Show messages:  1-3  …  264-283  284-303  304-323  324-343  344-363  364-383  384-403  …  3104-3117
31 Jul 2018   [#324] In reply to [#323]
3D-Coat is a piece of cake! :)
Only 6 years ago it would have been impossible to have a product like that (and under 400USD!!!)
31 Jul 2018   [#325] In reply to [#321]
Hi Metin,
Thanks for sharing. The guy who created Hard Ops works with me on the Alamo project and has been trying to get me to use it for some time. It's quite powerful. I want to get the basics out of the way first.
Here's helped me with Blender and I've helped him with Moi3d.
7 Aug 2018   [#326] In reply to [#325]
Sounds good, Chipp. Good luck exploring Blender, I love it.
13 Aug 2018   [#327]
Hello everyone!
Check it out...
BLENDER 2.8 OVERVIEW - Eevee, Grease Pencil, Matcaps & More
https://youtu.be/fh29-ZgOLxY
13 Aug 2018   [#328] In reply to [#327]
Thanks Marco for sharing :-)
15 Aug 2018   [#329]
Hello everyone!
Another great "inside" for the amazing upcoming version 2.8 of Blender!
https://youtu.be/7jxii_T2Gcw
21 Aug 2018   [#330]
Meshroom: Photogrammetry Open Source
https://alicevision.github.io/#meshroom
23 Aug 2018   [#331]
before the direct Brain connection! :)
29 Aug 2018   [#332]
Manchu (Philippe Bouchet)
A big blog!
http://manchu-sf.blogspot.com/
a fan of Chris Foss of course! ;)
29 Aug 2018   [#333]
Visions of the future (5 parts)
31 Aug 2018   [#334]
Hi Pilou and all,
maybe interesting for you... It is possible to load .obj meshes into MagicalVoxel,
when converting .obj to .off and then use these two converters* from here:
http://dgtal.org/doc/tools/nightly/converters.html#converters
first run the .off file through mesh2vol and then through vol2vox.
However, in order to use these converters you need to compile the DGtal
library and also the DGtalTools.
Bildschirmfoto_2018-09-01_um_01.25.45
31 Aug 2018   [#335] In reply to [#334]
it's not more easy with Goxel?
http://guillaumechereau.github.io/goxel/
Magicavoxel-->Goxel
or even if you want only render you have the free Simlab Composer Lite (works with any 3D format files! :)
who has a Voxel function! :) (Maxi 1920*1040) (you can only save in proprietary format! )
1 Sep 2018   [#336]
i don't know, can you import with Goxel .obj and export to MagicalVoxel?
1 Sep 2018   [#337] In reply to [#336]
Seems yes for Magica Voxel :)
But I don't very well understand that you want to do in finality ?
1 Sep 2018   [#338]
The idea is that you can take any .obj convert it and load into Magical Voxel,
so that you don't have to model it in there... :-) Or to simply voxelize and
color a converted .obj file.
1 Sep 2018   [#339] In reply to [#338]
But you can import an OBJ File directly inside Magica Voxel!
1 Sep 2018   [#340]
I don't have this import button, hence that's why i wrote about the converters.
I downloaded version 0.99 and i can not see this in the Mac vers.... :-(
1 Sep 2018   [#341]
O.k. according to a Twitter post, i can drag and drop an .obj file or image
to the canvas, but the resolution is then for the .obj much smaller than
how i did it with the converters...
1 Sep 2018   [#342]
Mac users are always unlucky! :)
after direct import inside Magica Voxel (some speedy little paint for example and Cylinder as "modules" )
1 Sep 2018   [#343]
So the best worflow is import OBJ to Magica Voxel (very speedy) then use the Simlab Lite for a more elaborated rendering!
(because the Simlab Voxelisation directly (some posts above) is some painful - i discourage that! )
MeshMixer or Rocket3F MeshLab or your favorite 3D Package for the OBJ repair...
