Show messages:  1-11  …  3032-3051  3052-3071  3072-3091  3092-3111  3112-3119
6 Apr 2025   [#3092]
image from free Aria (Opera)
Free Vizcom Mix function
20 big zoom: https://imgbox.com/g/FAswFCsOYZ
<img src=”https://images2.imgbox.com/bd/b2/RRFpwktQ_o.jpg"/>
25 big zoom: https://imgbox.com/g/o4w4TXyQCZ
and the trick!
As the mix function don't use prompt you can use the same trick on the normal use for input a prompt! ;)
6 Apr 2025   [#3093]
My favorites
6 Apr 2025   [#3094]
30 Big zoom https://imgbox.com/g/FWmVJuEYQu
11 Apr 2025   [#3095] In reply to [#3094]
I have not heard of this IMGBOX? is it like ComfyUI or is another AI 3D tool?
12 Apr 2025   [#3096]
Here is an Action Figure Generator that can turn photos into highly detailed, collectible-grade articulated figures, powered by GPT-4o. https://actionfiguregenerator.io/
12 Apr 2025   [#3097] In reply to [#3095]
No no ImgBox is a free cloud for stock image! ;)
Program used is the very cool free Vizcom and it's so tricky Mix function!
You can make 100 images in 7 Minutes! So some speedy! :)
13 Apr 2025   [#3098] In reply to [#3097]
I have a free account at Vizom AI. I love this app very much.
13 Apr 2025   [#3099] In reply to [#3098]
Yep it´s the more versatile one!
And no limit of number of image!!!
A true gem!
13 Apr 2025   [#3100]
Haha, this made my day — it's like looking at the anti-Moi universe.
Speaking of fun visuals, if anyone's into experimenting with AI-generated cartoon avatars or art, I recently found AI Cartoon Generator(https://aicartoongenerator.org) — pretty cool for turning your photos into stylized cartoon images. Worth a try if you want something artsy to contrast with all the CAD precision here!
14 Apr 2025   [#3101] In reply to [#3100]
Yes the "opposite" as said in the thread tittle! :)
Cool i didn't known this Ai Cartoon Generator!
But seems it don't keep original model in Image to image!
Or does exist a trick ?
16 Apr 2025   [#3102]
Kling 2 but free version has not in free the new model of image! :(
17 Apr 2025   [#3103]
Leonardo is incredible!
19 Apr 2025   [#3104]
Happy Easter Eggs! :)
19 Apr 2025   [#3105]
40 Big Zoom Eggs : https://imgbox.com/g/t1Rp47UsBW
Vizcom Mix
19 Apr 2025   [#3106]
Leonardo
36 big Zoom : https://imgbox.com/g/ePPEDVnkAp
21 Apr 2025   [#3107]
OrigamiSimulator
Vizcom
21 Apr 2025   [#3108] In reply to [#3106]
Where did all of those egg themed images originate?
Thanks.
Frederick
22 Apr 2025   [#3109] In reply to [#3108]
@Fcwilt
Very easily! :)
I input this image (or similar) inside Leonardo! (will be another story for it self! ;)
Speedy Tuto
The Leonardo Section Image! (on the start online Application)
Legacy Mode (old Interface...check) / Image Guidance (check) (like Control Net on another prog)
Then load your source image above, and choose your image palette effect...here Image to Image
The Type "Control Net" image palette ...each one obviously gives a different result!
And, of course, your rendering engine (not-XL) and Element(s), if required, to achieve infinite profusion!
Here i used the cool "Isometric SFI Buildings"
And adjusting the cursor forces of all this junk... seems a little complicated... but once you've practiced a little, it works like a charm in 5 sesnonds!
In general, for a 780 x 780 size, it's 3 credits, for a 1040 x 1040 size it's 4 credits
All this over 150 automatic daily credits... and it's great, it keeps all the generations in memory!
You can run 10 generations in a row and watch their output on "Generation History"
I have used only 2 ELements ... Inferno & Baroque (Alone or both)
General tuto! :)
22 Apr 2025   [#3110]
For the first original image itself... free Gemini 2.5 experimental (imagen 3)
with the prompt
"a very complex colored transpararent engine Easter Eggs on Mars"
And if you want infinite variations of it...
Use the free Vizcom! with any images you want...:)
Use the Mix function...press generate any time you want...
nothing to do, no prompt, nothing... : Drag & Drop any images ... make links "+" to the "box Mix"
...select 2 to 5 images on the" Workbench" and move cursors! :)
22 Apr 2025   [#3111] In reply to [#3109]
Thanks for the info.
Interesting stuff, to be sure.
Frederick
