Show messages:  1  …  282-301  302-321  322-341  342-361  362-381  382-401  402-421  …  3102-3119
1 Sep 2018   [#342]
Mac users are always unlucky! :)
after direct import inside Magica Voxel (some speedy little paint for example and Cylinder as "modules" )
1 Sep 2018   [#343]
So the best worflow is import OBJ to Magica Voxel (very speedy) then use the Simlab Lite for a more elaborated rendering!
(because the Simlab Voxelisation directly (some posts above) is some painful - i discourage that! )
MeshMixer or Rocket3F MeshLab or your favorite 3D Package for the OBJ repair...
1 Sep 2018   [#344]
I just thought to mention that ZBrush can also convert meshes to a voxelized representation.
Use Tool ➔ Subtool ➔ Remesh All, or Tool ➔ Unified Skin to voxelize meshes. Turn down Polish / Smooth to 0. Remesh All has more options, and creates a new subtool, while Unified Skin creates a new tool you have to activate.
1 Sep 2018   [#345] In reply to [#344]
Yes but it's not the same price! :)
Blender is also a challenger! :)
1 Sep 2018   [#346] In reply to [#345]
Yes, I almost forgot. You can simply use the Remesh modifier in Blender as well. :)
1 Sep 2018   [#347]
Seems OBJ format Magica Voxel keep color painted inside at the exportation
but these colors are not affectable separatly in a render Engine!
here the file created at the exportation without background obj +mlt+png (of Magica Palett colors - not background)
must create a file with separated colors - for address some different materials : any idea ?
I miss some inspiration now! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.zip
here inside SimLab
2 Sep 2018   [#348]
Hi Metin,
thanks for the tip with ZBrush. I just converted the dog asset and do with it something in MoI.
It takes a while until it is finished, but i hope the end result will look nice.
2 Sep 2018   [#349]
Hi all,
here is something funny... The first time i use the word penis, in combination with 3D. The penis
gives me non-manifold geometry in my dog model, which i'm currently working on. So i have
to make a female dog... :-D
Bildschirmfoto_2018-09-02_um_12.15.09
photo hosting
2 Sep 2018   [#350] In reply to [#349]
Very conceptual! :)
2 Sep 2018   [#351]
Thank you Pilou! :-)
and here is the final model. Renderings will follow on a later date.
Bildschirmfoto_2018-09-02_um_17.27.33
2 Sep 2018   [#352]
...and a rendering. Hope you like!
2 Sep 2018   [#353] In reply to [#352]
Remember animal wood building!
(here mechanical)
For the little story : all the animation, modeling etc is made with ArchiCad + GDL language! (not by me! )
2 Sep 2018   [#354] In reply to [#352]
Very nice Stefan! Very nice :)
2 Sep 2018   [#355]
Any idea for transform this single obj with different materials/colors in different objects by same material/color ?
I was unlucky till now! (detailled workflow needed...)
Thx by advance!
I tought that just some explode, select by colors will be fine but...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.zip (without wavy background)
3 Sep 2018   [#356]
About problem above
Edit: resolved : I can make that with the last version of MagicaVoxel before export! :) 0.99.1
make different group by selected colors but maybe I spoke too quickly! :)
PS Seems Last version of Magica has no more Import OBJ : so keep the 0.98 ;)
3 Sep 2018   [#357]
Thank you Marco, much appreciated!
3 Sep 2018   [#358]
Deep Learning for images * 600 % (99$)
Impossible to make more neat!
https://topazlabs.com/ai-gigapixel/
4 Sep 2018   [#359]
i just purchased the IMHO awesome Cubik Studio...which allows you to do that
with different materials for colors... As you can see in my picture i exported
a divided sphere from MoI with different styles and then run it through Cubik
Studio. You then have separate objects, which you can then give a different
material in SimLab Composer, i strongly assume.You can also import textured
.obj into Cubik Studio!!!! :-)
P.S. these are then Vertex Colors... I hope SimLab Composer can import and
show vertex colors!
P.P.S. sorry, Pilou it also divides when using complex models in different
areas with more colors, so you need a Polygon Modeler, which a. can
import Vertex Colors and b. then you have to join/seprate the polygons
where the colors are, to get different materials...
It cost only under 20 € and is IMHO well worth it.
Cubik_Studio
image host
4 Sep 2018   [#360] In reply to [#359]
Interesting, Stefan. Is Cubik Studio a MagicaVoxel / Qubicle competitor? I'll Google it and have a look.
4 Sep 2018   [#361]
Thx for the efforts!
for the moment i have made hundred of tests! (with programs I have) in a tonne of format! OBJ, DAE, PLY, 3DS
Meshmixer, MeshLab, Wings3D, Blender, SketchUp, pConPlanner and the Voxel Magica, Goxel
(i don't want use Zbrush or 3DCoat because I want a free solution ! ;)
Problem is that Magica produce objects in OBJ formats following that you have made
- one files where colors must be separated in Simlab (impossible easily for the moment)
or
- multiple files (when you make separated objects) who can't be reloaded mysteriously in simLab at the good place! (and manually one by one)
For the moment best is used SketchUp (.skp) - because arborescence of Objects/ colors are reloaded in one time inside Simlab!
but you must load one by one the objects inside SketchUP before export!
An another mystery is all formats dae, 3ds arrive without colors inside SketchUp!
so the Graal for this easy thing is not yet found! :)
Maybe I miss an option inside Magica for have a "group" of "objects" who can export in one time as group(s) for arrive as arborescence inside SimLab?...
Ps i have found a free Poly2Voxel here http://advsys.net/ken/download.htm! ;)
Right click on your OBJ file object / open with Poly2Voxel
A master Of Magica! It's really a magical program! ;)
