 1-15 236-255 256-275 276-295 296-315
 316-335 336-355 356-375 3116-3119
A free PBR* render directly inside SketchUp (so for Moi3D ! ;)
 * Physically-Based Rendering (PBR)
Carreful, you must intall 2 .rbz files : plugin itself
https://github.com/SamuelTS/SketchUp-PBR-Plugin/releases/tag/v1.4.5
https://extensions.sketchup.com/fr/content/gltf-exporter
& library
https://github.com/SamuelTS/SketchUp-PBR-Plugin/releases/download/v1.4.3/sketchup_pbr_material_lib.zip
You can edit material properties etc...
Crazzy thing! very nice rendering real time (not like these videos ultra compressed)
Following by Sammuel (creator of the plugin PBR)
Without PBR
With PBR
Leela your coach!
With Deep Learning technology!
Program free! :)
https://www.sjeng.org/leela.html
Put Tools " Show Network Probabilities"
Good luck!
VIDEO
Hi everyone!
Check this additional resource from 3D-Coat, related to Quad tool!
Thanks Frenchy for sharing the PBR rendering plugin. Didn't know about it. Cool beans!
<< the PBR rendering plugin
@Chipp
...and made by a French guy! ;)
Not to mention the most prolific SketchUp plugin developer, Fredo, is also French!
>> Fredo
Caracteristic of all its plugins : a rustic UI but very efficient!
The man who has given "thickness" to SketchUp! :) (and PushPull "Multiple" )
VIDEO
... and its last opus is the Crazy Animator!
VIDEO
Free Filters online (355 today) can  be local!
https://gmicol.greyc.fr  (in English! ;)
and a cool blog!
http://opensource.graphics
Of course an image of Moi ;)
The PBR above has now a ToolsBar!
You can use this cool one for make thes differents maps online! :)
http://cpetry.github.io/NormalMap-Online/
Hello everyone!
For all interested in digital paintings on iOS, finally there's the A-M-A-Z-I-N-G 4.1 version of Procreate!!!!
Check it out:
https://youtu.be/juDKyQce6_k
So incredible what Procreate' guys were able to do....
Beotian's question :)
Does this can work on a SmartPhone ? (procreate)
Yes! Only on iPhone obviously because it's exclusively for iOS.
Here the iPhone version:
https://procreate.art/pocket
I don't know if this pocket version has already received the same updtae 4.1 of the iPad version.
Anyway, I use only the iPad version but for what I've seen so far and what I've read here and there also the Pocket version is a killer App.
Consider that many people (including me) bought the iPad Pro almost exclusively to run this magical App (Procreate).
Maybe this can sound a little bit extreme but if you had the chance to use Procreate at least for some minutes you can understand :)
Yes seems a killer toshop /cintiq for 12 $ on tablet or 6$ for the Smartphone :)
and works also on normal Mac computers ?
VIDEO
No. It works exclusively on mobile devices, iPad/iPad Pro/iPhone.
And it's better this way because Procrete's guys were able to create the most optimised code, leveraging on Metal API of iOS instead of the poor OpenGL.
P.s. see what great artists around the world can do with this amazing App...
https://procreate.art/showcase
About the free PBR for free SketchUp Make  ! :)
For have transparency, it's a little tricky! :)
Use free online
https://pixlr.com/editor/  (or your 2d favorite editor) for give to your "texture image" % of Opacity (so transparency)
+ decrease the Luminocity!!! (that the trick)
then Import the PNG inside SketchUp as usual as "Texture" (can be in redrawing over a surface)
Now don't forget in PBR to put Section  "Alpha / Combined with Background" else transparency don't will existing!
For build some maps the cool free online
The PBR
Just for test: a simple plan + hard normal map for give simulate forms to waves and you can see clouds under! ;)
You can save a Material PBR! (+ maps)
Right Click on the palett of a SU materiel "used in the Model" !!! Save as
That create an .skm matrerial file that you put on the PBR folder :)
Rename a .skm file in .zip, Unzip it and you will refind all images!
Another trick for refund all SketchUp Images texture of a model
Export 3D .kmz
rename .zip, unzip, you have all image textures in a folder (only default they are rename texture, texture_0 etc...
it's not so bad! :)
Astonishing guy! Peter Draws!
Always absolutly incredible!
VIDEO
New free version PBR 1.43 for SkechUp Make!
Library of PBR Materials is now external !
Water PBR added :)
PBR above New version 1.5
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.296
 free textures
https://cc0textures.com/home  (+230) direct access!
2k, 4k, 8k with maps (4) JPG
with meedeek plugins (free version are existing)
http://design.medeek.com/resources/medeektrussplugin.html
or more elaborated :)
Our friend Chipp makes this one! ;)
VIDEO
