Show messages:  1-13  …  374-393  394-413  414-433  434-453  454-473  474-493  494-513  …  3094-3101
17 Oct 2018   [#434] In reply to [#433]
@Chipp
You are also in the biggest 3D French portal ! ;)
http://www.3dvf.com/actualite-24581-kit-ops-un-addon-blender-kitbashing.html
17 Oct 2018   [#435] In reply to [#434]
Wonderful! Many thanks
22 Oct 2018   [#436]
Magica buildings :)
23 Oct 2018   [#437] In reply to [#436]
Beatiful!
23 Oct 2018   [#438]
Citizen Kane! ;)
25 Oct 2018   [#439] In reply to [#432]
Hi Might be wrong place to post this but I thought it would be something mkdm would like https://www.youtube.com/watch?v=vtnJToPxBNo
Keith
25 Oct 2018   [#440]
My Magica Gallery :)
https://schmoll8.wixsite.com/magicavox
25 Oct 2018   [#441] In reply to [#439]
Thanks Keith!
Yes :) You nailed it!
Very interesting.
Asap I'm going to check it!
25 Oct 2018   [#442] In reply to [#440]
Wonderful gallery!!
I like it very much!
Bravo :)
6 Nov 2018   [#443]
Some amazing indeed!
6 Nov 2018   [#444] In reply to [#443]
Amazing things!
I can't wait to see the first final public release of Blender 2.8!
6 Nov 2018   [#445] In reply to [#444]
I believe you can use the 2.8 for test it! ;)
""These builds use the latest snippets of magic code developers write. Give the upcoming Blender 2.8x a try! Although it is absolutely not recommended for use on production environments""
6 Nov 2018   [#446] In reply to [#445]
Well...indeed, it could be a very interesting thing, but this period really no spare time to deserve to beta testing :)
Almost zero.
8 Nov 2018   [#447]
Tree Generator (free) TreeIt
http://www.evolved-software.com/treeit/treeit (7 Nov 2018)
8 Nov 2018   [#448]
Magica
How erase a line(s) with just one click ?
not works here
All functions can be pressed on the screen but very speedy with SHortCuts!
T + F + Ctrl+2 + Shift + Click
aTtach  + Face + SHIFT + Axe(s) +  Click (Shift is a trick for keep the creation mode but this invert it)
you must know the axe of it : easy because there is a tripod RVB on the bottom righ of the screen
So Axe Y [b]key on the screen or (CTRL + 2) because shortcut y is yet for other thing!
10 Nov 2018   [#449]
@stefan
there is a new plugin by Zarbuz for Magicavoxel! https://github.com/Zarbuz/SchematicToVox/releases
You can enter any image under 2048 * 2048 (4096 * 4096 will works but will be truncated)
Each matrix will be 126 * 126 *126 and image automatically trimed !
Little bad side it's line commands! So for Windows 10 : Logo windows + R and enter the following line
if your image PNG is on the same folder (and with 255 colors max - black colors up palett are error by my fault! ;)
C:\Users\Pilou\Downloads\SchematicToVox-v1.0\SchematicToVox.exe --i toto.png --o totovox
will be the same for an object format schematic (Minecraft) not yet tested but i believe there will be only one color!
my test with a little image of Verve! ;)
10 Nov 2018   [#450]
so inside Magicavoxel by Zarbuz! ;)
14 Nov 2018   [#451]
Blender becomes more human! :) (but it's 20$ )
(you can put video speed *2 )
And I beleive that "Companion" is inside the Above
14 Nov 2018   [#452]
Before an hypothetic shader in Magica :)
Curiously the shader xs height works better with color image than gry levels from this same image color :)
16 Nov 2018   [#453]
MagicaVoxel
From a Verve image :)
All image arrives automatically in several matrix
and infinite variations! :)
