17-33
Another Small update, slowly moving this one!
Looking good :)
I like the metal look on some of the parts.
Thanks Nightcabbage!
Now working on the suspension. Here is a moi screen capture, once I model in Moi I then take it to Modo for placement and poly reduction, take care
Little Update
small update
Somemore updates. The front wheels are up higher than the ground for the shock setup which will be animated up and down while traveling
Hi there here is an update to the quad any thoughts?
Great stuff Moe. You could put some more clamping/bolt work/detail in the area where the handlebars meet the steering column...
It's really transforming and comming out nice.
Hi Moe,
Great job, Well done!!
regards Colin
Thanks Burrman and Colin for the feedback! Here is another one with more mud.
I am still thinking about the clamping/bolts I will be animating this and not sure how much farther I want to go with polygon details. If I was only keeping this still then I would then definitely add more detail. Anyway thanks for the advise take care
Coming along really well Moe! keep up the good work.
Hi Moe, it has come along really well, it looks pretty well finished up to me - time to switch to animating it?
Hi Michael and Danny thanks for the feedback. Hopefully this afternoon I will start the morphs for the left and right shock and a morph for the rear shock. This will help me so I will be able to control the heights of the wheels as it moves through the terrain I have created.
Take care
Last update for this one any thoughts take care
Looks great Moe!
Hi Moe, very good work!
Fil
Thanks you guys for the positive feeback take care
17-33
