Show messages:  1-14  …  515-534  535-554  555-574  575-594  595-614  615-634  635-654  …  3115-3119
24 Jan 2019   [#575]
Ok works ;) (recall me "crop circles" ;)
(images are 960 * 800)
Inside with cubes = Spheres
24 Jan 2019   [#576] In reply to [#575]
WONDERFUL!!!
Very beautiful :)
Thank you so much!!
Very eye catching the second one but I didn't understand from which part of the original image is...
Could you upload also the generated .vox files?
Thanks a lot again.
So...some of my digital paintings could be useful to generate some fancy Magica stuff...
Good to know :)
24 Jan 2019   [#577]
Reload big size is not reasonnable! :)
24 Jan 2019   [#578]
No problem for the vox ;)
I unzip and post here ;) something like 75 & 137 megas zipped
Here the first : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/string_theory.zip
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/space_lollipop.zip
I try you big images but i don't see well the interest (except freeze the latop! :)
24 Jan 2019   [#579] In reply to [#578]
THANK YOU SO MUCH!! :)
The second pictures from "Space Lollipop" is amazing!
Thanks also for the .vox file Maybe one of these days I will play with it ;)
Much appreciated.
24 Jan 2019   [#580] In reply to [#578]
Thanks again :)
Very interesting elaboration!
24 Jan 2019   [#581] In reply to [#579]
A little trick : when you render such number of matrices
you must enable a button "SV" under Render Menu / Show Sampling Setting / Geometry else image will be truncated!
(Image can also truncated if number of Matricices is too big!
Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)
24 Jan 2019   [#582]
Ok I try : message "Image is too big"! So no freeze... ;)
I will search the maximum ;)
Ok maxi for your image is 1500 * 1224 ( I take 1500 maybe a little more but not many more :)
SO here 12 * 9 = 108 matricices 126 *126 *126 = 216 040 608 voxels! ;)
24 Jan 2019   [#583] In reply to [#581]
Thanks a lot for all the tech infos :)
Much appreciated again!
@You: "...Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)..."
I'm sorry.
No, for the moment I only want my original paintings on my Procreate profile and here on this forum (your elaboration of my images).
Thanks a lot for asking me. Very honest!
Thanks!
24 Jan 2019   [#584] In reply to [#583]
No problem! :)
As I made one by day (minimum) i have enough! ;)
24 Jan 2019   [#585]
Some frightening to think that person is not real!
Message 4446.586 was deleted
24 Jan 2019   [#587] In reply to [#584]
Thanks Pilou.
Clearly, if you want, feel free to play again with my previous two images in order to generate some other cool shots in Magica for this forum!
One question regarding all the tehc infos and knowledge that you have learned, with a very tough work I guess, about Magixa Voxel and how to create this kind of 3D render.
Are this info available putted all together in a some ordered way, maybe on your Moi's French site?
I hope so.
It could be very helpful to anyone who wanted to play with this kind of things, without the need to "reinvent the wheel" :)
24 Jan 2019   [#588] In reply to [#587]
Of course all is yet on my French page! ;) (in French of course! ;)
http://moiscript.weebly.com/magicavoxel.html
24 Jan 2019   [#589] In reply to [#588]
Perfect!! Thanks a lot.
No problem for French, I will use a translator to english :)
Did you include in that page also the new trick yo told me in the other post?
@You: "A little trick : when you render such number of matrices
(Image can also truncated if number of Matricices is too big!"
It's very important I think...
24 Jan 2019   [#590] In reply to [#589]
Existing! ;)
24 Jan 2019   [#591] In reply to [#590]
Perfect!
24 Jan 2019   [#592]
For study limits my avatar :)
1996 * 1676
16 * 14
No possibilities to have sphere Cylinders... i suppose too numerous matrices!
24 Jan 2019   [#593] In reply to [#592]
Wow!
25 Jan 2019   [#594]
Impressions...
