Show messages:  1-15  …  976-995  996-1015  1016-1035  1036-1055  1056-1075  1076-1095  1096-1115  …  3116-3119
29 Jun 2021   [#1036]
MagicaVoxel 0.0.2 is released, with:
• New Stroke Shapes: Quadratic Bezier (3-point), Oval (Cylinder), Star (Polygon)
• Icons: add icons to stroke panel and list.
• Stroke List: use SHIFT/CTRL to multi-select strokes in the stroke list. use right-click menu to rename layers and strokes.
https://ephtracy.github.io/index.html?page=magicacsg
29 Jun 2021   [#1037] In reply to [#1036]
Excellent!
And don't forget to put the plugin Denoiser for a speedy Render! https://github.com/ephtracy/ephtracy.github.io/releases/tag/0.01
30 Jun 2021   [#1038]
Hi All
Made a funny little Vespa with MagicaCSG 0.0.1.
(in reminiscence of Mauro's Vespa tutorial :) )
I know Magica CSG 0.0.2 is out.
Already downloaded ;-)
30 Jun 2021   [#1039] In reply to [#1038]
Onctuous lines! Bravo!
30 Jun 2021   [#1040]
Thank you Pilou :)
And let me also thank you for all your good tipps
you have shared over the years in this post.
30 Jun 2021   [#1041]
3D Coat Learnings becomes free!
https://3dcoat.com/2021announcement/
Numerous free file PBR also! (2500)
A special version only Texture + Render : named "Textura" will be low coast! Perfect for MOi! ;)
etc...
30 Jun 2021   [#1042] In reply to [#1038]
Nice scooter model, Subpath!
30 Jun 2021   [#1043] In reply to [#1042]
Thank you, Metin.
Was a lot of Fun to make it.
Love MagicaCSG a truly little Gem.
1 Jul 2021   [#1044]
Hi all
Pilou, I hope you don't mind me introducing an free Online Tool here.
Stumbled across this free Online Tool, which may interest also
MOI Users, Graphic Designers because of Vectorgraphics.
(Results can be also saved as .SVG Vectorgraphic)
Its a kind of Halftone Generator.
You can use a Photo, choose between different Shapes and the space
between the Shapes and your Photo/Rendering would converted then
in a Halftone Picture. Which can also be saved as SVG.
Here the Link:
https://labs.adobe.com/experiments/hello-halftones/
Have fun being creative.
1 Jul 2021   [#1045] In reply to [#1044]
Cool but it's a pity that they don't use colors of original image! :)
Here i reload the SVG inside the low cost Affinity Designer and exported as PDF for Import inside Moi3D!
It's of course 3 Moi's Objects! ;)
Maybe a day an SVG direct import inside moi ? :)
15 562 closed curves! (the entiere image)
1 Jul 2021   [#1046] In reply to [#1045]
Flow on a sphere of the all image : 15 seconds :)
1 Jul 2021   [#1047] In reply to [#1046]
Wow, that flow on sphere gets me.
Cool Idea.
Do not miss the colors from the photo that much.
Because I am more interested in the patterns.
1 Jul 2021   [#1048]
And inside the free Aerialod ;) (just Drag and Drop any image on the screen : magic! :)
https://ephtracy.github.io/index.html?page=aerialod (by EPHTracy MagicaVoxel, Magicacsg)
You can export as PLY of that so a 3D model ;)
2 Jul 2021   [#1049]
Nice, Subpath and Pilou!
In my spare time I'm a big fan of experimenting with AI / ML for image / photo enhancement, particularly GANs (Generative Adversarial Networks).
Here's a Twitter thread where I posted some recent results:
https://twitter.com/metinse7en/status/1405465023015755776
2 Jul 2021   [#1050] In reply to [#1049]
Wow, these photo enhancements impresses me.
Thanks, for your Link.
I am also always interested in such things and generative art.
Also Art and Design in general and of course admire the old Masters.
But i am not a Pro, only interested ;-)
2 Jul 2021   [#1051] In reply to [#1050]
Every skill starts with interest! :)
5 Jul 2021   [#1052]
Some infos :)
free ZPlugin for import / Export PLY pour ZBrush by Marcus Civis
Export quadrangles depuis ZBrush
5 500 faces dans MOiavec _importObj by Max Smirnov (_ImportObj 30 secondes)
8 Jul 2021   [#1053]
So cool the Modernist a free Shader by mode_vis for the free MagicaVoxel !
https://mode-vis.gumroad.com/?recommended_by=library&sort=page_layout#EhDwgL
MagicaVoxel : https://ephtracy.github.io/
8 Jul 2021   [#1054] In reply to [#1053]
Thanks for the tip Pilou.
Wow there are a lot of incredible shaders for Magicavoxel
8 Jul 2021   [#1055]
Hi all
Here is another tool worth mentioning.
"Sceelix" (Mac/PC/LInux) has been open source
for some time. Was sold on Steam before that.
"Scellix" is a standalone procedural generation
software in the vein of a node modeler. But don't
expect too much, it is still in an early stage.
The File contains a few examples.
Homepage Link:
https://sceelix.com/docs/Introduction/AboutSceelix
and a vid:
https://www.youtube.com/watch?v=aSgJPN6qK5I
