Show messages: All
1-2
3-8
Not on a curve, but on an arc, line, ... ;)
If you have the "Show edit Frame" enable you will see the middle of this box for transform resize...
but Michael answsered before me with a nice trick :)
Thank you for that . That was quick
> middle of it for transform resize...
That's the "center of the curve's bounding box", which is different than the "midpoint of the distance as traveled along the curve".
Here's an example of that kind of midpoint:
In my Cad/Cam package, the points tool has some options... "Point on entity by Distance/Percentage." It's very handy.. If you could look into this, I think it could be a great addition to the point command.
Hi Burr, I was kind of thinking in the future that there could be some option for that in an extended properties dialog box for curves...
< That's the "center of the curve's bounding box", which is different than the "midpoint of the distance as traveled along the curve".
yes :)
If for that I that I had rectify "of this box" but as always you will so speedy that you have seen my previous version :)
Show messages: All
1-2
3-8
