Show messages:  1-12  …  1053-1072  1073-1092  1093-1112  1113-1132  1133-1152  1153-1172  1173-1192  …  3113-3119
27 Sep 2021   [#1113]
How cool is this Snap!
27 Sep 2021   [#1114] In reply to [#1113]
I know it too. ;-)
Am a long time fan of logo and turtle graphic.
Here are some Snap! alterations.
"TurtleStitch", which can be used to create patterns
for embroidery machines, also generates the code to
Embroidery machines to control. You can export your design
export also as .SVG
Here is an example:
https://www.turtlestitch.org/run#cloud:Username=elise&ProjectName=stern
There are more examples on their website, all are
directly playable.
And "Beetle Blocks" turtle graphics in 3D.
Many examples on their website.
The created model can be exported as .OBJ and .STL.
In 2D Mode, Lines could be exported as .SVG
http://www.beetleblocks.com/
an Example:
http://www.beetleblocks.com/users/Jens/projects/Hilbert%20Cube
27 Sep 2021   [#1115]
Btw. like the other Tools you mention also
Big Like !
27 Sep 2021   [#1116]
Snap : With my last one Moi textured...
Minimalist listing :)
A long way to explore!
27 Sep 2021   [#1117]
Astonished! By the language creator himself! :)
28 Sep 2021   [#1118] In reply to [#1117]
Indeed "Astonished " is the right word.
I have never seen this side of Snap! before.
28 Sep 2021   [#1119] In reply to [#1118]
Your 3D Version of Beetle Blocks is some cool! (stl OBJ export ! )
28 Sep 2021   [#1120]
Bonus! :)
https://microblocks.fun
28 Sep 2021   [#1121] In reply to [#1119]
Yes, i know :)
Dont forget you could, in 2D Mode, also
save curves as .SVG.
But TurtleStitch has also something to offer. :)
https://www.youtube.com/watch?v=K6ra5ThxkrE
29 Sep 2021   [#1122] In reply to [#1121]
Ah yes i have made this one! :)
Works like a charm except you must convert the SVG! (I use Affinity to PDF to Moi)
29 Sep 2021   [#1123] In reply to [#1122]
Nice one, Pilou !
I would also like to mention that Snap!
can also run offline.
But only within a Browser.
Here is the Link:
https://snap.berkeley.edu/offline
30 Sep 2021   [#1124] In reply to [#1123]
yes of course but you are not sure to use the last version of Snap with the local one! ;)
In the other side maybe it's run a little more speedy when you use images! :)
else the famous one!
and the direct Snap online prog (only 2D of course)
https://snap.berkeley.edu/snap/snap.html#present:Username=jadga&ProjectName=collatz
Found on the Twetter of Jens Mönig! ;)
https://twitter.com/moenig
2 Oct 2021   [#1125]
Maybe not so opposited! :)
Windows, Mac, Ipad
Terrific! Cad Free with export STL low res, 3MF
2 Oct 2021   [#1126] In reply to [#1125]
WOW!
2 Oct 2021   [#1127] In reply to [#1125]
The fillet system on that program is amazing.
However, I would need an overwhelming reason to use subscription based software. They all seem to hook you in, then raise prices. If you quit using, you can't edit your prior work.
That's why I ditched Adobe when they got greedy and purchased Affinity Photo / Affinity Designer.
2 Oct 2021   [#1128] In reply to [#1127]
Yes is more for a Pro than a hobbyist !
5 Oct 2021   [#1129] In reply to [#1127]
Same here, Ed!
7 Oct 2021   [#1130]
Test Snap with Moi Objects :) Any sizes or images can be used!
For one object : that is some synthetic!
13 Oct 2021   [#1131]
For be inside the beta! :)
https://www.sketchup.com/products/sketchup-for-ipad
13 Oct 2021   [#1132] In reply to [#1131]
Yep, I'm in the BETA and so far so good. It works a lot better than the Web version through a browser.
