Full Version: Top 5 Features list for V3 !
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  106-125  …  426-442
2 Aug 2010   [#46] In reply to [#45]
"""""""""""Is this what you're talking about Burr?""""""""""""""
That Danny has a mind like a Steele Trap. Thats the thread I was refering to where it had been discussed before.
And then the flip, I'm not sure how/if that works...I understand it's about applying a curvature from the existing surfaces, but then to be able to flip/invert that could be some type of cavity tool. But, maybe thats just me looking for "wacky tools?"
But basically sliding the apex of the buldge around could be useful.
2 Aug 2010   [#47] In reply to [#46]
Hi Burr, sorry I'm still not sure if I'm understanding...
Do you mean a slider to control the bulge like this one here: ?
You can do this with the current Blend command by entering in a negative value for the bulge, that flips it to the opposite side, here's an example:
2 Aug 2010   [#48] In reply to [#47]
Well look at that...FLIP and I didnt even know it!! Presto!!! lol
As far as the other option, I envision it being an opprtunity to control the surface like this..
FIrst, this is a regular MoI blend with some bulge. Note the bulge favours one side (The strong side perhaps???) I've called dthis the apex.
The new slider would allow the control/ability to "slide" the bulges apex (Pardon the pun)
The values that Danny refers to in that other thread I read as this. The two number 1 values are the "Depth" at which the skew has to work. The number 2 value is the bulge as it remains now, and the number 3 value is the skew value, which slides the apex back and forth to be strong on one side or the other..
2 Aug 2010   [#49] In reply to [#48]
The 2 number 1 values above, could even be like a Conic RHO value, as opposed to an actual "distance" which would be hard to figure out on the fly.
2 Aug 2010   [#50] In reply to [#48]
Hi Burr, I think I understand now.
Well, remember the Blend adapts itself to the directions of the objects it is connecting.
The shape you have on the left there has a tangent direction pointing more sharply up in the vertical direction than the one on the other side, so the half of the blend that attaches to that side correspondingly also goes up more in the vertical direction.
What would help to alleviate that would be to have an adjustable bulge for each side with 2 sliders instead of just one global slider that bulges each side by the same amount. An option to adjust bulge independently for each side is one of the things that I do want to add to Blend.
2 Aug 2010   [#51] In reply to [#50]
Oh Ok. I see what you were saying there. Sounds like that would do it too! Thanks
9 Oct 2010   [#52]
MoI is the best nurbs modeling software!!! congrats Michael!
All the features that have been asked will be welcome but I have another one: Smooth. Some times when i make a network, the generated surface gets wrinkled. So smooth please!!
Another one is make2d like in rhino. Silhouette is fine when you are working with one object, but when there are objects behind other objects it makes lines that you dont want.
Deformers would be a great implementation for MoI too. Imagine one solid taking the shape of other one while embracing it!
Offset and shelling tools need to be improved. For example, when you offset too joined surfaces, some times it will create intersecting surfaces not joined.
Well thats all for now!
10 Oct 2010   [#53]
Variable filleting, continuity options in the network command (so that creases are not visible when building something patch by patch), variable blending.
I consider those to be basic functionalities.
I'm sure SuperMike will come up with something awesome!
This is Sparta
14 Dec 2010   [#54]
Here's my 5
1) Texture support
2) comprehensive training video
3) Rhino 5 compatibility
4) option to maintain Rhino texture coordinates
5) option to have objects grouped and named by Styles when exporting to LWO for modo
Thanks for the great software Michael!
Bill
14 Dec 2010   [#55]
more tools for engineers. LOL
-array (either by angle, centerpoint, spacing, etc.)
-bend
-divide space (equally, by a number, etc.-sort of an offshoot to array)
-printed manual for $10 postpaid in the USA
Cheers,
Chris
14 Dec 2010   [#56] In reply to [#55]
Hi Chris, just a quick note re: Array
The already existing Transform > Array > Circular command lets you create an array by an angular distribution around a centerpoint:
And the Transform > Array > Curve command next to it can create an array by evenly divided spaces as traveled along a path curve:
Some more information on these here:
http://moi3d.com/2.0/docs/moi_command_reference8.htm#arraycircular
14 Dec 2010   [#57]
Hi Michael ...
My top five would include:
Dimensioning, text and line weight control (so I could use MoI as a drafting tool as well as a modeling tool) ... I guess that's 3
Printing from within MoI
Extrude is beautiful ... sometimes I would like to reverse extrude a face instead of having to trim with boolean difference.
MoI is wonderful for modeling ... I use it more and more for illustrating structures to clients ... it might be nice to be able to print to 3d pdf but that has already been discussed.
cheers,
eric
14 Dec 2010   [#58]
I think my #1 feature for MoI would be a really basic renderer.
Something that can render a curve or a surface to a transparent PNG.
Also, export to SVG would be nice.
14 Dec 2010   [#59]
Hello,
Even at this point MoI's 2D output is exceptional. Waiting for the icing on the cake in 2011. Some better filleting would be welcome, but I suppose that is more dependent on the library than MoI itself.
15 Dec 2010   [#60] In reply to [#56]
Wow! Michael, I gotta RTFM. LOL I don't know how i missed that.
Thanks!
C.
15 Dec 2010   [#61]
Very nice thing to appear, 2D functions for drawing creation.
João
15 Dec 2010   [#62]
2 things I would like (not easy)
1) Variable radius fillet
2) Surface continuity matching e.g. for Network patch, sweep, loft.
18 Dec 2010   [#63]
Variable radius fillet has been on my list for a long time...
Deformation tools would be a welcome addition as well
22 Dec 2010   [#64]
Can a new user place a request for a V3 change? Hope so.
I am big on desktop customization and having two 24" monitors I would find that the ability to show all the tabs on the command palette opened at the same time to be very sweet (or as toolbars that can be docked or undocked).
22 Dec 2010   [#65]
I would love to see a simple renderer attached to MoI as well - having to deal with all the complexity (and flexibility) of large packages like Modo or C4D is not always necessary.
I would suggest looking into adding a simple exporter to Luxrender scene format; it's plain text and fairly uncomplicated. I would even say that writing UI for it would be harder than the export itself. :-)
