8-27
28-47
48-67
68-87
88-105
Yeah - the wine version is a little old - wine-1.2.2.
Other simple apps run OK, such as notepad. I am upgrading wine to 1.3.15 right now.
I get:
fixme:system:SetProcessDPIAware stub!
fixme:iphlpapi:NotifyAddrChange (Handle 0x8ede914, overlapped 0x8ede918): stub
wine: configuration in '/home/phr0sty/.wine' has been updated.
fixme:process:GetSystemDEPPolicy stub
fixme:process:SetProcessDEPPolicy (0): stub
Segmentation fault
Hi Phr0stByte,
These lines that say "stub" just mean that these are some particular Windows functions that Wine does not happen to implement yet. But these particular things should not really make any difference one way or the other.
Can you try running using winedbg instead of regular wine to see if it gives any information on where the crash is happening? When you use winedbg, it will break into the debugger when it starts up and then type in c and push enter to continue running after that.
Was there possibly any moi_report.zip files generated in the MoI program folder?
What particular version of Ubuntu are you using?
Hi Phr0stByte, I just also ran a test using Ubuntu 11.4 and did not see any problems there either.
Are you possibly trying to install the v2 trial version instead of the just released v3 beta version?
Or are you maybe running on some older version of Ubuntu?
Also how did you install Wine, I used this:
sudo apt-get install wine1.3
That pulls in a variety of support libraries. If you used some other method for installing it maybe you did not get some kind of support libraries that are needed for some portions of Wine to function properly.
Yeah - I am running Ubuntu 11.04 x64.
It might me something with this laptop video card. I will try on my desktop this weekend and let you know.
There was no zip file in the Moi directory. Maybe I am missing something... Do you need to install the windows version of the video driver into wine?
Hi Phr0stByte,
No Wine itself uses OpenGL and will make use of whatever OpenGL driver is installed already, you don't need to (and can't really) install drivers within Wine itself.
OK - I tried on my desktop and I get an inkling that things might work under the perfect storm of circumstances. Here is what I get:
phr0stbyte@Phr0styBox:~/.wine/drive_c/Program Files/MoI 3.0 beta Aug-24-2011$ wine MoI.exe
Error: API mismatch: the NVIDIA kernel module has version 280.13,
but this NVIDIA driver component has version 275.21. Please make
sure that the kernel module and all NVIDIA driver components
have the same version.
err:winediag:X11DRV_WineGL_InitOpenglInfo Direct rendering is disabled, most likely your OpenGL drivers haven't been installed correctly
fixme:dbghelp:elf_search_auxv can't find symbol in module
I think that NVIDIA driver component has version 275.21 is an old version. I am not sure how to fix this though, as I don't want to break things so that Octane doesn't work (it does now, and wonderfully so). NVIDIA drivers are hard enough just to keep working under linux.
Hi Phr0stByte - what actually happens on your desktop machine though, is there still a core dump when you run it there, or does the rest of MoI show up except for the 3D viewport display?
What happens on your desktop system if you edit the MainWindowLayout.xml file as described previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.25 does that make the rest of the UI come up without the viewports or still not?
Actually, never mind! I just got the nVidia mismatch sorted out and MoI v3 beta is working! Hurry up and start selling it! :)
Hi Phr0stByte, that's great news that you've got it up and running now!
So it's still a no-go on your laptop, is that correct? But it is running ok using Wine on your desktop machine now?
That is correct. I will play a little bit more on the laptop, but I mostly just use my desktop, as that is where the beefy h/w is. But the laptop would definately be a bonus.
[EDIT] It is now working on the laptop too! Woohoo!!!
Hi Phr0stByte, was there any particular change that you did on the laptop to get it working, was it also a video driver tuneup there as well?
Yep - I could not say exactly what fixed it. I just kept monkying with the driver until it worked. I was actually stuck without any display at all in one point and only had tty. Luckily, I got it all back plus the nice little bonus of having MoI working :)
A little update - I tried to get the MoI v3 beta running on my Macbook Pro too using wine, but I can't get it to run. Any Mac users out there have any input?
Russian:
Привет всем!
Все сделал так, как вы здесь написали. Но программа запускается в таком виде и выдает следующее сообщение (nVidia GeForce 9600GT, Kubuntu 11.04, Wine 1.3.15):
English (Goggle):
Hi everyone!
