7-24
Hi Burr,
> You just need to get 2 files to put in the folder with it.
> The license key and the ini file.
Yup! Just one note - if you have a v2 upgrade version then you'll want to actually copy 3 files - the moi.ini file for your settings, and then both the v1 and v2 license key files (moi_v1_license.key and moi_v2_license.key).
Then you are all set up to just run moi.exe directly off of the USB key, and it will find those license key files and not prompt you for them.
Just wanted to post a couple renders from Octane of this model. Always good to see a little more than a screen-shot.
Looks like there are still normal rendering problems with Octane ?
Not quite certain there, as I need to bring the model into Maya to do texture mapping. The problem might come in there, but Octane is still quirky, as it renders quite fine in MR. Notice also on the metal part of the USB, there are supposed to a square hole on either side. They are there on the model, but not in the Octane render.
Anyone currently working a MoI > Maya > Octane pipeline, export methods/details would be much appreciated.
Can you post the file so that I can have a look?
Any help would be appreciated - here is the file:
USB_stick.3dm.zip
Yeah, maybe it's maya that discard the normal information when UVmapping?
Maybe testing a direct Moi export in Octane.
I also remember having these kinds of issues with ngons in Octane.
Marc
Thanks for posting the file. I'll have a look tonight.
I exported this straight from MOI and right into Octane without using any additional software. Rendered for 2 minutes using Path Tracing. I think that something happened when it was re-exported from Maya. I just assigned a bunch of styles for the various parts and adjusted them in Octane.
Here's a 23 second Direct Lighting render
What a selective DOf :)
Hi Phr0stByte, also one other note - when you export out from MoI for later import into Octane make sure you un-check the option for "Weld vertices along edges" on the meshing options dialog.
That may have been the initial problem.
The other thing to look for with Maya is if there is some option to enable to write vertex normals into the OBJ file. If that was disabled for some reason in the Maya export, that could also cause those kinds of shading problems.
Yes, I don't think the problem is not MoI, and I am sure Something is happening with the export from Maya (2009). I will have to investigate further over at the Octane forum (as I said before, it renders fine in mental ray). Octane is just very picky about things. I was looking at the section where they have screenshots of all the different 3d apps export settings, but no Maya (am I an odd-ball using Maya? How dare I?). Anyway, off to continue my hunt for an answer/solution. Nice renders PHILBO!
It is recommended that you use the Maya plug-in instead of manually exporting. This will also give you access to Animation functions as well. You can then post specific questions on the plug-in in the Maya section of the Plug-In Discussion / Support section of the Customer Forums at
www.refractivesoftware.com/forum/.
I will give the exporter a try. I was hesitating on that because I am on Linux, and the exporters don't always work correctly. I will also play with exporting FBX from MoI. I need Maya for texturing. I only have a license for MoI v1, and I am thinking very hard if $100 is worth v2 for "styles" and the other newer functions.
I tried to just use 1.0 after using the Beta V2.0 for so long. I couldn't hack it and had to pony up the $100 for the upgrade.
If things don't work out on the Linux side of things, please post it to the forums so they can get resolved.
Just sprang for the v2 upgrade license. MoI puts real fast wheels on my production time and Michael deserves it (if not more - the price is WAY reasonable).
Thanks Phr0stByte, I hope that you will get some good use out of v2!
There's quite a lot of new stuff in there, there is a collection of all the notes on new and improved features in v2 here:
http://kyticka.webzdarma.cz/3d/moi/doc/V2releasenotes.html#V2-out
7-24
