Full Version: Random color script
Show messages: All  1-11  12-18
28 Nov 2010   [#12]
Works like a charme! You rocks!
http://moiscript.weebly.com/randomcolor.html
Speedy test!
Ps No problem but there is a white color who is not inside the default Style
28 Nov 2010   [#13] In reply to [#12]
Hi Pilou, I'm glad that will work for you!
What options do you have enabled under Options > View > Lighting options, did you turn on the option for "Specular highlights" in there?
That option makes white shiny spots on objects, so turn that off.
28 Nov 2010   [#14] In reply to [#13]
Yes it was some enable Metallic Lights :)
28 Nov 2010   [#15]
Seems Styles are losted when you export as SKP file
Is that normal?
28 Nov 2010   [#16] In reply to [#15]
Hi Pilou, yes currently styles are not exported to SKP format.
One reason for that was that I wasn't sure how they should be exported - SketchUp has a couple of different ways for assigning colors, there are both Layers and Materials.
I think with the previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3790.16 it was resolved that Layers are not generally used in SketchUp so that styles should be exported as Materials. That's something that I will be trying to add in for MoI v3.
28 Nov 2010   [#17] In reply to [#16]
Cool :)
29 Nov 2010   [#18]
Hehe, yes, I'm also very interesting in coaxing Michael into adding basic rendering into MoI :)
(even for 2d stuff)
Would cut out 2 or 3 programs in my workflow LOL
