Full Version: Beveled Text
Show messages:  1-9  10-29  30-49  50-51
18 Aug 2010   [#10] In reply to [#8]
Hi Burrman,
I have had a quick look at the thread you linked to. I am seeing that as a possible solution to using a single cutter giving a result of a variable depth cut. I will look more at the thread later, but I did not see a way to catch the problem from the need of a circle from 4 points at the corner intersection of various letters.
- Steve
18 Aug 2010   [#11]
Well in all honesty, I don't really want beveled text at all. What I'm trying to do is actually linked to Greybeard's thread on the CNC Zone and that is to find an easy way to create and then extract the centre line from the 45 deg surface of the text characters, along with the Z depth information. If I can do this easily, it will allow me to do VCarve lettering on my CNC miller. So far, I've come up with a couple of ways to do it, but there always seems to be something that makes the process long winded, although not impossible. I find the tangent circles method is a very time consuming way of doing it manually.
Here's a pic of 1 letter that I've run through the process and simulated in CutViewer.
Martin.
18 Aug 2010   [#12] In reply to [#11]
Hi Martin,
The line where the 45 degree angle surfaces intersects will be of varying height though.
If that's what you want though, you can use a similar technique that I posted earlier - draw a 45 degree angle line and sweep it around the curves. This will produce all kinds of crazy surfaces but then you can run the Construct > Curve > Isect command to generate the intersection curve between those surfaces.
You may want to do something like use Edit > Separate on the text path first so that you have all separate curve pieces for the path, that will prevent MoI from doing its own intersections to produce mitered corners. You may instead need to do some extensions yourself in that case though.
Here's an example - here I drew a 45 degree angle line in the Front view and moved it off to the side (this will active "auto place" mode for sweeping), and used Edit>Separate on the text to break it into individual segments:
Select the angled line, then run Construct > Sweep, and pick all the path segments as the sweep rails. That will generate a result like this:
Now select all those surfaces (easy way to do that is to use the Scene browser Types section, click on the text for "surfaces" in that section to select all surfaces), and run Construct > Curve > Isect to generate intersection curves. That will produce this:
Delete all those surfaces now (again use the Types section of the scene browser to select them more easily), and you are left with this:
Now you can go to each of those corner areas and clean them up using Edit > Trim, select 3 pieces like this:
Then run Edit > Trim, and right-click to indicate you are doing a "mutual trim" where all the objects are cutting each other, and pick these fragments to discard:
That will leave you with a corner like this:
If you repeat that on the other corners, you will get a result like this:
Or as seen from the top:
centerline1.jpg  centerline2.jpg  centerline3.jpg  centerline4.jpg  centerline5.jpg  centerline6.jpg  centerline7.jpg  centerline8.jpg  centerline9.jpg
18 Aug 2010   [#13] In reply to [#12]
Hi Steve...
""""""""""I am seeing that as a possible solution to using a single cutter giving a result of a variable depth cut.""""""""
Well yes that is Greybeards ultimate goal. I posted the link for 2 reasons. In the very begining, he gives his method to prgamatically determine centerline for the times new roman charater.. He just iterates through tangent circles then draws a curve through points with the circles center points to create centerline.... The rest of the very arduous thread, gets into some other discussion like you mention, but also touches on the various complexities of "What is really the centerline anyway???"
Here' s the file I was going to present with the initial greybeard iteration:
But that was just blown out of the water with Michaels isec example with some quick trims... Way more work to create each letter with my method...Less than a minute to create the curves with MG's, then some setup for sweeping surfaces....
Found one cool thing in Michaels method... When you run isec...Just click the right mouse button "twice", which will run the isec on the curves a second time and create "points" at their intersections, which helped me visualize the areas I needed to focus on....Bonus!!!
Anyway...
18 Aug 2010   [#14] In reply to [#13]
Hi Burrman,
Michaels methods is quick, although I would avoid using the actual letters for the surface creation.
The letters are OK for printing etc, but for smooth curves they can be quite bad, and would rebuild them before using them for building the surfaces.
- Steve
18 Aug 2010   [#15] In reply to [#14]
""""""""""although I would avoid using the actual letters for the surface creation. """"""""""""""
Hi Steve,
Could you explain what you mean here? Here is the Times New Roman "I" from Michaels example, and i dont really see anything wrong with the surfaces created. This one was done with sweep. I also did one with loft that produced a surface with less control points in it... But it appears they both make a smooth usable solid.... ?????
Are you refering to just "fonts" in general as being poor geometry to start with?
18 Aug 2010   [#16] In reply to [#15]
Yeah often times fonts can have pretty messy curve structures, things like many small segment fragments, slight kinks in between pieces instead of being tangent, stuff like that.