I've done everything as you wrote here. But the program is run in such a form and show the following (nVidia GeForce 9600GT, Kubuntu 11.04, Wine 1.3.15):
*** wine MoI.exe
fixme:toolhelp:CreateToolhelp32Snapshot Unimplemented: heap list snapshot
fixme:mountmgr:harddisk_ioctl unsupported ioctl 74080
fixme:mountmgr:harddisk_ioctl unsupported ioctl 2d1400
fixme:win:EnumDisplayDevicesW ((null),0,0xe4f804,0x00000000), stub!
fixme:heap:HeapSetInformation 0x110000 0 0xe4f330 4
fixme:advapi:RegisterTraceGuidsW (0x638962c3, 0x63ab1058, {ffdb9886-80f3-4540-aa8b-b85192217ddf}, 1, 0xe4ef78, (null), (null), 0x63ab1058,)
fixme:advapi:RegisterTraceGuidsW (0x638964fa, 0x63aae200, {0cfe0455-93ba-440d-a3fe-553973d0b723}, 1, 0xe4ef5c, (null), (null), 0x63aae208,)
fixme:advapi:RegisterTraceGuidsW (0x638964fa, 0x63aae220, {797fabac-7b58-4796-b924-d51178a59ce4}, 1, 0xe4ef5c, (null), (null), 0x63aae228,)
fixme:advapi:RegisterTraceGuidsW (0x638962c3, 0x63ab1088, {9e3b3947-ca5d-4614-91a2-7b624e0e7244}, 1, 0xe4ef78, (null), (null), 0x63ab1088,)
fixme:ntdll:NtQueryInformationToken QueryInformationToken( ..., TokenElevationType, ...) semi-stub
fixme:msimtf:DllGetClassObject ({50d5107a-d278-4871-8989-f4ceaaf59cfc} {00000001-0000-0000-c000-000000000046} 0xe4f548)
err:ole:apartment_getclassobject DllGetClassObject returned error 0x80040111
err:ole:CoGetClassObject no class object {50d5107a-d278-4871-8989-f4ceaaf59cfc} could be created for context 0x401
err:ole:CoGetClassObject class {82c5ab54-c92c-4d52-aac5-27e25e22604c} not registered
err:ole:create_server class {82c5ab54-c92c-4d52-aac5-27e25e22604c} not registered
fixme:ole:CoGetClassObject CLSCTX_REMOTE_SERVER not supported
err:ole:CoGetClassObject no class object {82c5ab54-c92c-4d52-aac5-27e25e22604c} could be created for context 0x17
fixme:advapi:RegisterTraceGuidsA (0x633fa1fa, 0x634235c0, {0cfe0455-93ba-440d-a3fe-553973d0b723}, 1, 0xe4ee78, (null), (null), 0x634235c8,)
fixme:advapi:RegisterTraceGuidsA (0x633fa1fa, 0x634235e0, {797fabac-7b58-4796-b924-d51178a59ce4}, 1, 0xe4ee78, (null), (null), 0x634235e8,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3e0, (null), (null), 0x63420f60,)
err:ole:CoGetClassObject class {6c736db1-bd94-11d0-8a23-00aa00b58e10} not registered
err:ole:CoGetClassObject no class object {6c736db1-bd94-11d0-8a23-00aa00b58e10} could be created for context 0x1
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f538, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3a8, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3b8, (null), (null), 0x63420f60,)
fixme:wininet:FindFirstUrlCacheContainerW (0xe473a8, 0xe473b4, 0xe473b0, 0x00000000) stub
fixme:wininet:CreateUrlCacheContainerW (0x1a43ac84, 0x1a43ff50, 0x00e47188, 0x00000000, 0x00000000, 0x00000009, 0x00000000, 0x00000000) stub
fixme:nls:WideCharToMultiByte UTF-7 not supported
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4ef08, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4eef8, (null), (null), 0x63420f60,)
fixme:dwmapi:DwmIsCompositionEnabled 0xe4e6bc
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4eb10, (null), (null), 0x63420f60,)
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=0): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=1): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=2): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=3): stub
fixme:wininet:FindFirstUrlCacheContainerW (0xe48f04, 0xe48f10, 0xe48f0c, 0x00000000) stub
fixme:wininet:CreateUrlCacheContainerW (0x1a43ac84, 0x1a43ff50, 0x00e48ce4, 0x00000000, 0x00000000, 0x00000009, 0x00000000, 0x00000000) stub
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2830, {b2a40f1f-a05a-4dfd-886a-4c4f18c4334c}, 1, 0xe49e30, (null), (null), 0x133f2830,)
