Full Version: Top 5 Features list for V3 !
Show messages:  1-4  …  25-44  45-64  65-84  85-104  105-124  125-144  145-164  …  425-442
15 Jan 2011   [#85] In reply to [#84]
That's why I'm writing in the feature list for V3 ;-)
I'm thinking about something similar to 3ds max "show safe frame" feature.
15 Jan 2011   [#86] In reply to [#85]
Hi Luca I see - but that would be kind of weird to have some specific rendering oriented UI feature in MoI when it was not actually used for any purpose at all within MoI itself...
I mean probably something like "show safe frame" would not get implemented in MoI until there was some basic rendering included in MoI that would also make use of it.
Message 3628.87 was deleted
19 Jan 2011   [#88]
Variable filleting
Deformations
Wrap text around cylinder for engraving
Maybe some "hints" that pop up when an action fails (such as a fillet that fails). This could be turned off in preferences for the pros, but would a great asset for new users.
26 Jan 2011   [#89] In reply to [#88]
height reliefs wrapped around a curved solid surface
Thanks Michael,
Rudy
5 Feb 2011   [#90]
I am a new user learning MoI for jewelry production. If MoI could do surface treatments such as textures and reliefs it would be fantastic!
6 Feb 2011   [#91] In reply to [#90]
Hi sdwalker,
You're already able to get & use textures into MoI, here's a link for the Jewellery Forum I moderate at.
http://3dcadjewelry.com/forum/entry.php?22-Creating-My-Own-3DM-Texture-Files
HTH, Colin
6 Feb 2011   [#92] In reply to [#91]
Sorry we can't access at the link http://3dcadjewelry.com/forum/showthread.php?9944-FREE-Texture-File&p=132674&viewfull=1#post132674
Something i don't understand
This texture can be used for curvated surfaces in MOI ?
7 Feb 2011   [#93] In reply to [#92]
Sorry, but you'll need to join that Forum to gain access to those files.
"This texture can be used for curvated surfaces in MOI ?"
No, not directly, for that I'm using Rhino4.
regards Colin
7 Feb 2011   [#94] In reply to [#93]
thx for the info ;)
26 Apr 2011   [#95] In reply to [#94]
Network Continuity with surrounding surfaces.. (ok, I'm up to 3 now excluding the beer thing...:o)
26 Apr 2011   [#96]
A "load barre" advancement during the loading of a "big file"
it's more reassuring )
A "curve point" persistent against "control point" but I don't know if it's compatible with nurbs system
26 Apr 2011   [#97] In reply to [#96]
Hi Pilou, so are those your top feature requests for v3, meaning that you'd be happiest if just those features were implemented and not anything else?
For this particular thread, it would be helpful to make sure you are talking about your top priority features that you'd like to see.
26 Apr 2011   [#98]
I don't think I officially posted my top five yet. Any order would be fine.
- Surface continuity of surrounding surfaces for as many existing surface tools in MoI.
- Strengthen Fillet including variable, put it on steroids or something.
- Basic dimensioning and annotation tools, pdf output will be fine.
- Deeper history.
- Deformation tools.
-A disco mirror ball.
P.S. I've already mentioned a tighter tolerance switch, but that doesn't count for this post :)
27 Apr 2011   [#99]
my 5 five
Components replication system for big file as you know ;)
Point Curve against Control Point
Variable fillet
Zebra color checker over surface for see some wrong tension or tengency
Help messages when something wrong arrives :)
27 Apr 2011   [#100] In reply to [#98]
same as DannyT here :)
Oh if you could get a T-Splines & Ledas partnership, Ill be complete :)
27 Apr 2011   [#101]
I posted five before but then i just had a few months using MoI, now here are my new ones:
-Dimensioning and annotation
-Line types and widths and fillers
-pdf output for printing
(with that 3 above i could stop using autocad!)
-A better silhouette tool
-Deformers
In order of importance.
27 Apr 2011   [#102] In reply to [#101]
My 5
-Line types and widths and fillers visible on monitor as well as when printed
-extrusion of solids without having to use boolean union to have one solid after extrusion
-shade and shadow for 3d viewing (not very important - can be done with available rendering tools)
eric
27 Apr 2011   [#103]
Hello,
My five requests are:
- Hidden line removal while keeping the most excellent AI export
- Filleting improvements
- Settable precision
Well, I thought I had five. I'm sure MG will come up with something that will make my tasks easier that I haven't even thought about. I'd be happy with the first one, that alone will lock in a v3 sale. Have a few larger projects coming up that will be using MoI for manual creation and the hidden line removal will save me loads of cleanup time.
27 Apr 2011   [#104]
Would like to have a simple texteditor.
Network points after Boolean operation.
Manipulating networks with magnets, loopcuts, aereas or other possibilties.
History.
Rudl
