Full Version: mesh edges not aligned when exporting (Closed)
Show messages:  1-13  14-33  34-53  54-73  74-93  94-113  114-123
3 Dec 2010   [#74] In reply to [#71]
Hi, everybody – Sorry to hijack this thread for a quick question...
I'm a new user, and I'm looking for a rendering application to use with MoI. Michael - you mentioned Cinema4d for N-gon support. And I also read, that there's Modo, which complys to N-gons and preserving normals, when imported from MoI. Is there anything else you could recommend?
Regards,
Sebastian
3 Dec 2010   [#75] In reply to [#74]
Hi Sebastian, Cinema4D and Modo seem to be pretty popular right now.
If you want something less expensive, Carrara could be a good fit:
http://www.daz3d.com/i/software/carrara8?_m=d
A few other discussion threads on this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3136.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3652.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3401.1
But there are quite a bunch of various renderers out there and many have a focus in particular areas, like some are focused on production for rendering movie stills, some have a bunch of stuff in them for making outdoor scenery, some are more focused on more hobbyist type use, some do both rendering and animation in the same package and some only do rendering, etc... etc...
So it can depend on what in particular you want to do with it.
3 Dec 2010   [#76] In reply to [#74]
Hi Sebastian, also a fairly new renderer that several people here have tried out and liked is Simlab Composer: http://www.simlab-soft.com/3d-products/simlab-composer-main.aspx , their rendering-only edition is $149.
For exporting to Simlab you may need to use OBJ format with "Quads & Triangles" output rather than n-gons though. But n-gons are not required to get a good rendering, they're more of something that are nice to have just to keep the wireframe nice and tidy. Support for the vertex normals is much more important for getting a good looking final rendering.
3 Dec 2010   [#77] In reply to [#76]
Hey, Michael
thank you very much for all those suggestions and reads – I'll have a look into those.
Regards,
Sebastian
3 Dec 2010   [#78]
I remember a discussion on Modo forum, where someone qualify MoI mesher been "bad" because the topology was not sub-d friendly :)
Btw I dont know for C4D, by when you start messing with MoI topology in Modo (merging, flipping poly etc), you just introduce all kind of shading artefact because the vertex normal is not right anymore.
Otherwise, the rendering is just perfect with MoI ngones, I dont remember any glitches since one year or so ...
3 Dec 2010   [#79] In reply to [#78]
Hi PaQ,
Yes, some people seem to expect that it should magically create the same topology as a highly experienced sub-d modeler would do by hand... And no doubt, that certainly would be cool if it could optionally do that (optionally because as I mentioned previously sub-d friendly topology and sparse wireframe n-gon topology are actually different things).
Unfortunately that level of expectation is what I'd call "pretty highly unreasonable" though. It's very difficult for software to replicate things that require a kind of case-by-case human judgment to them.
There are some interesting new auto-topology tools in 3D-coat recently but that overall technique is more for a kind of all smooth blobby sculpted shape and not really for CAD solids so much, particularly with a mix of large and small features.
I'm not 100% sure but I think C4D will automatically delete the vertex normals if you do some editing operation that makes them invalid.
It would be good for Modo to do the same thing as well, just automatically delete the vertex normals if you do something that modifies the shape of the mesh like pulling some individual vertices around.
The vertex normals information is something that should be tied to the current particular shape of the mesh. If the shape changes it just does not make sense to apply the same normals from its previous shape to its shading, yet that is what happens in Modo currently I guess.
But it's also good for the vertex normals to be kept and transformed with operations where it is possible to do so, like if you transform the whole mesh (like by rotating or scaling it so the overall shape of it stays the same), or also flipping a chunk of mesh does not need to invalidate the normals it can just flip them as well. It's not really very complicated stuff, so it's kind of surprising and frustrating that this is often not handled well.
3 Dec 2010   [#80]
**It's not really very complicated stuff, so it's kind of surprising and frustrating that this is often not handled well.**
Yes, thats true. I own Cheetah3d (MAC only, since I run MoI in Parralels) and was asking the developer over at the forums, what's happening. He told me, that vertex normals are recalculated automatically on import. So there's no chance I use this as a renderer without having to "polyflipweld" my ass off. :-)
Regards,
Sebastian
3 Dec 2010   [#81] In reply to [#80]
Hi Sebastian - that's unfortunate re: Cheetah3d not using the vertex normals from the file and instead calculating new ones, it's discarding some important data there. With CAD data, it's never going to be able to calculate the same normals since all it has to work with are a bunch of facets and not the original NURBS surfaces.