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2860, {ffdb9886-80f3-4540-aa8b-b85192217ddf}, 1, 0xe49e30, (null), (null), 0x133f2860,)
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2890, {5c8bb950-959e-4309-8908-67961a1205d5}, 1, 0xe49e30, (null), (null), 0x133f2890,)
fixme:advapi:RegisterTraceGuidsW (0x13231481, 0x133f12c8, {3e1fd72a-c323-4574-9917-5ce9c936f78c}, 1, 0xe49e10, (null), (null), 0x133f12d0,)
fixme:advapi:RegisterTraceGuidsW (0x13231481, 0x133f12e8, {afff9c82-5be3-4205-9b3e-49e014c09a63}, 1, 0xe49e10, (null), (null), 0x133f12f0,)
fixme:wininet:GetUrlCacheEntryInfoExW Undocumented flag(s): 100
fixme:win:EnumDisplayDevicesW ((null),0,0xe4a770,0x00000000), stub!
fixme:d3d:swapchain_init Add OpenGL context recreation support to context_validate_onscreen_formats
fixme:mlang:fnIMLangFontLink_ResetFontMapping
fixme:advapi:UnregisterTraceGuids 0: stub
Hi Alex,
> Hi everyone!
It looks like the Direct3D to OpenGL translation layer of WINE is not working properly for you there.
That could possibly be a bug in WINE or it seems that often the video drivers on Linux can tend to be pretty buggy as well.
You might try a previous version of WINE or try a different version of your video driver.
Unfortunately getting a reliable video driver working on Linux seems to be a big problem.
Wow! The program works on my Kubuntu!
I deleted all the Nvidia drivers and installed new Nvidia manually from the site. And the program started!
Thank you all for your advice and all the luck!
Hello:
Finally, I got MoI under wine too!
Unafortunately, it doesn't run fine. There are a delay between I click on the mosue and I see the point on the screen.
It's too much delay for considering this method like a real option to get MoI in Linux. :-(
I have:
Linux Mint DE 64 bits
Wine-1.3.29
MoI v3
Seems that hardware acceleration runs ok.
My graphic card NVDIA 6600 GT
Then, ¿It's normal this slow behavior?
Could anyone that uses MoI under Linux give any trick, or information about his machines,SO,wine version, etc...
Thank you
Hi David, if everything is working ok then I wouldn't think it should be normal to see a delay like that.
It seems that by far the most common issue for running on Linux is problems with the video driver. There seems to be a few different types of video drivers that you can install, one is the built-in "nouveau" one and then there is the nVidia proprietary one. If you are using nouveau currently then you might try switching to the nVidia proprietary driver instead and see if that behaves better.
Thank you Michael.
Actually, I have installed the propietary drivers.
On the other hand, I have started MoI from the console, and I have a bunch of messages (always the same) when I start:
fixme:win:EnumDisplayDevicesW ((null),0,0xe4f8e4,0x00000000), stub!
QWebInspector: QSettings couldn't read configuration setting [resourceTrackingEnabled].
fixme:win:EnumDisplayDevicesW ((null),0,0xe4dcc4,0x00000000), stub!
fixme:d3d:resource_check_usage Unhandled usage flags 0x8.
but, when I try to draw anything, I have a lot of messages of errors.
Example, if I draw a line:
fixme:imm:NotifyIME IMC_SETCANDIDATEPOS
fixme:imm:ImmReleaseContext (0x10072, 0x189048): stub
err:ole:marshal_object object doesn't expose interface {1430ab25-4fb6-44b9-8184-cce9ed3bd7d2}, failing with error 0x80004002
err:ole:ClientIdentity_QueryMultipleInterfaces IRemUnknown_RemQueryInterface failed with error 0x80004002
Maybe is better if I ask about that in winehq forum, ¿isn't it?
I have trying more....
Each time I press the L-button, I get that (only with 1 click):
8-27
28-47
48-67
68-87
88-105
