Full Version: Top 5 Features list for V3 !
Show messages:  1-14  …  375-394  395-414  415-434  435-442
28 Oct 2013   [#435]
One feature would be excellent for design workflow, real time temporary cutting plane for working in section. This feature allows people to study their models and add details
30 Oct 2013   [#436] In reply to [#422]
I know this is likely to be extremely complicated, but would it be possible to edit a cross sectional curve created in this way and have it affect the original model? I vaguely recall seeing something similar in SolidWorks once, and being impressed..
Also, to add to the debate above, a cross section tool similar to Sketch Up would be very useful for me. It would allow me to expose areas of a model for editing that are otherwise invisible (I'm using Moi for architectural work, so changing floor levels, adding doors, and so on.)
30 Oct 2013   [#437] In reply to [#436]
<< a cross section tool similar to Sketch Up
A simple Booelan Diff (or Trim if you want open volumes) by a straight line + hide one part (or move) don't make the same ?
30 Oct 2013   [#438] In reply to [#437]
"A simple Booelan Diff (or Trim if you want open volumes) by a straight line + hide one part (or move) don't make the same ?"
It would if I wanted to affect the geometry. It's really a display thing i need, to hide everything on one side of the cut line temporarily.
30 Oct 2013   [#439] In reply to [#438]
Make undo after ;)
But Michael will tell you if it's doable or not! )
30 Oct 2013   [#440] In reply to [#436]
Hi al,
I guess it's "possible" in the sense that if I buckled down and worked on just that for a year or so maybe it could happen...
It's just fairly tricky finding spare years of work time hanging around though. ;)
There are a lot more basic kinds of editing to tackle first way before that kind of more fancy editing though.
30 Oct 2013   [#441] In reply to [#440]
'I guess it's "possible" in the sense that if I buckled down and worked on just that for a year or so maybe it could happen...'
Ah. v4 then?!
30 Oct 2013   [#442] In reply to [#441]
Hi al,
> Ah. v4 then?!
It would be fairly tough for v4 as well, since it would be difficult to have a new version that only had just that one new feature in it.
The big problem with undertaking tasks that are hugely time consuming is that it's basically trading that feature for numerous other ones that I could have spent time on instead...
But that's where this discussion thread is helpful - if numerous people started posting here that having that one single feature was the most important thing for them outweighing anything else then that would move it up the priority list.