One thing that can help somewhat with that is to try and make a more finely diced up export from MoI, using the "Divide larger than" option to break polygons down to a more uniform size. But even then you're still going to see various imperfections in the shading. It's soooooooo very much better to have the true vertex normals - getting the true vertex normals over results in a super smooth and perfect looking render without any messing around at all.
Automatically calculated normals don't work very well with things like a large polygon face right adjacent to a bunch of small polygons for a rounded edge, it's too easy for the little poly on the rounded edge to overly influence the shading on the large polygon with stuff like that, and that kind of large flat face next to a rounded edge is a common kind of structure with CAD models. More organic sub-d models tend to work ok with automatically calculated normals because they're typically constructed out of all the same general sized polygons that kind of gradually bend around.
So some rendering programs that have become very focused just on dealing with sub-d models may not really know how to deal with CAD data that has a different structure than organic sub-d type models. But that's becoming fairly rare now, most renderers out there are able to import vertex normals these days.
4 Dec 2010   [#82] In reply to [#81]
I've tried various settings with the MoI exporter to use the mesh with cheetah3d - nothing worked without glitches. The only semi-acceptable solution is turning off "weld" so you get phong breaks, where the faces meet, but the surface of single faces are completely smooth.
I think I don't get around buying modo for this. Theres actually no other software for MAC, that lets you edit UV, imports normals from CAD and has a great renderer...and won't make me beg for a credit at my local bank (like autodesk would)
4 Dec 2010   [#83] In reply to [#82]
Hi Sebastian, yes the "edit uv" part kind of narrows things down somewhat.
Although another possibility might be to use a dedicated UV editing utility for that part, like UVMapper http://uvmapper.com/downloads.html there seems to be a "classic" version there for the Mac which looks like it is free, so that may be worth checking out to see if it can do the uv editing that you want.
Then that would enable you to use something like Simlab Composer for rendering which also has a Mac version I believe.
But it sounds like Modo or Cinema4D would have all of what you are looking for in just one single package so that could definitely be useful.
5 Dec 2010   [#84] In reply to [#83]
Ahh Ha! I found a quicker workflow to importing a model into 3DS Max without normals. It's v6 ;)
This model "Thank you to Steve, it's and excellent test" was imported as an obj using moi's output to ngons.
NGons came in great, but I knew I'd have to add smoothing groups. No biggy usually auto smooth at 45 degrees is great.
I added an edit poly, welded points as far as possible without damaging the model.
Then selected all polys and clicked the retriangulate button.
All that was left to do was less then 5 mins worth of edit triangulation, to turn some edges to eliminate sliver type polys.
Finally selected all polys and added auto smooth 45 degree. Any more bad smoothing errors will show up as to many smoothing
groups. This time however it created just 2 groups using auto. One flat grp, for the bottom, and the rest of the model for the other.
The moral of this story for me:
I think what I've learned from this thread is that you can't get away with not tweaking your model in some form or another
in your final rendering software. That is, it's very rare not to. ;) For me same has gone for C4D even 11.x. But being a well
seasoned veteran of polys, it's probably something I look at more closely then most CAD users. Although, you can see by my
3DS max version it hasn't been my full time career since at least 2005. ;)
To Steve's defense:
By the way yes slicing can take time to workout in Moi but can be a great way to force a sort of poly structure.
Although I can't get it anywhere near as clean as the radial sliced model shown earlier in this thread.
My Sliced model in Moi
Not meant to be for meshsmoothing just as a way to tidy things and force better smoothing groups in polygonal renders:
In retrospect, I'd say well over 75 percent of polygonal models I had created years ago with strictly 3DS Max required some
poly tweak or another. In particular when you had to use a boolean in that software. Booleans in polygonal software require hefty
point weld edge turn etc...
Hope I'm not hijacking
5 Dec 2010   [#85] In reply to [#84]
Hi FlashFire,
I'm kind of confused about how you ended up with this moral.
What is it that you are trying to use the model for in your final rendering software that forces you to tweak the model?
If you are actually rendering it (which is quite frequently the thing that many people do when importing models into rendering programs), then no there should not be any kind of tweaking required at all, just import the model, then render it and that's it....
