Full Version: Feature Wishlist 2D Curve Import from CAD format.
Show messages: All  1-2  3-5
8 Sep 2010   [#3] In reply to [#2]
And that will bring in just the lines, radii, and curves without having to be converted to surfaces first?
8 Sep 2010   [#4] In reply to [#3]
I think it will bring in everything and you will have to seperate or delete the surfaces. Make sure in MoI in the options that you have IGES import set to not stitch it to solids.
Or you can delete the surfaces in TC first without saving and then try to export IGES.
I'll try to do this when I get home and let you know more later.
Michael T.
8 Sep 2010   [#5] In reply to [#1]
Hi Drakonsden, I do want to add DXF support in the future.
But yes IGES files can also contain curve information like lines, arcs, and 2D or 3D spline curves, not just only surfaces.
So it should be possible for you to use IGES format to transfer curve data over to MoI.
You could also try STEP and SAT formats for that as well.
