Show messages:  1-2  …  1043-1062  1063-1082  1083-1102  1103-1122  1123-1142  1143-1162  1163-1182  …  3103-3119
22 Sep 2021   [#1103] In reply to [#1102]
Yes, have the free Version "Expression 3.3" but no
Link where you could download it. Seems no more
avaible.
Alternative could be the also free Microsoft Epression Design 4.
Works on Win 10, it even have more Brushes. Very cool ones.
Here Link:
https://www.heise.de/download/product/expression-design-41150/download
Its a german Site ( because i am german ;) ) , Use the download button below.
The upper one does not work. Is named as Trial but its the full working free Version.
22 Sep 2021   [#1104] In reply to [#1103]
Thx installed works fine except seems only in German ! :)
Now i have the name and found to download it in French ! :)
https://expression-design.fr.malavida.com/download (Expression Design 4 )
tested works fine! But seems it's not the same spirite of Creature Home (functions for that i remember) :)
22 Sep 2021   [#1105] In reply to [#1104]
Thats true. But find the Brushes are still fine.
22 Sep 2021   [#1106] In reply to [#1105]
Yes funny anyway!
i must just find how draw a Brush with image or photo without close the path! :)
like above the lemon...
Maybe trivial but...maybe a background transparency...
22 Sep 2021   [#1107] In reply to [#1106]
Look in the Help File under:
Using fills and strokes
> Define custom brush strokes
To create a brush stroke from an image, you need a bitmap image.
Open the image you want to use for the brush stroke in your document.
Select the Selection tool in the Tool palette (or press V).
Select the image, point to Stroke on the Object menu, and then click Define Image Stroke.
The Define Image Stroke dialog box opens.
22 Sep 2021   [#1108] In reply to [#1107]
yes, you must set the Fill to this
Fill is the left one, Stroke the right.
22 Sep 2021   [#1109]
The vector brushes also have a lot to offer.
Use one as a brush stroke (left) and make the stroke size very large (right).
An old Illustrator trick to create an interesting pattern.
22 Sep 2021   [#1110] In reply to [#1108]
Yep that is that! :) THX!
So a very smart one prog simple and efficient! :) Not a gas engine! That's cool!
On my picture of the day! ;)
Moi3D + Textures from the fabulous free Online! Vervette SandBox By Taron! http://www.taron.de/Vervette/sandbox/
Render : the free SimLab Composer Lite! a "Keyshot like" but free !) (maxi 1920 *800) or if you take an old one (maxi 1920 * 1040)
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
https://www.simlab-soft.com/3d-products/simlab-composer-old-download.aspx?locale=en
For the Lite : just download the normal prog (not the "trial")
else the Brush without back ground "closed" :) (in French! :)
26 Sep 2021   [#1111]
26 Sep 2021   [#1112]
MagicaVoxel : Animation is coming soon!
https://twitter.com/i/status/1441827172952391684
27 Sep 2021   [#1113]
How cool is this Snap!
27 Sep 2021   [#1114] In reply to [#1113]
I know it too. ;-)
Am a long time fan of logo and turtle graphic.
Here are some Snap! alterations.
"TurtleStitch", which can be used to create patterns
for embroidery machines, also generates the code to
Embroidery machines to control. You can export your design
export also as .SVG
Here is an example:
https://www.turtlestitch.org/run#cloud:Username=elise&ProjectName=stern
There are more examples on their website, all are
directly playable.
And "Beetle Blocks" turtle graphics in 3D.
Many examples on their website.
The created model can be exported as .OBJ and .STL.
In 2D Mode, Lines could be exported as .SVG
http://www.beetleblocks.com/
an Example:
http://www.beetleblocks.com/users/Jens/projects/Hilbert%20Cube
27 Sep 2021   [#1115]
Btw. like the other Tools you mention also
Big Like !
27 Sep 2021   [#1116]
Snap : With my last one Moi textured...
Minimalist listing :)
A long way to explore!
27 Sep 2021   [#1117]
Astonished! By the language creator himself! :)
28 Sep 2021   [#1118] In reply to [#1117]
Indeed "Astonished " is the right word.
I have never seen this side of Snap! before.
28 Sep 2021   [#1119] In reply to [#1118]
Your 3D Version of Beetle Blocks is some cool! (stl OBJ export ! )
28 Sep 2021   [#1120]
Bonus! :)
https://microblocks.fun
28 Sep 2021   [#1121] In reply to [#1119]
Yes, i know :)
Dont forget you could, in 2D Mode, also
save curves as .SVG.
But TurtleStitch has also something to offer. :)
https://www.youtube.com/watch?v=K6ra5ThxkrE
29 Sep 2021   [#1122] In reply to [#1121]
Ah yes i have made this one! :)
Works like a charm except you must convert the SVG! (I use Affinity to PDF to Moi)
