4-23
24-33
Hey cool, and not a easy shape at all to start with.
I have no clue how to build this myself, to finish with a perfect surface ...
Thanks Pak, yes it wasn't easy for that shape took me some time to figure out the best way to tackle this one. Most of this shape was done by using the loft tool. Working on the brake handle now, which is fun working on this though. Here is some wires, take care and thanks for the response.
Nice model Moe! will be waiting for some more details, maybe the wheels can be a little wider apart in the first few pictures.
Hi there here is some brakes finally been so busy. Let me know what you think, take care
Another small update, added gas tank and adding some textures still a lot to do
Here is a closer up on the gas tank and some more textures. I will dirty up before animating this. Thanks for any comments. I also widened the tire width but can't see on this image.
Hi Moe, it's really coming together well, nice amount of details you have added.
thanks for the reply, I love your program it gets me where I need to be to get things done easier and faster than to do a polymesh start to finish. Thanks again for such a great program!
Thanks Moe, I'm really glad that you like MoI and it is really fun for me to see what you are doing with it, thanks for posting your WIP!
Hi everyone,
here is a little work on the under carriage and engine parts, still a lot to do, take care.
Nice quad runner Moe!
I want a white-pink one for my three daughters...
But without Hello Kitty labels please!
FiL
Hi FiL,
thanks for the reply. Here is a little update only able to work through my lunch on this for now.
Humm...good!
And the red light back?
FiL
Another Small update, slowly moving this one!
Looking good :)
I like the metal look on some of the parts.
Thanks Nightcabbage!
Now working on the suspension. Here is a moi screen capture, once I model in Moi I then take it to Modo for placement and poly reduction, take care
Little Update
small update
Somemore updates. The front wheels are up higher than the ground for the shock setup which will be animated up and down while traveling
Hi there here is an update to the quad any thoughts?
4-23
24-33
