Show messages: All
1-3
4-8
The tricky part with compatibility would be what to do with objects that were assigned to a "parent" layer in Rhino.
In the folder concept, the folder itself would not be a style or layer, it would just be a container. Objects would not be assigned just directly to a folder, they would be assigned to one of the styles that were contained inside of the folder.
Maybe I could give compatibility if you did not have any objects assigned directly to parent layers themselves in Rhino, like if you were just using those layers as placeholders to contain a bunch of sub-layers only. Then those empty parent layers would be able to be mapped to a folder in MoI.
I'm not sure why the groups have to be related to styles...
But I would really like the added functionality of groups in MoI.
So you could assign soem objects to a named group, and then they'd all move/rotate/scale together (unless you go inside the group, then you can edit the objects individually).
The more I use MoI (for larger projects) the more I find myself wanting groups :)
Hi NightCabbage, yeah there will be something called a "group" like you are talking about that will be separate from what's being discussed here.
The option that I'm talking about here is just to help organize big lists of things in the scene browser.
Like for example say you need to make a model that has 500 different styles in it. That would make for a very long styles list and browsing through the list can get tedious. But if it was possible to organize the styles by putting them in a folder type list that could be useful. That way you could collapse many of the folders to keep a lot of those styles out of the way from the currently visible list of styles.
It would not be meant as a replacement for an object group, it would be something additional to that just as an option to use in the scene browser lists of stuff.
Ah cool ok, that sounds good too :)
Hi everyone,
Remember, MoI is NOT Rhinoceros. It's better:-)
Michael T.
Show messages: All
1-3
4-8
