Show messages:  1-18  …  479-498  499-518  519-538  539-558  559-578  579-598  599-618  …  3119
15 Jan 2019   [#539]
How funny simple deformation XYZ Voxels can change the general aspect of something!
Here that is the maxi x deformation with the start matrix above ! That is why the render itself is very more useful!
15 Jan 2019   [#540]
So sweet! :)
16 Jan 2019   [#541]
Thx to Zarbuz for its very cool Schematic To Vox!
https://github.com/Zarbuz/SchematicToVox/releases
With my previous flower! ;)
(56 matrix 126 * 126 * 126 here! )
you can of course use any "image.png" 256 colors! I don't want imagine the possibilities!
17 Jan 2019   [#542] In reply to [#541]
Bellissimo!!
17 Jan 2019   [#543]
New 3D with old 2D image!
Revival! ;)
Amazing is not it ? ;)
17 Jan 2019   [#544] In reply to [#543]
Really!
So, MagicaVoxel is a fun!
18 Jan 2019   [#545]
18 Jan 2019   [#546] In reply to [#545]
Beautiful!
Why don't you try a different camera angle?
It could be very interesting.
Something like a little bit exaggerated field of view with the camera a very close to a section of the object and the rest of the scene blurred.
I don't know if i made myself clear :)
18 Jan 2019   [#547] In reply to [#546]
here the file. vox play with it! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/coq.vox
Message 4446.548 was deleted
18 Jan 2019   [#549] In reply to [#547]
@You "here the file. vox play with it! :)"
Thanks a lot!
But actually I don't have enough extra free time to devote to this :)
Looking forward to your new creations!
Thanks anyway.
18 Jan 2019   [#550]
New painting indeed! :)
Thx to Leonardo...& Zarbuz with it's SchematicToVox
and my little work! ;)
Inside Mona
18 Jan 2019   [#551] In reply to [#550]
18 Jan 2019   [#552] In reply to [#551]
Always Mona! ;)
20 Jan 2019   [#553] In reply to [#533]
Hi Pilou
can you tell me how you load an image inside MV.? I dindn't found any option.
Thanx
20 Jan 2019   [#554] In reply to [#553]
@Apophis: --- You right : for the present version there is no importation Menu!
So
Current use for an OBJ object or an image PNG 256 colors
Just drag and drop your image or file.obj inside the screen of MagicaVoxel! ;)
That arrives in a "single" matrix ! (max 126 * 126 * 126 )
For a special use more advancedd you must use the Zarbuz plugin SchematicToVox : https://github.com/Zarbuz/SchematicToVox/releases
and use the Command Line of Windows
That permit to import more biggest result in several matrices in the same time! So super good!
For an obj file (with minimum parameters) you must first convert your file.obj in file.schematic
http://www.drububu.com/miscellaneous/voxelizer/index.html?out=vox or https://www.tinkercad.com/
then the Command Line (Logo Windows + R (in Windows 10) ( if images .png and .schematic file are present in the same folder than SchematicToVox.exe
for example
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i objecta.schematic --o objecta (will gives you a file.vox)
For an image
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i moni.png --o moni --hm 100 --color (will gives you a file.vox)
So at the end Open file .vox inside MagicaVoxel : can be a little long depending of files size!
20 Jan 2019   [#555]
Many Thanks :-)
21 Jan 2019   [#556]
Landscape for the pleasure of the eyes! (10 $)
https://pixelforest.itch.io/flowscape
22 Jan 2019   [#557]
Speed...
22 Jan 2019   [#558] In reply to [#557]
Interesting... :)
