Show messages: All
1-5
6-17
Using Pilou's example....
mobius_strip.3dm
Cool try!
Model by Danny
if you are interested I have made this little prog :)
It's for Processing (free) but you can adapt for any language :)
http://processing.org/
A little fractal effect
Just put your image in the Data folder and copy past these few lines : it's all ;)
size(1024,512); // your image's size in pixel
PImage pilou = loadImage("your image.png"); // any image with a subject + transparent background
int t = 8; // minimum height size in pixel
for (int k = 8; k < 513; k = k + t) { // increase width and height
for (int y = 0; y < 513; y = y + k) { //position x,y of each new image on the screen
for (int x = 0; x < 1023; x = x + k*2) {
image(pilou,x,y,k*2,k) ; // draw an reducted image at the x,y position on the screen
} // end loop x
} // end loop y
filter(INVERT); // invert colors between each new screen, you can erase it
t=t+8; // increase height size in pixel can be anything
} // end loop k
image(pilou,0,0); // draw at the end your image :)
Have fun fractalising !
a little model by me :)
Thank you all for your answers!
Michael, but better in the next version of tools to make the deformation geometry, such as Twist, Bend, and so on. This much reduces the time to create complex models, such as Möbius strip, and increase the chances of your wonderful program!
Once again, thank you, all you really helped me!
Alex.
and Pilou has been doing this since zbrush v1 :)
Doesn't this indicate there is a concept :)
And yet, they are still beautiful :)
Here is one I did a while back. I hope to do a video tutorial someday :-)
Michael T.
Looks nice! Thank you.
Ouch, my description was wrong...it tells you to do a 360 degree rotation of the lines and not a 180 degrees rotation, sorry. With a 360 degree rotation of the lines someone can create a cutting object* for a split torus model (Keizo Ushio stone sculpture)...;-)
*Simply cut a torus with it in two halves and then arrange the parts shown like shown in the picture.
http://www.youtube.com/watch?v=6V6DQKAe3DM ;)
http://jlsdiseny.blogspot.com/
One possibility :) (loop curve can have an infinite combinaison)
file 3DM
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/moebius.zip
Some funny images found on the Net ;)
Wow - Moebius bread!
It's only made once a year... Presumably on August Ferdinand Möbius' birthday ;-)
Created in MoI:
RibbonMobiusLoftFINAL03.3dm
RibbonMobiusSweepFINAL01.3dm
Show messages: All
1-5
6-17
