Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  106-125  …  3106-3117
1 Nov 2016   [#46] In reply to [#45]
Yes! Magica Voxel and its Viewer are a couple of absolutely amazing software!!
With them its possible to create very funny things and they are perfect companions for Moi!
best,
1 Nov 2016   [#47]
1 Nov 2016   [#48]
Big remark!
_importObj and Subdivide by Max Smirnov makes also the trick inside Moi!
And you have Nurbs! ;)
A little more tortured but ...its by Plugin! Always astonished by what makes this Max's Plugin!
And you can re-Subdivide some times! :) (always with Max Sudivide plugin)
31 May 2017   [#49]
1 Jun 2017   [#50] In reply to [#49]
Goxel or magicaVoxel ?
Thanks.
Marco (mkdm)
1 Jun 2017   [#51] In reply to [#50]
Previous post MagicaVoxel with SketchUp , Moi! ;)
Ps Goxel is made by a French guy! I have made the French code manual! ;)
http://moiscript.weebly.com/goxel.html
here modeling Goxel ;)
(Speedy render by the free Simlab Composer Light (max 1920 * 1080) :
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
1 Jun 2017   [#52] In reply to [#51]
Thanks a lot Pilou for the info.
Very interesting the Goxel script language manual!
Is there an English version ? (I don't speak french...)
Thanks.
1 Jun 2017   [#53] In reply to [#52]
Of course! ;)
https://blog.noctua-software.com/goxel-procedural.html
1 Jun 2017   [#54] In reply to [#53]
Thanks a lot :)
1 Jun 2017   [#55] In reply to [#53]
Great info, thanks Frenchy
Do you ever sleep? ... seems like you are always coming up with new stuff.
1 Jun 2017   [#56] In reply to [#55]
Some insomiac indeed! :)
1 Jun 2017   [#57]
Hi Pilou!
I don't remember if you have already reported this web app, but if not,
I think you'll find rather interesting these great 3d web app from Stéphane GINIER (https://stephaneginier.com/) :
https://stephaneginier.com/archive/editSDF/
https://stephaneginier.com/sculptgl/
See you!
Marco (mkdm)
2 Jun 2017   [#58] In reply to [#57]
Excellent alternative to the free Sculptris http://pixologic.com/sculptris/
2 Jun 2017   [#59]
About the incredible online https://stephaneginier.com/archive/editSDF/
you must press the button "Apply" for validate a primitive before call a new one!
2 Jun 2017   [#60] In reply to [#59]
Hi Pilou!
Yes...I already know.
But I don't know how to export in obj format. it seems that it's available only a strange "glsl" (OpenGL) format,
and I don't know how to use it in order to import the geometry data into other software.
Do you know more ?
Thanks.
Marco (mkdm)
2 Jun 2017   [#61]
Hi Pilou and everyone.
WOOOOOOOWWWW !!
Found this : https://www.shadertoy.com/
I didn't know it. it can load "glsl" Pixel Shader file generated from "https://stephaneginier.com/archive/editSDF/" !
From its About page : "Shadertoy is the first application to allow developers all over the globe to push pixels from code to screen using WebGL since 2009."
And from Stackoverflow :
"ShaderToy is a tool for writing pixel shaders."
Look at this : http://pixelshaders.com/
It seems to be very very interesting...
See you.
Marco (mkdm)
P.S. See this video article : https://www.youtube.com/watch?v=TDZMSozKZ20
2 Jun 2017   [#62]
...Also this one is a very interesting article : http://area.autodesk.com/blogs/the-3ds-max-blog/introduction-to-pixel-shaders-using-glsl
2 Jun 2017   [#63]
Hi Pilou.
Look also at this! It's awesome on my 1080 Ti : https://www.shadertoy.com/view/llK3Dy
Ciao!
2 Jun 2017   [#64]
About the json format :)
there are some converters on line http://codebeautify.org/jsonviewer
alas the xlm resulting can't be reloaded inside Kerkythea (the only one for the moment that I remember that reload xlm file! :)
I believe that with Processing (a free coding program, you can reload json file format with some library installed and save as obj)
but i want find more simple! :)
In any case json format is reloaded by the editSDF itself!
2 Jun 2017   [#65] In reply to [#63]
Shadertoy
Sure sound + crazy images & shaders that is hyper cool!
(but seems little codes must be done ? ;)
Minutes 1.06- 1.26 of your link!
