
With a little piece of the above image and a triple loops of Processing :)
I believe that you can change anything you want aespecially t between 1 - 50, the coef of k 1 - 5 etc...
Tell me if that work for you in direct on the fly ! Press the black triangle inside the yellow disc!
Then change the code...
A cool thing that this Web Editor!
https://editor.p5js.org/Pilou/sketches/PE_HwNoXH
Interesting...
@You : "...Tell me if that work for you..."
Yes! It works :)
Cool! :)
Else a meta animation because the start image is the image above! :)
554-573
574-593
594-613
614-633
634-653
654-673
674-693
3114-3119