Just make sure that you are importing vertex normals, that's the key thing that makes a great looking rendering _without any additional tweaking_ !!
Here is a simple example with that same block model.
You load the model into MoI, it looks like this:
You save from MoI to OBJ format, the polygons generated look like this:
You then import the OBJ into Cinema4D, and without needing to do anything special, you just render it and it looks like this:
So note there that the amount of extra tweaking is none! For rendering, that should be the normal thing, it is not required to do any additional poly tweaking if you want to produce nice looking renderings from your model.
If you want to reduce jaggies in silhouettes or something like that, then you do that by tweaking the export settings from MoI, which will usually involve just moving the slider over to the right some more to generate a larger number of polygons.
Do you have any example model that you can post that you were having a problem with rendering in Cinema4D ? If you post it, I can help show you how to get it rendered nicely in Cinema4D without needing to actually mess around with tweaking any polygons in C4D.
5 Dec 2010   [#86] In reply to [#84]
Hi FlashFire,
I think the problem is that you're so used to things working in the poly modeler by smoothing groups, that you mistakenly jump to the assumption that any kind of extra triangulation will cause some kind of shading glitches.
The part that you're not used to is that it's a completely different scenario when you get the good vertex normals to be used in the rendering.
When you get vertex normals that come from the original NURBS surfaces to be used in the rendering, it causes the shading to look the same as the NURBS surfaces instead of being controlled only by averaging between adjacent facets like with smoothing groups.
Here is a simple example - here I simply moved the density slider to the right when exporting out from MoI, and then imported and rendered the result in Cinema4D without any poly tweaking:
What area in particular do you think needs improvement? Which thing in the rendering are you looking at more closely than most CAD users?
5 Dec 2010   [#87] In reply to [#86]
Actually yeah sometimes even in C4D 11.5 i've had to fix smoothing glitches. Some polys even had to be flipped and
points get welded to eliminate wasted polys. It's like you mentioned, it's never perfect.
But this 3DS Max test was to see if I could find a faster method for use in Max. Since getting the model out of
C4D into max looses the normals as you know. Granted this version is old. I wanted to show that it's not that
bad to repair for those that might not have software that will import normals. As you pointed out even some newer
software can't do properly.
Wanted to also point out Steve's slice method was useful.
What I look at with scrutiny is the underlying wireframe. Since models created in the past were for resale.
I've been testing to be sure the wireframe will look great in all poly software such as 3DS, C4D, LW, etc.
Hopefully my testing is helpful to someone here.
5 Dec 2010   [#88] In reply to [#87]
Hi FlashFire,
That should not be a normal thing to have happen, and it may mean that you need to adjust some settings when you export the mesh from MoI.
For example something that is pretty big but only shallowly curved will not get a lot of polygons put on it when using the angle setting alone, so if you have something like that you may need to use the "Divide larger than" setting to force additional refinement when exporting the mesh.
> Some polys even had to be flipped and points get welded
"wasted polys" doesn't have anything to do with getting a perfect looking rendering, just as long as the good vertex normals are being used.
If you had some polys that needed to be flipped, that may mean that you have some individual surfaces that were not joined to each other - make sure they are joined together so that they can have a single unified mesh created for them instead of having them meshed individually.
You should normally get a perfect render, just like the example I posted above.
If you have a model that does not produce a perfect render without tweaking any polygons, please post the model so that I can test it and give you some feedback on things you can do to make the rendering look perfect without needing to tweak any polygons in it at all.
It should never be needed to tweak polygons or do manual splitting up just in order to get a perfect looking rendering.
What I was referring to earlier with C4D n-gon problems is a very rare thing, and I've only seen it actually be an issue if you started to tweak the n-gon points around and even then only in some particular situations. I have not seen one yet where it was a problem just rendering it directly without trying to pull polygon points around.
5 Dec 2010   [#89] In reply to [#87]
Hi FlashFire,
That does not have much to do with the appearance of the rendered output when the true vertex normals from the original NURBS surface are being used.
That's what is different from what you may be accustomed to with using regular poly modeling and smoothing groups to have the vertex normals created just by averaging the normals of adjacent polygons.
5 Dec 2010   [#90] In reply to [#89]
Well I should clarify, since the problem I once had was with a joined model. It needed some points/edges to be
edited in C4D. I too was shocked to see this from software that imported normals.
