Show messages:  1-12  …  233-252  253-272  273-292  293-312  313-332  333-352  353-372  …  3113-3117
14 Jun 2018   [#293]
New Vectary 2 but only for the direct fun online because free version don't export anymore 3D models in generic formats! Only glTF, GLB ! :(
images yes...JPG, Png
14 Jun 2018   [#294]
About the Free Vectary version! :)
In fact I found a trick ! ;)
Go there : https://github.com/ksons/gltf-blender-importer
and install it inside Blender (allways a nightmare to ...navigate in menus for install Addon but... :)
You can now import your glTF/ GLB
and make any what you want with it! :)
So Vectary (free) --> Blender (free) --> Moi3D :)
glTF/ GLB --> OBJ --> with _ImportOBj by Max Smirnov --> 3DM :)
2 Jul 2018   [#295]
Hello everyone!
Check this wonderful tool of 3D-Coat (I think it should be in the latest beta version)
https://youtu.be/A0HiMdnsUqA
4 Jul 2018   [#296]
A free PBR* render directly inside SketchUp (so for Moi3D ! ;)
* Physically-Based Rendering (PBR)
Carreful, you must intall 2 .rbz files : plugin itself
https://github.com/SamuelTS/SketchUp-PBR-Plugin/releases/tag/v1.4.5
https://extensions.sketchup.com/fr/content/gltf-exporter
& library
https://github.com/SamuelTS/SketchUp-PBR-Plugin/releases/download/v1.4.3/sketchup_pbr_material_lib.zip
You can edit material properties etc...
Crazzy thing! very nice rendering real time (not like these videos ultra compressed)
Following by Sammuel (creator of the plugin PBR)
Without PBR
With PBR
4 Jul 2018   [#297]
Leela your coach!
With Deep Learning technology!
Program free! :)
https://www.sjeng.org/leela.html
Put Tools " Show Network Probabilities"
Good luck!
5 Jul 2018   [#298]
Hi everyone!
Check this additional resource from 3D-Coat, related to Quad tool!
5 Jul 2018   [#299] In reply to [#296]
Thanks Frenchy for sharing the PBR rendering plugin. Didn't know about it. Cool beans!
5 Jul 2018   [#300] In reply to [#299]
<< the PBR rendering plugin
@Chipp
...and made by a French guy! ;)
6 Jul 2018   [#301] In reply to [#300]
Not to mention the most prolific SketchUp plugin developer, Fredo, is also French!
6 Jul 2018   [#302] In reply to [#301]
>> Fredo
Caracteristic of all its plugins : a rustic UI but very efficient!
The man who has given "thickness" to SketchUp! :) (and PushPull "Multiple" )
... and its last opus is the Crazy Animator!
7 Jul 2018   [#303]
Free Filters online (355 today) can be local!
https://gmicol.greyc.fr (in English! ;)
and a cool blog! http://opensource.graphics
Of course an image of Moi ;)
9 Jul 2018   [#304]
The PBR above has now a ToolsBar!
You can use this cool one for make thes differents maps online! :)
http://cpetry.github.io/NormalMap-Online/
11 Jul 2018   [#305]
Hello everyone!
For all interested in digital paintings on iOS, finally there's the A-M-A-Z-I-N-G 4.1 version of Procreate!!!!
Check it out: https://youtu.be/juDKyQce6_k
So incredible what Procreate' guys were able to do....
11 Jul 2018   [#306] In reply to [#305]
Beotian's question :)
Does this can work on a SmartPhone ? (procreate)
11 Jul 2018   [#307] In reply to [#306]
Yes! Only on iPhone obviously because it's exclusively for iOS.
Here the iPhone version: https://procreate.art/pocket
I don't know if this pocket version has already received the same updtae 4.1 of the iPad version.
Anyway, I use only the iPad version but for what I've seen so far and what I've read here and there also the Pocket version is a killer App.
Consider that many people (including me) bought the iPad Pro almost exclusively to run this magical App (Procreate).
Maybe this can sound a little bit extreme but if you had the chance to use Procreate at least for some minutes you can understand :)
11 Jul 2018   [#308] In reply to [#307]
Yes seems a killer toshop /cintiq for 12 $ on tablet or 6$ for the Smartphone :)
and works also on normal Mac computers ?
11 Jul 2018   [#309] In reply to [#308]
No. It works exclusively on mobile devices, iPad/iPad Pro/iPhone.
And it's better this way because Procrete's guys were able to create the most optimised code, leveraging on Metal API of iOS instead of the poor OpenGL.
11 Jul 2018   [#310] In reply to [#308]
P.s. see what great artists around the world can do with this amazing App...
https://procreate.art/showcase
11 Jul 2018   [#311]
About the free PBR for free SketchUp Make ! :)
For have transparency, it's a little tricky! :)
Use free online https://pixlr.com/editor/ (or your 2d favorite editor) for give to your "texture image" % of Opacity (so transparency)
+ decrease the Luminocity!!! (that the trick)
then Import the PNG inside SketchUp as usual as "Texture" (can be in redrawing over a surface)
Now don't forget in PBR to put Section "Alpha / Combined with Background" else transparency don't will existing!
For build some maps the cool free online http://cpetry.github.io/NormalMap-Online/
The PBR
Just for test: a simple plan + hard normal map for give simulate forms to waves and you can see clouds under! ;)
You can save a Material PBR! (+ maps)
Right Click on the palett of a SU materiel "used in the Model" !!! Save as
That create an .skm matrerial file that you put on the PBR folder :)
Rename a .skm file in .zip, Unzip it and you will refind all images!
Another trick for refund all SketchUp Images texture of a model
Export 3D .kmz
rename .zip, unzip, you have all image textures in a folder (only default they are rename texture, texture_0 etc...
it's not so bad! :)
12 Jul 2018   [#312]
Astonishing guy! Peter Draws!
Always absolutly incredible!
