Full Version: MoI slow to start
Show messages:  1-15  16-21
8 Sep 2010   [#16] In reply to [#15]
Hi Nick, well that would seem to be the problem.... ;)
Pick something like your favorite 1000 of those and get rid of the rest and that should probably zip things back up again.
Otherwise I guess that you will probably see this delay at odd times in a variety of apps, in some it may be when you go to edit a text document that lets you pick different fonts in it like a word processor.
Message 3743.17 was deleted
9 Sep 2010   [#18] In reply to [#16]
Ok Michael. I was trying to rebuild the font library I had had previously. But, I got side tracked and then forgot to get rid of the ones I dont need. Oops! I will do that soon and give you the result.
“Here's to alcohol: the cause of, and solution to, all of life's problems.” - Homer Simpson
-Nick
9 Sep 2010   [#19]
MoI is back to normal with default fonts. Thanks for your help, Michael. I guess that problem/solution can go in your troubleshooting guide. :-)
-Nick
9 Sep 2010   [#20] In reply to [#19]
Hi Nick, that's great that it is back to normal, the dump analysis paid off!
Yes, I will have to add that to my troubleshooting checklist: Have you recently been drinking and handling fonts? :)
9 Sep 2010   [#21]
If you like your fonts you can always use a font manager, there are a few good freeware/open source ones out there.
