Show messages: All
1
2-4
Hi 3dcnc, check out this previous post:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2888.11
That has a plug-in that make a new command in MoI called MarkOpenCurveStart , and when you set that up on a keyboard shortcut it will create a point object to mark the starting endpoint of an open curve.
Oh wow, I've needed this command quite often LOL
Yay!!
Happy Cabbage ^_^
Thank you . for the tip.
I don't know if this is possible, but it might be useful for the surface command to automatically put a point at the open section of an open curve if the planar command fails, so you can quickly fix the problem. (just a thought)
Show messages: All
1
2-4
