Show messages:  1-17  …  318-337  338-357  358-377  378-397  398-417  418-437  438-457  …  3078-3094
5 Sep 2018   [#378]
Pixolator is always the genious artist creator of ZBrush! :)
6 Sep 2018   [#379]
... and a little portrait test. :-)
6 Sep 2018   [#380] In reply to [#379]
<<< Texture support for import would be also a nice
feuture to have, but for a free app i can't complain.
@Stefan
Hello
In Magica Voxel you can Import an Image PNG 126*126 in Edit Mode so 126*126*1 inside MagicaVoxel
(only Drag&Drop : menu Import don't yet existing)
increase after import the general matrix following that you want
Larger scene area: (-1024, +1024)
Maximum matrix is : 512x512x512, 1024x512x256 or 1024x1024x128
As you can make one Multiple Drag&Drop image(s) you can have the same than above! ;)
Just find something who trim your original image in step 126*126 pixels on some png files ;)
After import image you can of course make some landform with some extrude following matrix aceptable
The OBJ export will report all this! ;)
Here after some extrude and increased the 126*126*1 matrix
6 Sep 2018   [#381]
i'm aware of picture import, but as you can see in your example
the color palette in MagicaVoxel is very bad...
I was also refering to .obj import with color textures, which i have
not seen yet in MagicaVoxel.
6 Sep 2018   [#382] In reply to [#381]
>>Very bad ?
it was the exact reflect of the original picture! :)
I believe that you can import a palett with colors of your original image!
the original is only126*126! ;)
6 Sep 2018   [#383]
yes, very bad, IMHO, because when i used a photo and made a small
picture it had false colors and only a few of them, after importing to
MagicalVoxel. But like you said, maybe there is an option for the
correct color palette import, which i have not found yet.
6 Sep 2018   [#384] In reply to [#383]
you right if the max is 255 colors that is some limited!
Maybe we must import the palett of the image made specially for it!
Else it's palett work is funny! Shift + Alt from a color to another on a platell makes a gradient : by line or by diagonal!
6 Sep 2018   [#385] In reply to [#377]
Hi Fabien,
I fully understand your viewpoint, and the non-destructive workflow in C4D is definitely interesting.
6 Sep 2018   [#386]
i figured out how to get correct colors from my previous image, in MagicaVoxel! :-)
Simply first drag and drop the image on the color palette, so that the color palette gets the
colors from your image and then drag and drop your image again in the voxel room. Not
hundert percent correct, because of 256 colors limit, but very good result for MagicaVoxel.
Bildschirmfoto_2018-09-06_um_16.16.30
6 Sep 2018   [#387] In reply to [#386]
@Stefan
One more time that is magic and so simple!
I have find that i must make a little programm in Processing for make a PNG 256*1 from a palette given by a 2D Prog!
My neurons say thank you!
So many Thanks! :)
6 Sep 2018   [#388]
You're welcome, Pilou!
But i don't understand why you must make a little Processing program...
6 Sep 2018   [#389] In reply to [#388]
@Stefan
Because I did't know the trick of drag&Drop image on the Palette!!!
Now no need to make the plugin! :)
6 Sep 2018   [#390]
Ah..., o.k. now i understand! :-)
6 Sep 2018   [#391] In reply to [#390]
It's not so bad! :)
In any case a very good trick! Bravo!
6 Sep 2018   [#392]
Looking good, Pilou! :-)
Maybe it depends on the colors and voxel size used, but yours looks fine.
6 Sep 2018   [#393] In reply to [#392]
Do you know a trimer image who create some files automatically
say i have an image 500*500 pixels
result wished will be this and of course in PNG
Max of 126*126 wished first
I have a normal Slicer, i search an "optimisation slicer" !
I have seen that for filling containers's boat, truck, cloth triming, wood, filling package... must be existing for image :)
7 Sep 2018   [#394]
Well, Photoshop can do this with it's "slice" tool and then you can save all
created slices at once, to have all the sliced pictures in one folder.
7 Sep 2018   [#395] In reply to [#394]
I have seen that for filling containers' boat, truck, cloth triming, wood, filling package... must be existing for image :)
7 Sep 2018   [#396]
GIMP has also a Guillotine function, but i don't know if you can slice the same way
like Photoshop, which would allow you to do exactly what you are looking for.
7 Sep 2018   [#397] In reply to [#396]
Looks like that this slicer has also variable slices options...
https://www.cyotek.com/cyotek-slicr