Those kinds of things don't particularly have an effect on making a 2D filled outline (which is what they are originally created for) but can be not so good for treating them as 3D geometry. So a rebuild step could be a good idea.
But Times New Roman itself seems to be pretty cleanly constructed though, so it's possibly one case where it may not be necessary.
18 Aug 2010   [#17] In reply to [#15]
Hi Burrman,
>>Are you refering to just "fonts" in general as being poor geometry to start with?<<
Yes.
A simple example would be the capital A in that font, if you explode/separate the curves you will find where the curves split due to bad curvature. .
That causes the sweep to create joined surfaces around that section
In may not matter, its probably just me liking continuous surfaces where possible.
edit. It took me that long to write this, that Michael got a post in first. I am slowing too much these days LOL.
18 Aug 2010   [#18] In reply to [#17]
That's not particularly bad though, when fonts get messy they can get a whole lot messier than that, like 10 times as much segmentation...
18 Aug 2010   [#19] In reply to [#18]
Yes,
I have seen numerous times where users of nurbs applications have been trying to put rads around solid text edges then they wonder why it can fail.
- Steve
18 Aug 2010   [#20]
Generally fonts are created for a 2D use :)
It's an artificial mode to have them in 3D
It's an another work to make an alphabet in 3D :)
The famous Dürer one ;)
29 Sep 2020   [#21]
RE: bevelled text / vcarve letters / chiselled shapes
Can someone please let me know, how do i fill this shape into a solid...
Also as this post is quite old any faster / alternative ways to acheive similar results ??
V_Carve_I.3dm
29 Sep 2020   [#22] In reply to [#21]
I don't believe you can without make some reparations :)
so after : explode all
and make some Sweep (and other reparations because your file is a true mess! ;)
(Curves at jonctions are not on the good vertices so no joint possible, no symmetry etc...)
Better is redraw it than make repairs!
29 Sep 2020   [#23] In reply to [#22]
i was following michaels instructions on the "I" but likely did it too fast; will try again.
I could easily fix that missing 'joint' but only some surfaces would close if i clicked planar.
29 Sep 2020   [#24] In reply to [#21]
Hi Stefano,
The general technique is above in this same thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3723.12
For your case here to start with the curves need to be cleaned up so the pieces meet up exactly end to end and are precisely mirrored. You only need to bottom ones though, join those together into a single curve like this:
Then draw in an angled line here:
Select the line and run Construct > Sweep and pick the bottom closed curve as the rail path, that will generate these surfaces:
These are the surfaces you need but they need to be trimmed up. You can use the Edit > Trim command for that cutting them one by one but there is a shortcut you can use if your initial construction curves are clean and precise. The shortcut is that the boolean merge command can be used to extract out a center volume from a piece like this and slice away all the outer pieces in one shot. To use that you would need to put in a ground plane like this:
Now select all the surfaces and run Construct > Boolean > Merge and it can extract out the inner core solid:
3DM model file is attached.
Using boolean merge will be quite a bit faster than trimming each individual surface. But make sure your starting curves are cleanly constructed, ends exactly touching and opposite pieces mirrored.
V_Carve_I_solid.3dm
steve_I_sweep1.jpg  steve_I_sweep2.jpg  steve_I_sweep3.jpg  steve_I_sweep4.jpg  steve_I_sweep5.jpg
29 Sep 2020   [#25] In reply to [#24]
Already tried following your initial instructions which is how I seemed to get 'close'.
It seems all I need is a closed curve of the font outline and a 45degree line, no trimming
required if bolean merge used and artwork perfect...
Could you please verify if this dxf; the origination of the "I" is ok to start with...
Stefano
V_Carve_I.dxf
29 Sep 2020   [#26] In reply to [#25]
Hi Stefano, yes that DXF file works fine with the CorelDraw DXF import fix. It would not be a bad idea to replace the straight parts with simple 2 point lines. You can construct a solid without doing that but it might help with other operations further down the line.
Here is a screencap of the process just after opening that V_Carve_I.dxf file you posted:
29 Sep 2020   [#27] In reply to [#26]
Hi Stefano, additional notes - the curved sides of the letter in your DXF file are not exact mirror images of each other but it seems to work ok still. But the center line where the pieces intersect will have a little undulation to it instead of being straight because of that variation.
Also if you want to draw a 45 degree angle line, type <45 and push enter to enable angle constraint.
29 Sep 2020   [#28] In reply to [#27]
i will try and do it in 56 seconds - thanks again...might take me 57 minutes to get there !
29 Sep 2020   [#29] In reply to [#28]
