Full Version: Beveled Text
Show messages:  1-6  7-26  27-46  47-51
2 Oct 2020   [#47]
For MoI serif font Times New Roman, used the sweep technique with two 45 degree lines, for D and R. Manual trimming required. Did C with Merge. The 3d letters look good.
2 Oct 2020   [#48] In reply to [#46]
Cheers chaps will take a look at some of these routes but not likely to dive into fusion at moment.
Unless it's easy to get a finished result...
@Brian- I presume setting the 45degree line at a length greater than the widest 'stroke width'
of the letters should cover most shapes and mean minimum extensions required....
Btw...i also challenged a friend (autocad expert user)
with these but he was not confident he could do any faster.
Work in progress!
2 Oct 2020   [#49]
Somehow, my custom style colors reverted to default. Colors were easily restored from AppData colors2020...3dm file.
-B
2 Oct 2020   [#50] In reply to [#48]
The more speedy will be to found a 3D Font yet existing and with nurbs export 3D format!
2 Oct 2020   [#51]
https://www.adobepress.com/articles/article.asp?p=1743636&seqNum=2
Only 256 - 33 - 2 characters to do. Times 5?, plus unicode, plus spacing + ? :-)
I wonder if Flow could convert the 3D fonts to italics?
Bold?
Only about 306,729 +/- fonts exist today, to search. (per one website:-)
Would the 3D font actually be classified as a font?
