Show messages:  1-2  …  103-122  123-142  143-162  163-182  183-202  203-222  223-242  …  3103-3119
1 Dec 2017   [#163]
Magica Voxel 0.99
https://ephtracy.github.io/
See here for funny previous Magica Voxel things! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.41
1 Dec 2017   [#164] In reply to [#163]
Hi Pilou!
...I really love Magica Voxel!
It's a piece of cake into the almost boring and repetitive world of CG :)
1 Dec 2017   [#165]
Hi Pilou and Marco,
I love MagicaVoxel too. It's a joy to work with.
Have a nice weekend!
8 Dec 2017   [#166]
Hi Pilou.
I ask to you because you're the "SimLab" expert :)
With the "Lite" version how I can export the rendered image to 1920x1080 png without background ?
And when I click "Render to File" Simlab ask me to activate a trial license.
As you can see in this image the image resolution is not 1920x1080 and if I press the "Camera" button at bottom right the image is save with the background,
but I would like to save it without background.
Thanks for help.
8 Dec 2017   [#167]
Hi Marco,
Simlab looks interesting. Does anyone know how it compares to Keyshot, in ease of use and rendering realism?
8 Dec 2017   [#168] In reply to [#167]
it's more easy than Keyshot! (if possible! )
Perfect for hobbyist for the free price!
All that in 3 seconds!
8 Dec 2017   [#169]
Simlab Composer Light - Lite (free)
menu Render / Exit Parameter any size till 1920 * 1080
menu Render / Environnement parameters = you choose any backgrounds !)
And you can of course change all parameter if you want more advance things! :)
8 Dec 2017   [#170] In reply to [#169]
Ok Pilou.
But...I'm sorry...maybe I didn't understand.
What I need is to know how to, with the "Lite" version, export the rendered image to 1920x1080 png without any background (or transparent background).
8 Dec 2017   [#171] In reply to [#170]
Just look attentively my image above! ;)
If you explore the Menu Background you have to choose a unic color !
So ;) Sorry it's French version but...
And for have your 1920 * 1080 you must pass by the Render Menu!
in fact I believe you can have any size that gives 2 073 600 maxi (pixel) = 1920 *1080 !
8 Dec 2017   [#172] In reply to [#171]
Thanks Pilou for help.
A couple of hours and I'll try your suggestion.
I will let you know the results.
Ciao.
8 Dec 2017   [#173]
If you take the "Default background" of my first image above you will obtain a pure white Background!
white
And if you start with an empty scene you will have only object imported rendered + white background! = easy for clipping! ;)
So
8 Dec 2017   [#174]
PS Of course at the end after all Render parameters / Environnement, Advanced, Exit
Menu Render / To File (F5) :)
For compare versions!
http://www.simlab-soft.com/3d-products/simlab-composer-workbenches.aspx
I love it's simplicity! No headaches! And the free price for the hobbyists :)
8 Dec 2017   [#175]
Maybe this can interest you! :)
(you must have Flash Player installed)
2D Paint Program free Online (maxi 4095 * 4095) - Multi Languages
Maybe the more easy funny excentric toshop like ;)
SumoPaint : https://www.sumopaint.com/home/#app
Thx Patrick for the original image before playing! :)
9 Dec 2017   [#176] In reply to [#166]
Hi Marco
see my screenshot to export in PNG without background
9 Dec 2017   [#177]
My method was for the JPG format! ;)
9 Dec 2017   [#178] In reply to [#177]
you can't have a transparent background with jpeg :)
9 Dec 2017   [#179] In reply to [#178]
Sure :)
But you can use the Magic Wand with tolerance!
JPG is better for have more colors! ;)
9 Dec 2017   [#180] In reply to [#168]
Thanks for the Simlab info, Pilou. I'll have a look at it.
9 Dec 2017   [#181] In reply to [#176]
Hi Finema and Pilou.
Thanks for help :)
Ok.
I've made some considerations.
1) The "Lite" version is not good for me. 1920x1080 is too small. I need "print" resolution (at least A3 300 dpi 3508 pixels x 4961)
2) I'm evaluating the "Pro" version.
During the next days I will test it.
But for sure one thing that is not very good for me is that SimLab is CPU bound while some times ago I've invested my money in a powerful Gtx 1080 Ti,
and I've not invested in a multicore CPU. I have a good i7-7700K.
Actually I already have Thea Render, a blazing fast CPU+GPU rendering engine.
I need a rendering engine that should allow me to use this particular superspeed workflow for rendering of 3D concept models :
I don't want to waste my time in Retopo/UV/Texturing.
I need a rendering engine that should take the exported obj models with mid/high poly count and simply applying premade materials over them and render in one shot.
With Thea Render I can already do this thing with good results.
I want to see if the rendering quality of SimLab with that particular workflow is sufficient for me.
If so, I will accept its "slowness" of CPU bound and I will get a "Pro" license.
I will let you know.
Thanks and have a nice day.
9 Dec 2017   [#182] In reply to [#181]
Hi Marco
What kind of rendering do you want?
Personally, I use keyshot for my renderings of objects, bottles or packaging.
I have tested Simlab Composer 8, and I find the rendering to be quite correct. But nothing replaces the professional rendering of keyshot.
That's my humble opinion.
