Show messages:  1-7  …  968-987  988-1007  1008-1027  1028-1047  1048-1067  1068-1087  1088-1107  …  3108-3119
26 Jun 2021   [#1028]
Next version of the free MagicaCSG will have Bezier Quadric and other funny things! :)
26 Jun 2021   [#1029] In reply to [#1028]
Yeah, looking forward to those splines. They will only have three curve manipulation points though. Hopefully that will be extended in a next version.
27 Jun 2021   [#1030]
Thank you for your tip, Pilou.
Find MagicaCSG already a nice little gem.
But miss the grouping of strokes.
Here is my first attempt.
27 Jun 2021   [#1031] In reply to [#1030]
You can group strokes with layers in MagicaCSG, and the order of the strokes list is also important for different results (which strokes are affected by other strokes).
27 Jun 2021   [#1032] In reply to [#1031]
Thank you for the Info, Metin.
By the way I like the great examples you
made with MagicaCSG. Very well done.
In the meantime I found the "Select All" button.
With this button you can select all strokes of a layer.
I should have just opened my eyes ;-)
And this way I can now put parts of an object on a
separate layer and select them if I need that.
27 Jun 2021   [#1033] In reply to [#1032]
Many thanks for your compliment, much appreciated!
The next MagicaCSG version will introduce a number of UI / UX improvements. I hope it will be released soon.
Regards from the Netherlands,
29 Jun 2021   [#1034]
Demo of the next version of MagicaCSG :)
https://twitter.com/i/status/1409302243577315333
29 Jun 2021   [#1035] In reply to [#1034]
Thanks Pilou!
What a wonderful software is MagicaVoxel!
29 Jun 2021   [#1036]
MagicaVoxel 0.0.2 is released, with:
• New Stroke Shapes: Quadratic Bezier (3-point), Oval (Cylinder), Star (Polygon)
• Icons: add icons to stroke panel and list.
• Stroke List: use SHIFT/CTRL to multi-select strokes in the stroke list. use right-click menu to rename layers and strokes.
https://ephtracy.github.io/index.html?page=magicacsg
29 Jun 2021   [#1037] In reply to [#1036]
Excellent!
And don't forget to put the plugin Denoiser for a speedy Render! https://github.com/ephtracy/ephtracy.github.io/releases/tag/0.01
30 Jun 2021   [#1038]
Hi All
Made a funny little Vespa with MagicaCSG 0.0.1.
(in reminiscence of Mauro's Vespa tutorial :) )
I know Magica CSG 0.0.2 is out.
Already downloaded ;-)
30 Jun 2021   [#1039] In reply to [#1038]
Onctuous lines! Bravo!
30 Jun 2021   [#1040]
Thank you Pilou :)
And let me also thank you for all your good tipps
you have shared over the years in this post.
30 Jun 2021   [#1041]
3D Coat Learnings becomes free!
https://3dcoat.com/2021announcement/
Numerous free file PBR also! (2500)
A special version only Texture + Render : named "Textura" will be low coast! Perfect for MOi! ;)
etc...
30 Jun 2021   [#1042] In reply to [#1038]
Nice scooter model, Subpath!
30 Jun 2021   [#1043] In reply to [#1042]
Thank you, Metin.
Was a lot of Fun to make it.
Love MagicaCSG a truly little Gem.
1 Jul 2021   [#1044]
Hi all
Pilou, I hope you don't mind me introducing an free Online Tool here.
Stumbled across this free Online Tool, which may interest also
MOI Users, Graphic Designers because of Vectorgraphics.
(Results can be also saved as .SVG Vectorgraphic)
Its a kind of Halftone Generator.
You can use a Photo, choose between different Shapes and the space
between the Shapes and your Photo/Rendering would converted then
in a Halftone Picture. Which can also be saved as SVG.
Here the Link:
https://labs.adobe.com/experiments/hello-halftones/
Have fun being creative.
1 Jul 2021   [#1045] In reply to [#1044]
Cool but it's a pity that they don't use colors of original image! :)
Here i reload the SVG inside the low cost Affinity Designer and exported as PDF for Import inside Moi3D!
It's of course 3 Moi's Objects! ;)
Maybe a day an SVG direct import inside moi ? :)
15 562 closed curves! (the entiere image)
1 Jul 2021   [#1046] In reply to [#1045]
Flow on a sphere of the all image : 15 seconds :)
1 Jul 2021   [#1047] In reply to [#1046]
Wow, that flow on sphere gets me.
Cool Idea.
Do not miss the colors from the photo that much.
Because I am more interested in the patterns.