Would you not agree that in many cases CAD models are not poly efficient models? They tend to use to many polys at times
to describe a shape that could otherwise be shown even in a high poly res with less polys "after human editing".
In those cases it's nice to import ngons and be able to dissolve unwanted edges or even whole rings/loops, to create a much more efficient
mesh. Even older versions of 3DS have more poly editing functions then C4D. Which is why I tested the model in MAX. There are
many modeling scripts available for 3DS as it's far more popular.
This is what I've been after that a human can do, create efficient topology. Not had much luck with auto topology programs.
And honestly think they are overkill/re-inventing the wheel, for a cad model. They seem best for organic things. I'll use mudbox.
I think I may have made you feel I was re-inventing the wheel, which is not what I intended.
But I'm sure as time goes on more efficiency will be seen. As a matter of fact, customers at Turbo-squid are now voicing there opinions
on the lack of some artists poly efficiency.
The 3DS max render you saw earlier in the post could pass as somewhat efficient. Deleting a few edge rings would make for
a cleaner mesh.
Crossing fingers that C4D 12 will add even more poly editing.
5 Dec 2010   [#91]
I think what confuses the issue is the way that C4D and other poly modellers treat NGons.
If you create an NGon directly in C4D, the internal triangulation of that NGon is a bit arbitrary, particularly if it is non-coplanar. The smoothing algorithm then tries to smooth across those triangles, sometimes creating artefacts. Incidentally, the same thing can happen with non-coplanar quads.
However, when you IMPORT an NGon with vertex normals, each vertex has it's own normal, and the internal smoothing algorithm is turned off, resulting in artefact free rendering. In Modo this is even more evident. Where vertex normals exist, changing the smoothing angle for a mesh has no effect at all.
@flashfire - I'm not sure I understand your point about the models being "poly inefficient". The number of polys you use, whether manually or created by something like MOI, is dependent on how you want curved surfaces to look, and this is determined primarily by the angle at poly edges. The smoothing algorithm (Phong and others) can only cope effectively with small angles. Once you go above those angles, smoothing artifacts appear. Also additional edge loops are needed to cope with any transitions from curved to flat surfaces, which are not needed when vertex normals are present. Using sub-d with a low poly cage, is not the same thing as the sub-d is adding polys back in.
5 Dec 2010   [#92] In reply to [#90]
Hi FlashFire,
> to be edited in C4D. I too was shocked to see this from
Could you post the model, or e-mail it to me at moi@moi3d.com ? I will check it to make sure it is joined.
There are also other kinds of problems than joining that are possible, for example things like self intersecting surfaces can then produce polygon output that has polygons folded back over top of themselves as well.
If you post the model it would enable me to analyze it and better describe what was wrong with it and what you can do to avoid that. For example if you had a kind of curly-cue loop in one of the original curves you used in construction that will then create a self-folded surface from it as well.
Sure, but the part that I can't seem to get across is that does not have anything to do with the rendered appearance.
If your main goal is to produce a good looking rendering, having a supremely poly efficient model does not particularly help towards that goal (when the true vertex normals are being used of course).
> create a much more efficient mesh.
Why? Why do you go through all this effort when you can get a completely perfect looking rendering with the original model before doing all this extra work?
Once again here is the example model from earlier in this thread:
What is wrong with the rendering that makes you want to tweak the polygons? By tweaking, you're much more likely to actually introduce a worse quality rendering than what you've already got without any extra work. That's what's pretty baffling to me about what you seem to be trying to do...
Why do a bunch of work for a lower quality rendered result? If you edit the polygons you're never going to get as perfectly smooth of a render that looks completely identical to the original NURBS model as that rendering above does.
5 Dec 2010   [#93] In reply to [#91]
Hi Steve,
Yup, this is absolutely correct - imported vertex normals completely take the place of any kind of "break angle" or "smoothing group" type smoothing mechanisms.
Those other kinds of mechanisms like a break angle method only work by averaging together the normals of all the faces that share a vertex, which can be affected by the polygon topology.
A rendering with imported vertex normals does not have shading affected by topology at all - the imported vertex normals completely define how the polygon is being shaded, neighboring polygons don't have any influence on it.
Additionally with CAD model imports, the vertex normals are very accurate because they come from the original CAD data. Things like a part with a sphere in it will have the exact vertex normal from the original sphere surface, etc... There's no way for something that cooks up normals just by averaging already faceted data to come up with the precise original normals like that.
