Full Version: Curve start point needs to be visable to help close open curves.
7 Sep 2010   [#1]
Hi
I extracted some curves with Moi and wanted to create a surface with planar surface creation. the curves were joined but not closed. Is there an easy way to find the point where the curve needs to close.
3dcnc
7 Sep 2010   [#2] In reply to [#1]
Hi 3dcnc, check out this previous post:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2888.11
That has a plug-in that make a new command in MoI called MarkOpenCurveStart , and when you set that up on a keyboard shortcut it will create a point object to mark the starting endpoint of an open curve.
7 Sep 2010   [#3]
Oh wow, I've needed this command quite often LOL
Yay!!
Happy Cabbage ^_^
8 Sep 2010   [#4]
Thank you . for the tip.
I don't know if this is possible, but it might be useful for the surface command to automatically put a point at the open section of an open curve if the planar command fails, so you can quickly fix the problem. (just a thought)
